I have known for a long time that I am being WATCHED and I have also experienced various forms of SUPPRESSION and SABOTAGE over the years.
I doubt that very much,as you have nothing of interest to be worried about Les. If you did have the MIB watching you ,you wouldn't be here on a public forum posting every detail needed to run a car or ICE off of water--Which begs the question. If you are prepaired to post all the information needed on a public forum,then one has to wonder why you wont show all this information in action-in way of a video showing your setup working.
(Perhaps you should check out the video “Free Energy – Pentagon Conspiracy to cover up.mp4” where I am also featured briefly at 3:39 and 5:38. If my memory serves me right, that interview took place in 1996.)
Yep,seen that one. There you are(once again) making claims of cars running around the streets running on only water,but of course ,no one can see this due to government suppresion,and threats of death
As perhaps most readers here will know, “they” also tried to kill Bob Boyce not long ago!
No-didnt know that. One has to wonder why they would be after him,as he also never had a HHO looped system that worked.
As you have pointed out in your excellent post, we are all free to think whatever we want to think!
Yes we are,but i better not post what I'm thinking right now
You are one of the VERY few who understood from the start what the “8 times 'Faraday' electrolysis
with nano-pulse power supply” meant and you also knew that the 'Faraday' ONLY applies to pure DC electrolysis
The cell is powered by the inductive kickback from a transformers secondary
Quote your file: The energy in the generated pulses are transferred to the secondary and are then applied to the electrolysis cell.
Further, you also know that my 139 cell HV electrolyser is NOT DC electrolysis but is PULSED.
'Faraday law' DOES NOT apply here and never has!
Since when
Regardless of weather it is pulsed or continuous,it is still DC.
Faraday's law stands.
The direct consequence of this is a WAY over 'Faraday' HydrOxy gas production which is also disputed by the same “no-hopers”!
Oh,there is that claim again
So no-hopers are those that would like evidence from those that make such claims of Overunity devices.
I would think that no-hopers are those that make claims they cannot back up
I thank you also for pointing out the FACTS about the “8 times 'Faraday' electrolysis with nano-pulse power supply” thread to the trouble makers here.
Those ruddy trouble maker's-at it again
Make no mistake, Mark, the 'witch hunt' was NOT about the name of my “8 times 'Faraday' electrolysis with nano-pulse power supply” thread!
It was/is about my WFGP. (Water Fuelled Generator Project)
It was/is a childish RETALIATION for my refusal to 'give in' to the demands of a bunch of hardcore 'skeptics'!
Maybe they work for the CIA,or home land security--and there just trying to discredit your work Les. I mean,there is no chance that there just ordinary guys that were interested in and prepaired to spend time and money on your device,but made the mistake of asking to see a working model-->the proof that must be provided to back up ones claims of an OU/Way over Faraday device
A couple of quotes from the power and creed document
: To place integrity before ego;
To post claims of overunity only when backed up with solid proof and
evidence in the form of fully documented, and accurate measurements and
test setup diagrams;
They have managed to convince the so-called 'moderator' (who has NOT done his homework!) so he changed the name of my thread for no valid reason whatsoever!!
Hard to do your homework when there is nothing to base that homework around.
The name of the thread was changed because it was misleading.
In short, my time on this Forum has turned out to be an almost total waste!
And why is that Les-->because some have asked you to back up your claims with evidence?
After I 'tie-up' a few loose ends here, I am leaving this Forum as a PROTEST to the ongoing
INSANITY, INTERFERENCE and CENSORSHIP! (the *big brother* approach you referred to)
Yes,we knew this was coming--we have seen it many times before. When the pressure is on to backup ones claims,they quickly seek a reason to leave-->so as they don't have to back up there claims-->which they cant
I just wonder if 'peterae' (the owner of this Forum) is REALLY aware of what is happening on his Forum??
I'm sure he is,and Poynt dose a great job at keeping things on the straight and narrow.
Anyway, I have 2 boards left and I will send you one, this time in REGISTERED Air Mail.
We will soon find out what will happen!
I'm sure they will turn up safe and sound-just as mine did
The MIB must have been on days off when mine arrived.
You should ignore the latest posts by several posters as they have clearly demonstrated
NON-COMPREHENSION of what is required by this circuit.
Nor do they understand HOW the IES operates!
I don't think they have bothered to check out my work on this subject.
Generating 200ns pulses is NOT the issue here. (that is a “piece of cake”)
When power is applied to the circuit, control MOSFET Q2 is turned ON.
“Opening switch” Q1 (SITh) is also turned ON, simply because it is a 'normally-ON' device!
Current is now flowing through Q2, Q1 and the transformer's primary, 'storing' a certain amount of energy in its magnetic field, depending on how long the current has been flowing.
The current level is adjusted by the ON-time of control MOSFET Q2.
In other words, when the current has reached the desired level, Q2 is turned OFF.
Now, “opening switch” Q1 must turn OFF very fast, in order to generate a sharp, short pulse!
The AMPLITUDE is a lot higher than the DC power supply voltage.
So at the end of the day,the cell is receiving the inductive kickback current from the secondary of the transformer.
The path they are on at present is GUARANTEED to fail
The fail here Les is your inability to understand what this nanopulse circuit is doing-->and that is-->sending the inductive kickback spike to the cell as the current source. The amount of available power/energy in this kickback is less than that which created it. There is no need to use inductive kickback current,as the very same can be sent to the cell without all the losses involved in your circuit.
If you would care to post a scope shot showing the trace across your cell using your circuit,i will replicate that trace without your circuit. As you quote in your document :Les Banki (Electronic Design Engineer),i am sure this is within your means,and I'm sure one scope shot will not attract the MIB.
What I refer to is the FACT that hardly any water is being used to power the engine!
This much is true.
