2024-11-29, 19:40:11
Author Topic: Modified phase converter, turn into a power amplifier! input 1 Kw, output 4 Kw  (Read 3015 times)
 Owner of Missouri Wind And Solar(Jeff) made this video. He talks about the guy that came in his store
and demonstrated his Modified phase converter, turn into over efficient machine or rather power amplifier!
As Jeff says, it  takes in 1 Kw, and puts out 4 Kw of power.
https://www.youtube.com/watch?v=PwedoZZHadY
He does mentioned that the inventor modified the phase converter armature with permanent magnets.
But still how is it possible that he was able to make that converter so efficient?
The old sneaker on the shaft Prony brake, gives new meaning to "foot pounds".  :o
No mention of  phase angle or voltage differences, power factor not considered. No real loads.
Now where did I leave my calibrated sneaker?  ;)
Hopefully around someones uncalibrated arse  ;D
Good one, Peter.
This is video a typical example of jumping to conclusions before real measurements are performed.
All right,  it's okay to get excited about something, I've been there and had many disappointments after accurate measurements were performed.
Still we carry on with the work. Stil can't find that sneaker.  O0
LMAO ;D-foot pounds.
I was going to comment on the video,but i just couldnt bring myself to do it C.C
I wonder if he sticks his tounge on an iced lamp post during winter to get a temp measurement :D
Hi All,
 Everytime I see people make claims of 400% efficiency you have to ask yourself what were they thinking.
How foolish could one be to make claims while he shows how a load is tested with his own foot.
He may weight 200 pounds, but it's not 200 foot pounds of torque.
The trick of running a 3 phase on a single phase is old school, just change the wire around and add a few capacitors.
Tom.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-29, 19:40:11
