2024-11-30, 03:52:28
Author Topic: High voltaga Generator  (Read 1557 times)
Hi All,
This is a experiment using a secondary winding from a microwave transformer to create higher voltage.
https://www.youtube.com/watch?v=E3pAiHwcuZQ
Tom
Hi All,
Tom
Tommey
Try putting various AC rated capacitors on the output of the window generator to see if you can find resonance with the turning rotor. The energy being pumped out of the coil should form a resonance with the capacitor and a sweet spot RPM will be found.
While the resonance may seem to load the generator more, you wll be have lots of amps circulating in the circuit. It is a way of impedance matching the crank speed /power input to the generator. You may be surprised when the sweet spot is found.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-30, 03:52:28
