2024-11-30, 02:51:07
Author Topic: Tommey Reed's Simple Vapor Carburetor  (Read 4409 times)
This simple vapor carburetor will run any engine when you have carburetor problems and can't buy a new one.
I have built these for years and it's so simple a cave mane can do it.
Enjoy this video. :o
https://www.youtube.com/watch?v=1ZUnbHrXs3I
Tom
« Last Edit: 2014-06-28, 03:02:58 by Tommey Reed »
Tom
Hi Tom, yep that's the way to do it.
Here's a little extra for those that reprocess cooking oils and other waste oils (don't do it) ;D  I think you know where I'm going with that >:-) and you can upgrade the octane as well when done properly :o
thanks Tom
regards
Tom
Have you run any comparisons
A quart thru the carburetor under load and a quart thru the gassifyer under load?
thx for sharing.
Hi Chet,
Yes, you do get a 30% increase of output, but with all the chemicals added to gasoline today you would need to keep the temperature around 120deg using the exhaust.
Tom...
This is a test run on a old 25hp Honda engine using my simple vapor carburator.
https://www.youtube.com/watch?v=edXvkkQshE4
Tom.
Hi Tommy!
Thanks for the video, your design is the simplest one  O0 but for more applicable use on car engines I recommend below video:
https://www.youtube.com/watch?v=17xVBQ_U2yw
also the same above video on vimeo: http://vimeo.com/53415056
For those who have not access to youtube or vimeo download it here:
http://www.mediafire.com/download/q897d40h0yordyl/The_Complete_High_Mileage_Fuel_Vapor_System_for_the_Internal_Combustion_Engine_Part_V_The_Gift_YouTube(1).rar
I have seen this video about two years ago it has been reuploaded by others, as I remember the originator of the video disappeared after first upload.
Leed
Hello,
I seen the video and understand that he wanted to make a custom parts to sell.
The problem with a vapor carburetor is you have to adjust the fuel & air mixture under different loads, that won't work as efficient vapor carb.
Tom Ogle have to adjust his system when He got 200+MPG.
http://www.rexresearch.com/ogle/1ogle.htm
Thanks for the video.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-30, 02:51:07
