Hi Grumpy
Thank you for the offer, yeah i have been looking for a 1000pf variable Vacuum cap on ebay, but they are very expensive, but non variable will make my life hard to tune these.
I have not been getting good results so far, i am not so clever with this high voltage setup, fish out of water really.
The caps i am using on my primary are 5 x 1uf HV caps in series and for my secondary cap i am using 10 in series 470nF to give me my 47nF @ 6300v, i suspect this isn't good, maybe high series resistance is causing me problems.
Originally when i posted on OU that i was going to Replicate this device, i mentioned i was doing it because my pulsing a bifilar coil experiment on the other thread had collided with Some of Don's stuff, so now i will switch back to using this system for my original purpose.
The purpose is for me to start pulsing my primary with my 2 channel controller and start injecting the delayed pulses to study what effect this has with a movable primary and a tuned and untuned secondary, this means i will not need the expensive high voltage caps and can drop down to 500 volt caps instead.
Also the problem i have had is that when i am using 10kv to pulse my primary, i am left in the position of making sure my scope is not connected, this leaves me somewhat blind to what is happening, so with my original intention of pulsing the primary with fast nS pulses i will not have this and will be able to scope and see what the results are.
Also
If anyone is interested i am willing to make a few of the secondary coils to send out to people to experiment with, on the condition they document their experiments on OUR, guys let me know on here and i will get the gear to make another 2 or 3, i will have to leave the primary upto you guys.
Again thanks for the offer Grumpy but there's no need now
Cheers,
Peter
