2024-11-28, 17:50:26
Pages: 1 [2]
Author Topic: Men in Black are stopping me from accessing my own forum :(  (Read 14468 times)
Thanks but i better not start monitoring traffic  8)
So is it the one before timeout or the first timeout that's blocking me, is this common and no we don't block any IP's at work it's only me  O0
What do i need to do, contact the tech email address above.
Thanks for your help e2matrix, i cant even read any email without remoting into my home comp.
It would be the first timeout that is a problem but it doesn't always mean that server is THE problem.   I would put Puppy Linux on a flash drive (even a one gig will work but probably better a 4 gig - less than $5 from many sources now)  and see if you get the same results.   Tails won't work to use traceroute since that is one of the very things it prevents for security reasons.  Go into the Terminal (or Console) in Puppy Linux and use the traceroute command to see what you get.   You could have something messed up with Windows or a virus or malware.   Running a traceroute from Linux will eliminate that possibility and you will know for sure if it's your computer or something else.   I've even seen network adapters go bad to where they flake out part of the time causing problems similar to this although I see that as a less likely scenario.   Puppy Linux is small and very easy to use also and can be run from a CD or usb flash drive easily.  Just grab a Puppy Linux Iso and burn it the iso to a CD and you can either boot that way or boot it up from CD and then make a bootable usb flash drive (it's a menu selection in Puppy Linux that let's you make a bootable Puppy Linux flash drive).   If you have a laptop you could also probably run it at work off Puppy to see what traceroute finds that way too.   Several versions of Puppy - here is one that should be easy and is only about 156 Mb :  http://distro.ibiblio.org/quirky/precise-5.7.1/precise-5.7.1.iso
Puppy seems to work well with most common hardware and you can be up and on the Internet once you've booted it in just a minute or two.
I would give that tech a phone call if possible as it may be faster to get an answer but email may work.   Sometimes they are quite busy and slow to respond but everyone is different.
BTW do you have a firewall ?   You should if you don't but I'll assume you do and if so can you look at logs of blocked web sites?   The logs of them can tell you a lot.  Sometimes firewalls can get messed up too and will end up blocking a lot of things they shouldn't which could cause the problems you are having also.
I was going to try puppylinux, that times out as well, see tracert below.
I tried the google DNS setting, made no difference.
My ISP responded
Eu is having data transfer problems. unable to replicate on a dial test but appears the I.P. may have been blocked as it is failing at the host servers.
I'm wondering if it's something to do with my router now.
I would rather fix this just in case it happens again, and anyway i want to know the cause  >:(
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Peter>tracert www.puppylinux.org
Tracing route to www.puppylinux.org [66.96.160.129]
over a maximum of 30 hops:
  1     1 ms     1 ms     1 ms  192.168.2.1
  2    37 ms    52 ms    37 ms  lo0-central10.pcl-ag04.plus.net [195.166.128.185
  3     *        *        *     Request timed out.
  4    36 ms    36 ms    37 ms  xe-0-2-0.pcl-cr02.plus.net [212.159.0.206]
  5    36 ms    35 ms    40 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  6    50 ms    37 ms    53 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
  7     *        *        *     Request timed out.
  8    38 ms    38 ms    38 ms  ae-51-51.csw1.London1.Level3.net [4.69.139.88]
  9    40 ms    35 ms    37 ms  ae-115-3501.edge3.London1.Level3.net [4.69.166.1
30]
 10    37 ms    37 ms    39 ms  be3043.ccr22.lon01.atlas.cogentco.com [130.117.1
5.245]
 11    38 ms    39 ms    37 ms  be2315.ccr22.lon13.atlas.cogentco.com [154.54.73
.109]
 12   123 ms   123 ms   124 ms  be2391.ccr22.bos01.atlas.cogentco.com [154.54.44
.237]
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21     *        *        *     Request timed out.
 22     *        *        *     Request timed out.
 23     *        *        *     Request timed out.
 24     *        *        *     Request timed out.
 25     *        *        *     Request timed out.
 26     *        *        *     Request timed out.
 27     *        *        *     Request timed out.
 28     *        *        *     Request timed out.
 29     *        *        *     Request timed out.
 30     *        *        *     Request timed out.
Trace complete.
OK fixed it, i did a factory reset on my router.
Thanks for your help guys  O0
Good going. We were all about to go on Level 10 Alert!
Do you ever do a major backup of the site?
Remember way back we had a forum called TPU123 when @otto was doing his ECD experiments? Well, before it went offline I backed up the complete site. The forum did not last that long so the backup was not that big.
Regular backups are done at server level.
OK i have only partly solved the problem.
My router sits in a cupboard attached to a pc i use for storage and bitcoin mining. i can remote into this and it's connected via ethernet, no monitor or keyboard on it, but OUR.com timesout even though it connects via ethernet.
Now to reset the router i took it out of the cupboard and connected it to my main comp using ethernet, normally i wireless into the router, well it worked OK when i ehterneted in, but having put it back in the cupboard it stops allowing OUR.com again.
Strange thing is that the comp in the cupboard with ethernet connection OUR does not not work either.
So i took it out the cupboard again and connected to main comp again using ethernet and it works, go back to wireless to my router and it stops again.
Very strange, still scratching my head right now.
At least i know it's not the my isp to host server connection, despite it looking that way from tracert.
I hope that what "type" can not be used for those good people ....
Wow this is weird, i finally got it working, it turned out the dial on demand setting in my router was not ticked, but it gave the same fault, i could surf most websites but i think anything with a logon was timing out, or something like that anyway.
Well i am working again THANK GOD  :)
LOL - glad it wasn't the MIB's...
LOL indeed, but it's still not fixed yet, i thought it was and it was for a while, seems to work sometimes having reset the router but other times it just wont work, i think it's either the router or my wireless dongle, I've tried googling things and been trying various but still no solid fix, as both comps don't work one with ethernet and other with wireless i guess it must be the router although i am also having suspicions that one comp maybe screwing it up as it seems to work more often with the ethernet disconnected.
I hate intermittent faults, thing is i only have 2 more weeks at the place with this setup anyway so i am not going to loose sleep over it.
@Peterae
I remember the last time I had to reset my router I also had to readjust the default value for MTU from 5000 to 4096 or something otherwise the router would lag.
yep did try, was 1472 it was suggested to try 1400, i will try higher then tomorrow  O0
Peter
Pages: 1 [2]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-28, 17:50:26
