Well fellows
I know there are a lot of Raw nerves around about this Gentleman!
The Buzz Quote:
People have to learn the process step by step and the first step is the molecular polarization process just as Meyer stated.
After posting the Above last night
The thread was locked.
http://www.overunity.com/index.php?topic=6340.msg276989#newA pm to me follows.................[several Relevant but nasty comments were for mature audiances only, omitted]
Quote:
Too funny. I read your comments at OUR today and see you have been reposting my posts there. I about fell out of my chair laughing about the OU van gogh comment.
Nope, I don't have syphilis, I am over 50 years old and not a bit over weight. I drink 3 pots of coffe a day, smoke a pack a day and my hands were probably swollen from winding copper tubing. I just figured out they make thin walled tubing which is easier to bend. You find that in a different part of home depot - over by the brass fittings. It's called an icemaker install kit. 20 feet - 20 buck and comes with a few fittings.
The moment I started posting the gas and how to make it used in the tubing, Pirate banned me and deleted the posts. Even when I tried under a different username to post the info., it was deleted.
The methods and ways to build this device are ENDLESS!
Lee deforest invented the vacuum tube. He placed hydrogen in the tube and it self ran and self destroyed. Decades later they invented the pentode tube. Again the tube would self oscillate and self destruct. So they de-tuned it.
It is sometimes called multipacitor effect.
http://en.wikipedia.org/wiki/Multipactor_effectUtkin describes it well in his documents but leaves out the gas portion. The reverse wind mimics the two waves that make a particle which I have written about somewhere
The gas is simple to make and I suspect there are several that will work. Exothenilist (mis-spelled) made a post in 2008 where his girlfriend translated a video of kapanadze. Kapanadze talked about how it made everything around the device give off electricity, that is true.
For example - If I connect a neon to a earth ground and touch the other end to the coil, it will not light. BUT, if my wife holds one wire and I hold the other wire, it lights to full bright 4 feet away. If we hold hands with our other free hands, the light is cut in half.
I could explain all kinds of weird things about this thing that make no sense at all until you realize it is an energy sump just like Tesla stated. No meter could measure it but I found a way to make a meter to measure it using a cheap analog and some parts.
You saw how in the green box video when they tried to measure from the light bulb the meter just bounced around? Yep - same thing. Nothing electronic is going to run near that coil. If he did get an amp reading off the ground plane in that video, I would be amazed. No wonder that is the biggest wire in the system X10. So you are basically unable to use scopes and meters when working with it. Did you ever see a scope or meter in a lkapanadze video? Nope - useless.
Eric Dollard stated it is "dielectric electricity". That is not true but you can not use it without a dielectric between you and the coil from what I have figured out so far. It is by far, the strangest thing I have ever played with.
I suspect there is another step to convert it into a current source. I have not figured that out yet. Absolutely nothing about this electric field makes sense. I suspect when I get the correct gas made, it will be a better current source.
I have proven that different gases at different pressures changes everything about how it works.
The buzz bomb was so far the single best disclosure regarding this device.
The large copper coil on the end is just a kicker used to start it and is unimportant. The inverter box that kapanadze plugged into it to start it drove that and charged a cap inside the green box. pirate claims it is a heater coil. Ha!
Feel free to post that at OUR since I know you probably would anyway. My best to Grump - I miss ya man.
Busy experimenting with this super strange field for now. I'll be bach.
PS I'm quite sure "theBuzz" has been deleted at OU
so no more PM's To me!
Chetkremens@gmail.com
