OK
Unless I've really missed something
This is Quite an observation by Quarktoo!
From Here
http://www.overunity.com/index.php?topic=7679.5985Quote:
Go up to the photo of the copper coil and look at what is on the ends of the tubes and think about it. There is you big secret and it is not complex.
Don't get too cocky girls. There is a few frames of a video I have not posted that blows this wide open. No way in hell would you use uninsulated copper tubing with no spacing on an inductor but Kapanadzi is using it and lots of it. So did Hubbard and it is the mother of all free energy devices.
There is also a video that I have pointed out before of the Russian wood working factory running on a free energy device where they are using uninsulated copper tubing for coils. I tried to get people to notice but it went right past them.
In every instance, they try to hide the fact that they are using tightly wound uninsulated copper tubing by covering it with tape. The cost of copper tubing far exceeds that of wire and there is no way to use it without insulation unless they are pulsing a gas in that tubing to produce a quick high current pulse and that is exactly how they are pulsing this magnetic compression coil and what it requires. That would explain why a wire goes INSIDE the tubing on one end and attaches to the OUTSIDE on the other end.
If you think a flyback is going to magically transform into 5000 watts of power with a earth ground and a coil, you need to study more physics and stop watching the magical Jim and Tammy Fey show.
I could spend the next half hour posting photos of devices that use copper tubing in coils and it is not because they are Tesla type primaries. The reason people most likely could not get the results Tesla did back in the day is, Tesla never disclosed what was in the tube. Note how in all the devices the tube need not be insulated?
FACT: Under the tape of those three Kapanadze inductors are two layers of uninsulated copper tubing. Brew that--------------------------------------------------------------------------------
Logged Free EnergyRe: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
« Reply #5990 on: Today at 12:37:40 AM »Sponsored links:
quarktoo
Posts: »Quote from: wattsup on Today at 12:21:18 AM@forest
In your post here;
http://www.overunity.com/index.php?topic=7679.msg276207#msg276207Is it possible that the brightness is due to an internal spark gap housed inside the coil. He then plugged the end to not show it but had to make a small hole for aeration. I will have to take a closer look at that.
Unlike what @QT says about it being a "magnetic short". What is a magnetic short. Nothing as usual.
Quarktoo responce
Quote:
Wrap a thick band of copper around any part of an inductor and you have a magnetic block or what I call a magnetic short. That magnetic short forces all the magnetic energy to go in the other direction just like the EMP gun that Kapanadze pointed to when he disclosed how it works.
Electro-magnetics 101
Logic 101
Reason 101
- Verses -
Your attempt to suppress this at an elementary level. Anyone with two eyes can see that is a copper end cap. You people doing suppression are so obvious. This web site has a reputation for being nothing more than that and that is why so many other web sites have sprung up. It is only going to get worse if you continue to do your thing. Logged Free EnergyRe: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
« Rep »quarktoo
Note the man standing there with the coil in his hand. Notice how the end of the tubing is crimped closed? That is so the gas does not escape.
Normally I would not have disclosed this as I have known of gas coils for years. That was my way of getting some payback. You push, I push back. People read this stuff and start noticing things and thinking.
Quote from: ramset on Today at 01:08:08 AMQ2
I don't think you pushed back hard enough!
Whats the gas?
Quarktoo responce,
I call it "Ramset Gas" because it is so magnetic.
»http://www.youtube.com/user/Xdole#p/u/1/YzepOmT5N_8
Dole is the sharpest pencil in the box. Notice how he crimped the ends of that coil closed? Maybe he figured out the composition of Ramset gas, maybe not.
I was able to cobble together my own version of DOLE's cold electricity demonstration. That is by far the most exciting thing I have learned in the last 5 years. If I had his address, I would send him flowers. That process needs to be explored in full.
If this web site had any sense, it would offer DOLE money to start threads on his projects. DOLE worries that people will get electrocuted since he uses a 10K neon transformer and a MOT in some of his experiments. He is not only smart, he is a decent person. A class act all the way.
Well Ramset, sorry I have to ban myself for a week or two but I need to rebuild my gas lab left over from my Stan Meyer stuff and do some experiments. Here is a good place to start.
http://www.magnegas.com/Meyer's first patent is also a good reference.
