2024-11-26, 08:56:21
Pages: 1 ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18]
Author Topic: Tariel kapanadze's Energy Generator  (Read 367679 times)
We have seen several times that the current on the GND wire is approx. 24A. We do not know if this is real current! or if it is electrostatics. Only the fact that 220V x 24A gives approx. 5kWh and this is supposedly in line with what Kapa says. However, we have no certainty that the bulbs light up with this power but they definitely light up with a minimum power of 1kWh if they are 1000W and we do not know this for 100%.
What do we know for sure?
In my opinion, we still do not know anything because no one has done it "correctly".
No one has observed any increase in energy and dozens of people are still dealing with it without result.
As for the current on gnd, I wrote that there are only three ways I know of when the current will be there.
1. sparkgap
2. TT coil
3. closed circuit loop.
Does anyone know of any other possibilities?
4. Tesla radiant energy patent
https://youtu.be/hofuRiMdrDE?t=1000
neutral has to be thick for large current GOT from ground via electtrostatic induction at low frequency
Hi guys,
I went trough this tread and could not find a good start with a schematic.
Is it possible the most acurate schematic can be posted with a brief summary where we think this all comes together?
A kind of a rap up after 10 years.
Maybe we get some new ideas?
1. sparkgap
2. TT coil
Is electrostatic charge / discharge already part of the above mentioned?
If you give a spark to the ground wire then current appears on that wire. This is best seen when you use a spark gap.
Hi guys,
Your wish is my command!
I enclose the patent minus the start up which Kapanadze said was variable. ie a 9-volt battery across the terminals and then a solenoid to remove the power input.
Note: He said the arrangement between the L1 and L2 coil was special or words to that effect. Maybe that is where the secret is. "It's so simple that you'd laugh."
Maybe moving the L2 coil to find a "sweet" spot is all that is required?
Anyway, some scope shots with different arrangements might be useful.
Also, remember that L2 has to be a whole multiple of L1 to get resonance.
He talked about the spark gap which is used as a fail-safe device to safeguard against runaway. Please don't be mesmerized
by the spark gap as Kapanadze said they had an electronic circuit doing the job but it kept blowing - hence the spark gap.
In other words the spark gap is NOT where the secret is. It just distracts.
DEUTERIUM
One day Kapanadze asked me if Deuterum was available in England.
This was during the time we were negotiating his forthcoming work in England.
I have never mentioned this before, but what prompted me was Kapanadze's comment in the video that the coil had a secret
If that is the case, then we are looking at a form of LENR, which may make sense.
Over to the chemistry or radiation experts.
Maybe the coil former is made of plastic and then sealed. Maybe the deuterium is absorbed in a sponge or some other absorbing material.
We know that Kapanadze was experimenting with a water-powered engine.
Maybe water is all you need in the coil and deuterium makes the process better, - who knows?
Anyhow, I have told you everything I can remember now.
Once some guys were speculating that his coil had polystyrene in it.  I mentioned this to him and
he paused for quite a while and said "That is not the secret".
I hope to see some experiments on that information.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-26, 08:56:21
