Hi Peter
Now I am going to explain a very simple thing and you can take it or not, it does not worry me, but it works, and I have demonstrated this to a group of people.
Tesla's 3,6,9 is no joke, it is real when implemented in the right way.
Harmonics will look after themselves, what is needed to start with is mixing Two frequencies, yes hetrodyning, but mixing in the item you want to alter in some way by electro magnetic waves (RF).
The most important is the frequency split, it should be eg. 120khz and X6 this frequency which is 720khz, as long as it is a 6 X difference it does not matter what frequency you start with.
Here is an example in khz:-
120 720 600 840 240 1440 1200 1680 480 2880 2400 3360 960 5760 4800 6720 1920 11520 9600 13440 3840 23040
and so on, now look if the split was say X4 below
120 480 360 600 240 960 720 1200 480 1920 1440 2400 960 3840
I have blackened the blocking frequencies, the X6 does not have any blocking frequencies, so this split will create a full spectrum of frequencies
With harmonics, as they go up and down, the power of the harmonics is less than the original, with hetrodyning you get a straight line with peaks greater at certain points in the spectrum
As with all RF you need a matching network for the frequency, so as to stop reflective power, so it is not just connecting to a coil. This system combines in "free space", there is no direct coupling, the item to be irradiated has to be between the two radiating coils, then you can hit what ever frequency the material being irradiated needs for whatever reaction required, be it to break molecular bonds or change atomic state. The latter I have never worked on, but breaking molecular bonds yes.
Hope I have given food for thought, and as I have said, take it or leave it.
« Last Edit: 2013-11-23, 08:28:17 by Centraflow »
