2025-03-31, 19:52:19
Pages: [1] 2 3 4 5 6 7 8
Author Topic: Wesley news #2 Wesley succesfully performs his TK test in a remote location  (Read 155116 times)
http://www.youtube.com/watch?v=wuoISZAlFAc&feature=youtu.be
Here is another Wesley translation of an Akula vid [Akula #3]
http://www.youtube.com/watch?v=3xUjJjBUdwE
Thx
 O0
« Last Edit: 2018-08-16, 13:32:07 by Chet K »
Nice Tesla coil, is that all it is?  I thought these guys were replicating Tariel Kapanadze devices.  :-\
Edit:   Just watched the second video, much more insightful, so he is replicating the TK device.  I like the fact that he shut the power off to his whole house.
« Last Edit: 2013-10-03, 01:49:48 by EMdevices »
Akula0083 was supposedly lighting the same lamp setup without the T coil or a ground in previous videos.
So whats with the T coil and ground....one step backwards? That "ground" wire is always highly suspect. If it worked without it in prior video's why re-introduce it into his latest video?
Can someone explain what Wesley or Akula is trying to say? I can't make it out.
I'll give another look to see if any of it makes sense.
Edit Ok he's talking about  two resonant circuits at least three control loops and "K" capture of electrons. This could explain the need for a ground. Akula's communication skills could be improved, he seems to have a nice lab and is good at electronic circuitry.
Here is the video that needs a translation:  http://www.youtube.com/watch?v=xdLlnHptTOk
« Last Edit: 2013-10-04, 15:12:43 by ION »
Wesley translates another Vid
http://www.youtube.com/watch?v=eUxFuW3JYdY
Here we go again. The thing is all taped up and we can't see.
One test would be to pull the wire off the pipe. If the lights go out then this holds some merit. If the lights stay on then there are batteries. Did he really turn it on with a 9vbat? No prestidigitation?
A few comments on video.
1) the ground wire is actually 2 wires. This could be a interlock loop that will interrupt operation if the wires are separated, proving to an audience that disconnecting the "ground wire" will cause the device will stop.
2) He seems to be connecting one of the wires to the back of the faucet before connecting the other to the front joint. Is there an insulated sleeve at the back of the faucet for the "juice". An unseen hot wire glued to the back of the pipe? An accomplice possibly energizes this wire from an unseen position at the appropriate time. The pipe is the cold return.
3) The lamps only run for about 6:18 starting at 1:20. Is this not possible with today's new LiPo batteries? how many watts are the lamps?
4) He should show the pair of wires twisted together before attachment and also show what happens when the wire is repeatedly touched to different sections of the ground pipe. Always a bit suspicious of grounds.
Are people compensated for the number of hits a youtube video gets once it qualifies for advertising?
Yep. Google Adsense just paid $144.00 to me for doing nothing.
He could be using a two-wire trick here but i think its more likely lithium battery powered.
FE video faking is a lucrative way of earning from Youtube 'hits', especially when enhanced by us 'eyeballers' repeatedly running the videos through looking for signs of skulduggery.
« Last Edit: 2013-10-11, 11:14:29 by Hoppy »
From Hoppy:
I usually download the video and frame step the images, so I don't give them the hits.
Lithium batteries, flatpacks from discarded cellphones, are easily sandwiched under the baseboard.
Looks like the "cargo cult" of TK  "look alike" devices are ubiquitous.
A clear plexiglass base and getting rid of all that plastic wrap would be a step towards credulity.
From Hoppy:
Yes, this is the sensible approach.
Its of note that all the similar devices being shown use filament lamps which present a resistive load well suited as a load to Royer type oscillators of the type we see on many of the circuit schematics. I have conducted a few experiments using a mosfet based Royer oscillator (Mazzilli variant) driving a Lasersaber Super Joule Ringer 3.0 style transformer. However, my version has bifilar primary winding of 80 turns, 1.5mm stranded electrical wire wound bifilar and the secondary winding of 600 turns of 0.32 swg ECW. The primary is wound on a 38mm plastic domestic waste pipe with the secondary wound as one layer on a cardboard tube that fits snugly into the plastic tube with virtually no air gap. The end of one 40-turn primary strand is connected to the start of the second 40-turn strand and this connection forms the centre tap for the oscillator output coil. The start and finish wires are terminated with four good quality 0.22uF polyprop caps in parallel to give a sinusoidal 26KHz, 132V pk-pk output waveform scoped across the caps. The load is a 230V, 60W bulb connected directly across the secondary winding. The performance of this setup is impressive and by far the most efficient and simple to construct inverter that I have built. Unlike Lasersaber, I use an air core with a larger diameter coil former, eliminating the need for ferrite rods or stacked toroidal cores.
My reason for describing this setup is I think Kapanadze and Akula may have built a very similar setup but on a much bigger scale using a thicker primary and secondary winding to power a heavier load. The Kapanadze multi-turn secondary winding maybe wound on top of an inner primary winding. The thick copper coil winding around the secondary maybe unnecessary to light the lamps but could be enhancing output by inducing spark-gap induced pulses into the secondary winding, or just to confuse measuring instruments! Yes, a lot of surmising, based on my belief that he has a concealed low voltage power supply to drive the oscillator. However, my approach to understand how Kapanadze / Akula 'did it' is to first get a lamp to light brightly using a look-alike coil arrangement and then work to get it self-running.  :P
Wesley translates Vid #4
https://www.youtube.com/watch?v=ScXhI2hQawc
Thank you for taking the time to do this Wesley
« Last Edit: 2013-11-02, 23:10:25 by ramset »
Wesley and T1000 examining the principle of the device
http://www.youtube.com/watch?v=G9KEBOC4coQ
thx
Wesley says its staring us in the face.............
"Quote"
what I suggest the most:
1 go to my first  post that was  saying about Mr King and Akula
2 read it.
3 go to my video http://www.youtube.com/watch?v=SS_CsCX2SHc&lch=email&lc=kVDLz5so32DjVj9GgaRRTtJ1gdPdgE9TW-QVTVoCm9U&feature=em-comment_received
9:27
4. go to
http://www.youtube.com/watch?v=px14OF1D3EA
4:43
5.than go to Akula schematic
you have the same mechanism but made  from electronic components.
6. forget about  everything for the moment and go to my video  again
and  build it  as you see it.
Remember in  first Akula device there was no donut on the top
Remember in TK there was mostly  no donut
but in tent   it was..............
I did my part you do yours
can you?
 Just take it for granted it is it
I already 'm being accused of stilling Akuas by some members of Russian movement.
If I would ever say anything ..........
at best of my believe we got TK by the balls...
Now I see all chain:
TK..SR..  Lithuania experiment( Wesley, Aidas, Arunas Gintas)...Tiger...Akula....
Wesley from  2012
http://www.youtube.com/watch?v=Mn8TLBsR3r0
A word of caution guys,Akula  has never shown
a device that can clearly show the absence of hidden wires,or batteries.
He seems to have copied Westleys yoke device,which was never shown to be overunity,and a health hazard.
Over here SM can not lie ,would not lie and wants you to make hes tpu,over there its,can't you see its
a Tesla invention,if it has coils, arcs,and a ground and farts its a Tesla invention.A lot of members
 believe Tesla is a god and hero worship him.In particular the Russian members regard Tesla as a god,like a person that
hero worships superman,they think they can be superman by putting on a cape or making a fraud as in the case of Tesla.
All this massive confusion makes analyzing Tariels device difficult as you can not be objective hero worshiping.
Cp2012
I have to disagree with just one point you made, I agree with the rest of what you said but only to some degree.
Steve Mark has no interest in anyone building a TPU and left the scene in 1997 or thereabouts.
If he sincerely had interest in desiring anyone to replicate the device it surely would have been done by now.
Just about anyone with a moderate electronics or technician level expertise can fake a TPU demonstration for a brief youtube video. This is easily done. You are not alone in having done this.
But ability of fakery is not necessarily proof of fakery.
I have seen you on the OU forum calling people over here old and gullible. Some of us may be old, but still sharp as a tack and having the benefit  of thousands of hours of bench time, which brings a certain wisdom and maybe not so gullible as you would think.
Your points have been well made over and over.  Now lets get on with "the work".
When in a foreign land, good manners are also appropriate.
« Last Edit: 2013-11-10, 16:07:22 by ION »
From Wesley
here is something that might help
http://www.youtube.com/watch?v=lEa_B-zYObc
http://www.youtube.com/watch?v=0_fTQvEnhvQ
Wesley
thx
Wesley Tanslates [and comments]
Akula Number 11
http://www.youtube.com/watch?v=v9Nl6c7ZtS8&feature=youtu.be
thx
A happy new year vid from AKULA [via Wesley]
http://www.youtube.com/watch?v=UPJPPZLhsqY&feature=youtu.be
thx
PS
I do like Wesley's little Coleman Gelespi comment at the end    ^-^
« Last Edit: 2013-12-19, 03:26:09 by Chet K »
Wesley News: Vasmus Free Energy Generator
 http://youtu.be/HUsdlnjfh9Y
New guy in FE movement
it is going to take about 20 minutes before link will be accesible
Wesley News;part #2 Vasmus Free Energy Device
http://youtu.be/cbKfS02_b5E
NOT READY YET to watch
 give it about 30 minutes to show up
Wesley
« Last Edit: 2013-12-21, 22:16:08 by Chet K »
I Believe there will be more!!
 O0
There is a wall cord in the background.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 19:52:19
