Wow, that is interesting.
I won't bother to show how many errors are in the "Quote", and I don't mean copying errors. I went to the link given, and while the measured effects may be "Proven", that is also a description of "Theory" on the formation of these effects. With a little "real-life" experimentation, the initial theory can easily be disproved. This is not to say that the math isn't correct for the effects, but to say that the initial "Cause" or "Form" of energy IS NOT PROVEN.
To "Blindly" accept something, without actually checking it out for yourself, can be very revealing as to what one believes. The only problem that this causes is if any part of the "Initial" parameters is incorrect, then you really are assuming that because the "Math" happens to work correctly, you must know what is happening. Even Einstien admitted that error, so this has nothing to do with knowledge of a subject, but with lack of open mindedness to consider the possibilities.
A stupid story, from my early years. Two people, one a sheep farmer, and one a scientist, drove by a field with a lot of freshly shorn sheep. The farmer said, "Those sheep are freshly shorn." The scientist said, "It looks that way, from this side."
In the above situation, who is correct? The answer is "Both"! The farmer, with his experience, can be 100% sure that he knows what has happened, as this is his area of "Expertise". The scientist knows that "Effects" are inconclusive without ALL the data, or what you see and measure are of NO VALUE. There is NO ONE who can say for sure that both sides of those sheep were shorn, without more data, even though the farmer could exactly figure it out, and the scientist could make assumptions from that.
Difficult point to get across, but I hope this gives an idea of what I think when people talk of absolutes, when the concept is still in the theory stage, especially when the "Data" being measured cannot be defined by itself. Can anyone actually state they know which is "Cause" and which is "Effect"? Anyone can calculate correct values, but what figures are you plugging in? It ends up being back to the old situation of assuming that "If the math works, I am right..." Tell that to Einstein. Interesting field. (Pun Intended...)
Here's a stupid question, as I am not sure this is "On-topic" or not. (I wish I knew...) The propagation of "Energy" on the "Extra" coil in a Tesla MT continues after the coils of wire. (Proven? Recorded data is available...) What form of energy is this, and could this be related to "Displacement Current". I am not talking 'RE" and Tesla made it clear as to the difference. I have not heard/Read of the "Possibility" of a Magnetic field collapsing into a single wire and still maintaining the same rate of dV/dt that was in the coil. IF that is true, what type of energy flow are we talking, as it certainly cannot be standard electron drift, especially as it's measured at pi/2*c speed? Lots of questions. No definitive answers that I can even test. What do you think? (That is addressed to all, if I may.) The more I test the "Fringe" areas, the less I seem to know... There certainly seems to be an energy flow that is "non-magnetic" in nature that still follows conductors, or am I missing the boat here? (I realize that many don't even recognize the "Extra" coil's function. If that's the case, just ignore me as an "unknowing" tinkerer. From original descriptions this flow, in extreme circumstances, was seen on the outside of the coil. Seems to be acceptable to consider that this "Current" could be related to "Displacement Current" in some way. Seeing that I have never, personally, operated an MT at this power level, I cannot verify that observation, so this is very much in the "Theory" area for me.)
