tinman, I've had a TENMA 72-7290 universal combo on my home bench for several years. It is an excellent workhorse. The counter, function generator and power supply all have a common AC power transformer each fed from different transformer secondaries. The DMM section has a separate wall-wart. Each section is completely stand-alone except for the common power transformer. Looking at your pic I would say that device is a copy of my TENMA  The only problem I've had was a blown power transistor on the variable PS output and that was my fault. It is at the center of my bench for good reason. I suggest you look at the specs for each section of the device to make sure all sections will fit you needs.
