Come on Bro! Time to move past the "electron hurdle"...
I don't think so,
There are some rules in QT/QED that explain the phenomena of secondary emission.
This is for example the pauli exclusion principle.
It states that no two identical fermions may occupy the same quantum state simultaneously.
Since electrons are fermions this rule boils down to the simple rule that no two electrons may exist at the same place at the same time.
So if one fires one electron at another one, the second one has to move because they cannot exist in the same place.
Try doing that with just one photon...
This is a good explenation how momentum is being transferred between particles.
It's like the guy that shoots a billiard ball aimed at the triangle formation and they all move because they cant exist at the same place.(kinetic)
You could compare the movement of the other balls with secondary emission.
Note *This is extremly Stiff as it has NO place for compression, you cannot squeeze more electrons into a box that is already full.(not exactly but it willdo in kid's classroom)
Now things can become tricky because bosons are said to be the real force carriers.
They transfer the interaction between particles.(radiation)
You mentioned particulary Photons.
They are the force carriers of an electromagnetic field correct.
Now we know from both the photovoltaic and the photoelectric effects that they are able to move electrons.
But Note *This is extremly flexible as this situation allowes compression.
You can squeeze more and more photons into a box...(laser etc.) Again.
So if i look at the gray tube and i do not like to use the word "probably" then i would say it runs on secondary emmision.
Electrons, not Photons.
Why? because you got to have one hell of alot of photons to do the same with just one electron...
Some of my test have shown that the spark accellerates electrons to a point that is far beyond the speed they could ever get in and around wire, where are the photons? there is some RF but it doesn't beat it, and the magnetic field confirms..Remember? i know you did that experiment,i have a good memory..I even remember you said you will never look at it this way again.....
If they do reach that speed close to a wire,it would evaporate...(sounds familiar?)
So these ultra high speed electrons hit the center anode which is filled with free electrons and they are launched like billiard balls towards the recieving grids.
Same principle is at work in Philco Pharnswort's Multipactor.
The impact of the secondary electrons change the charge of the recieving grids.
In this situation nature has to restore balance because there is a potential diffrence between the grids and the environment.
An unconventional flow of energy will result.
The grid capacitance only plays a part when AC/RF is used not when one uses high voltage DC.
So this is my oppinion about the Gray tube and what it does.
If you think you got better ways i suggest you try them.
You can't just poke others to try your ways.. they got ideas of their own.
If you think you can make it work then do so....at least that is what i am trying and i like to test my own things.
Marco.
Ps I will use noble gas in the PAGD and Plasmatron tubes,but not in the Gray tube.
It would be best if we manage to generate the effect in open air since evacuating tubes makes it harder.
And both paradoxes are explaind by Heisenberg's uncertainty principle.
