2025-03-31, 17:05:46
Author Topic: HV Bifilar Coil  (Read 9564 times)
Anyone have any experience using Bifilar coils at high voltage?
I am trying to test a Bifilar coil in place of a regular Solenoid coil but the Bifilar wont perform any work other than pumping out huge amounts of ozone.
I think that i am within the voltage rating of the c-200 magnet wire.. but i do know there is a greater difference of voltage between windings on the Bifilar.
Im considering trying it under an oil bath to see if it fixes it.. anyone ever have this problem?
Thanks...
PS; I have never seen good reference material on Bifilar coil design.. anyone know of a source??
He he... I know what you are about to say... but its one of those things that i wont be happy till i know what i does in my particular application...
Dont forget Tesla coil for electromagnets is bifilar.. there may be more there than meets the eye..
I have two coils driven by dc pulse
coil A : 4000ft 28 awg c-200 245ohm
coil B : 4000ft total 28 awg c-200 ( two wires of 2000ft each in bifilar )
at lower voltage coil B is stronger, as the voltage increases the power of A increases and B decreases - but coil B puts out more and more ozone
so im wondering if it is shorting internally, if there is some sort of capacitive action going on, or ? that is consuming power in coil B
Coil B is good to about 2kv then it starts to decline
coil A will punch up to 15kv with no problem
Just wound a second bifilar coil and it also dumps a huge amount of ozone.
This has to be due to the voltage difference between adjacent conductors in the bifilar.
Im going to try making a form around one coil and casting it under a vacuum and see if it fixes it.
It is kind of interesting though..
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 17:05:46
