2025-03-31, 19:14:16
Author Topic: Oscilloscope-test-ready board number 1  (Read 3376 times)
This is the first board prepared for shipment outside Hong Kong.
The COP was -12.68.
COP is defined as the Coefficient of Performance.  It is the ratio of the average Output Power over the Input Power.  This ratio, by conventional wisdom, is positive.  However, if either the Average Input Power or the Average Output Power were negative, this ratio can be negative.
The negative sign has very special significance.  It implies a feedback circuit - more energy comes back to source than supplied by the source.  By itself, lead-out energy is confirmed.
The negative sign came from INPUT.
« Last Edit: 2013-01-20, 00:15:44 by ltseung888 »
The COP was -12.68.
This deserves some explanation, Lawrence. A COP is a ratio.
*** see comments above.
« Last Edit: 2013-01-20, 00:16:43 by ltseung888 »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 19:14:16
