Exactly. That's why when the output resistance matches the input impedance, there is no more resonance
Incorrect!
Ok dude, let me explain this to you step by step so you can comprehend.
Resonance is when the circuit is left purely resistive, so in a series RLC circuit, XL = -Xc and they cancel out, leaving only resistance.
If the resistance is large compared to XL, the circuit has a low quality factor, so its wide bandwidth (3 dB) A square wave, which possesses lots of harmonics will pass through pretty unchanged. If it were a narrow filter, yes it would be only a sine wave at the output, because the rest of the harmonics got filtered out.
So why do we want to negate the inductive reactance in the induction cooker by making it resonant?
Answer: to drive as much current and power through the circuit.
I = V/Z, so we want Z as small as possible. That occurs when its RESONANT!
Comprende?
As far as your accomplishments, if they are true, congratulations, But learn to be humble towards others less fortunate, and beware that others on this forum, including me have achieved more then you professionally. And for your information I built my first xtal radio set at 7 years of age!
I'm known for a real time software in matter of radio signals processing and decoding
Ok here is a simple test, what does QAM mean, and draw me a 10x10 signal constellation, also what does FIR mean in filter theory? Don't cheat and look them up on the internet. You have 5 minutes to answer.
