Thanks EM for the diagrams.
Certainly in the Hendershot motor there was a magnet, he mentions that they were originally not sure if the magnet would eventually lose it's magnetic field, as if the energy maybe used up from the magnets field.
One interesting thing about the motor is that it maintained the same RPM under varying loads, and this rpm was set by the coils, this is interesting as it probably means the generator produces a set amount of power by varying either the voltage or current, if it's the voltage that varies then i would not like to run the device without a load, you would reach a point where a lightning bolt would be unleashed, which sounds like what may have happened to Lester at the patent office. This also ties in with SM about it feeding itself, therefore i think we can assume this constant set RPM of the motor is the result of automatically feeding energy back into the system, this i think must have been done with coils.
So it would appear we are creating an environment where we input energy and get more back, even if it's only a little extra back.
I am also interested in the transformer with the middle leg removed, this could be interesting as i don't know of anyone having ever tried this, we have a flux magnetometer which uses a toroidal core and then a winding wound over the outside diameter of the toroidal core, this seems similar but with the coil aligned and contained inside the core instead. I have almost built one of these using a small LT77 audio output transformer for some testing, very annoying all new transformers seem to have welded laminates which makes them impossible to disassemble, i may need to use eBay to get an old frame output transformer for larger tests.
