I found the motor on German-ebay. Appears to be a fan-motor from a microwave oven. For a couple of Euros... But I haven't found the 240V AC generator yet... unless it is actually the same fan-motor driven as an AC generator... Would that work? http://peswiki.com/index.php/Directory:Motor-Generator_Self-Looped_with_Usable_Energy_Left_Over
DC.
Very useful, thanks DC. From that article: Karl Palsness' Theory
I had a chat yesterday with Karl Palsness, who is an expert on Tesla technology. He has also heard of several cases like this, all independent from one another.
"I know exactly what you're talking about. I've done a lot of work in that area. That's amazing. I've heard this from so many people now, that this works.
"From what has been observed, you're playing with the phasing angles between the motor and the generator, and when the phasing angles are out of phase, you're getting into what is called 'power factor'. When you get the power factor right, the current and voltage are out of phase, and when you get them meshed up enough, it actually self-runs and produces excess energy.
"This theory is based on magnetic flux. Permanent magnets or electromagnets such as in a generator or a motor, under certain conditions, give overunity (OU) behavior. But there's more to it than that, from what I've seen myself in overunity devices. It is all about geometry of the system. How and where a permanent magnet gets it's energy, is still a very big mystery to science. Excess energy can appear in electromagnets, as well.
"I've seen this effect on generators. When you have a generator that's turning too big of a load, and you have big enough breakers to handle the current, the currents go way up. Imagine if you have 500 Volts at 1 Amp; you have 500 Watts. Or you can have 500 Amps with one Volt; and you have 500 Watts. So when you get huge amps and low voltages in between the phasing angles, the current and magnetic fields are so collapsing and rising, and the phase angles are 'wrong', I believe that the magnetic field is coupling with, I'd have to say the word: 'The Vacuum'. In other words, it's coupling with an unknown -- whatever makes the permanent magnet work. We truly don't understand the science of that. There are a lot of theories, but no proof yet. Permanent magnets are still one of those unknowns, as to why it does what it does. And that's the same thing with electromagnets. There are a lot of unknowns.
"So when we kept playing with the power factors and phase angles, I believe there is overunity. I've seen it so many times now, with so many different people, that if I had the money, I would go out and buy the parts to do the testing in this area myself.
"Remember that guy [...confidential / U.S....]. He's doing the same thing. He has a small motor turning a big generator, and it's out of phase, and the power factor is out. There's a guy in South Africa that's doing the same thing. He's got a motor connected to a bigger generator, and it's doing the same thing. There's a guy in South America, (the blind guy from welding) (Force Multiplier System). He had a motor turning a generator, via shaky gear connection. That's doing the same thing.
"There are a lot of people claiming this. It's getting to the point that there are so many people claiming it, that are unrelated to one another, that I'd have to say that it holds a lot of potential.
"And I have a theory behind it. I actually wrote a whole chapter on that in my book about the science of how to do it in a much more elegant method than they are doing it now, based on what they are doing right now. The problem is, I don't have the funds to do it. That book is my research journal, and I don't have plans at the current time on publishing it – my notes as you work every day. I've got a lot of time and money into that. If what they are doing indeed works, I believe it can take it to the next level and make it a much better product and bring it to market. At the current time, I don't want to give that idea out, as it is still just an unproven theory of a way that might work. I'd like to bring it to fruition in the future if I can prove it works." [/b]
« Last Edit: 2012-11-15, 17:38:11 by PhysicsProf »
