2025-07-18, 08:04:48
Pages: 1 [2] 3 4
Author Topic: MrClean's claimed "self-looping" device with load, and no +Battery connection  (Read 75571 times)
We've had the diagram for a while Peter.
The question I have is; what is providing the 9V source?
http://img802.imageshack.us/img802/1874/imagedmb.jpg
Well I can't make head or tail of this diagram, which I understand is a truer depiction of the actual layout than the neat schematic. The PWM appears to be providing parallel outputs - what's that all about.
I assumed the 9V was a battery powering the PWM cct, and that the whole thing was kick-started by an additional 12v source, but no transistors are depicted at all (if the Amp blocks refer to ammeters!).
Oh sorry i had not seen the drive circuit mentioned before.
Quote from him at energetic
ive had to put it down for a bit, going insane trying to do it again
Does this mean it's stopped working?
It's simple for the most part.
See the annotated diagram.
Does anyone know what he might be doing with that "Parallel free wire"?
I'm familiar with the pulser schematic.
 Question is: what happens at reduced voltage and current drive?
 I surmise that the pulser circuit will function at very low current / voltage from the residual charge in the 1 farad capacitor, which can act like a battery due to dielectric absorption.
 This is the same effect found in electret's but capable of a little higher current, possibly enough to run the oscillator in a quenched mode.
After all the dipoles in the 1 Farad capacitor have been permanently reset, the effect will disappear.
« Last Edit: 2012-11-13, 00:58:56 by ION »
Quote from him at energeticDoes this mean it's stopped working?
The diagram is on the first page.
I think he means he can't replicate it with another setup. He has stated that on the other forums.
« Last Edit: 2012-11-11, 18:00:18 by poynt99 »
The way I see it, Kurt's 9V source is either a 9V battery, or he is regulating the 12V input from the 12V battery down to 9V.
By "isolated" I suspect he means that the 9V supply is not connected to the transistor collectors.
Here once again is how the PWM circuit is driving the coils.
Here is a circuit update from verpies.
I think by 'isolated' he either just means it's a battery and not a mains PSU, or the 9V battery only powers the PWM. He then sets the cct resonating with the 12V car battery and then disconnects it.
The video is so messy it's impossible to see what he has connected to where - there's wires and crap everywhere.
I'm getting a little confused here. OK, am I right in thinking that the neat schematic is the whole PWM cct, simply with the LC part of Mr Clean's setup tagged onto it?
Well he did mention Don Smith.
Don clearly stated in one of his videos that he could quiet easily remove the power supply running his device and feed it from a wire that was trimmed to the correct length, which seems to be what is being tried here?
Don's device created a large field in the area when at resonance and could be intercepted by a single wire of the correct length, this was Don's explanation of how to close the loop.
The extra energy was sucked in during the build up and collapse of this large field.Something like that anyway  C.C
EDIT Farah
Yes the 555 & 393 is the cybernetics circuit, it seems likely the 9V isolated is a pp3 battery providing power to the 555 & 393 and hence the device is still being independently powered by a battery, how that powers the coil i don't know, this what the others Poynt and others are trying to figure out.
« Last Edit: 2012-11-11, 21:16:13 by Peterae »
So doesn't he initially power the coils with the 12v car battery which charges that 1 Farad capacitor? He then disconnects the 12v battery and the cct goes into oscillation as the 1 Farad cap starts to discharge. Then oscillations that would normally dampen down and eventually cease altogether are somehow kept topped up by the PWM.  Probably way off the mark, but it seems to me that if the cap/coil arrangements are set oscillating, then the PWM must be providing +ve feedback to maintain those oscillations.
Doesn't the fact that the voltage slowly rises simply mean that the PWM is providing a slightly greater signal than is required to maintain the initial oscillation voltage?
Poynt99,
I'm confused.  How come verpie's diagram shows 2 transistors?    I don't see any transistors in Kurt's hand drawn diagram (which Farrah linked), I just see the PWM & 393 block connected directly to the central coil in parallel with the capacitor.    No transistors there!    As such,  the coil and capacitor tank circuit are excited and ring out from the PWM signal, so why is this invention claimed to be "self running"?
... What interesting is there was an accumulation in energy measured by the meter.  There maybe an amplification factor by circulating current in the LC.
There is never amplification of energy by a LC circuit, but only accumulation as you said it. Consequenty if you use permanently the energy, for example to light LEDs, it doesn't make a difference there is a LC circuit or not. At most a LC circuit can be used for impedance matching between load and source but this works also with energy conservation.
Poynt99,
That got me too EM, but I think those transistors are just part of the PWM output circuitry.  The PWM (powered by a small 9v battery) would be used to modulate the auxillary 12 volt DC supply which feeds the LC configuration.  I now think that this is also what he means by isolated power supply, in that the 9v powering the pulsing part of the PWM, is independent of the power supply (12v car battery) that supplies the LC configuration.
Poynt99,
Basically, place verpies' circuit drawing (excluding the bi-toroid) inside the block labeled "PWM & 393". It would be nice if verpies updated his circuit to show the entire setup as a whole.
I based my theory on sling shot effect proposed earlier.  You based yours on the conservation of energy.  Right now we're talking about the anomaly of the circuit.
I based my theory on sling shot effect proposed earlier.  ...
A new theory is needed only when new facts are observed, duplicated and certified.
If you prefer accumulation, that's fine with me.  What we're trying to determine is what causing the accumulation:  Is it our input alone or could something else entering the system.  For example, an antenna can have accumulation from radio waves.  How then can we amplify this effect?  I don't mean amplification as energy multiply from nothing.
Below is an updated schematic diagram of Mr. Clean's Device according to his posts at this thread.
It is still a mystery where the +9V supply rail comes from and where the red question marks (? ? ?) go to.
Also I am not sure of the R5 value and the dot symbolizing the W3 winding direction.
I would appreciate if some persistent person could ferret out this info.
Thanks verpies, nice work.
The bottom (? ? ?) must go to the circuit ground. If the 9V supply is derived from the 12V supply (and I suspect it is), then the upper (? ? ?) would go to the 9V regulator input in the PWM block. Kurt does show both going to that block.
Hopefully Kurt will be a little more forthcoming with some answers, then we may know for certain if what I am saying is correct.
The elephant in the room will soon be noticed
For once was he a big spender
But with so much now squandered
He spends his Joules with thrift
And is rejuvenated from within
The panther is starved and fed again
Lunges forward, now and then
Has only a dim light  to tell his tale
He finds his path, obscured, though it seems
But not to one who moves quickly
And not a mere flick of the switch!
The elephant must be fed for one hour
Then, for the amusement of those who watch, and wait
He will repeat his trick
In the three ring circus
« Last Edit: 2012-11-13, 04:06:55 by ION »
This points are answered from decades. For the accumulation, see electronics courses, according to the schematic the input alone is not enough, and ask those who have an experience in radio, they will tell you, from a usable energy viewpoint, the negligible order of magnitude of the ambient field that you can be expecting for, except when you are very near a transmitter antenna.
There now appears to be two 12 Volt sources in Verpies latest schematic - surely this is not correct!
Here is my understanding of the circuit.
He is using a 9 Volt battery for the oscillator circuit.
The battery can be seen in this video: http://www.youtube.com/watch?v=gHnJYl6q96w&feature=relmfu
[EDIT] I have updated my circuit drawing according to the hand drawing from Mr. Clean.
GL.
« Last Edit: 2012-11-13, 13:14:36 by Groundloop »
Pages: 1 [2] 3 4
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-07-18, 08:04:48
