Ok, slowly getting there, using the groundplane pcb with the components shortly soldered to each other and as storage cap a 20cm long open ended piece of RG-316 coax cable. And also very important...... remove the bandwidth limitation from the scope  Closing in to the 1ns pulse width, see screenshot. Still using the normal probe, when using a piece of 50 Ohm coax directly to the a scope port set to 50 Ohm shows an even smaller pulse, but the signal is to strong as in this 50 Ohm setting, the scope can only handle max. 5V RMS, so i need an attenuator. Regards Itsu
« Last Edit: 2014-08-26, 10:28:49 by Itsu »
