2025-07-26, 08:51:25
Pages: 1 2 [3]
Author Topic: Locked reference material - no comments  (Read 49263 times)
Stored data for Board 80 for the Hong Kong Government.
Summary data for Board 80
Digital Oscilloscope UNI-T UTD4104C
4-CH DSO under USD1000
Mr. Zhou getting ready to promote lead-out energy.
The theoretical model with "hidden pulsing source".
EM Noise or electrosmog as the source of lead-out energy?
See reply 1037 of the "Is Joule Thief overunity" thread at overunity.com.  Void also produced cross 0 ref line waveforms.
The two presentation files to be used in the Hong Kong Senior Centers.
The ones with most time are the retirees.
They can play with the Zhou Boards.  Just treat it as a project to pass time if not successful.  If successful.....
God Bless
The Chan and Yuen Wheels are now available in Tai Po for those interested to validate and improve.
The latest presentation file is in:
http://www.overunityresearch.com/index.php?topic=1516.msg24854#msg24854
titled: Presentation on Nov 2014.pdf
God Bless
Open the Christmas Gift
Now is Boxing day.  Time to open the Christmas Gifts.
The most important element of the Gift is confirmation of Lead-out or Bring-in Energy Theory.  From the theoretical point of view, there are two calculations to consider.
1.   When a horizontal push is applied to a pendulum, the tension in the string will increase.  The vertical component of the tension in the string will lead-out gravitational energy.  The pushed pendulum will have this extra lead-out or bring-in energy.  Thus a lead-out or bring-in energy device will not violate the Law of Conservation of Energy.
2.   When a Milkovic two stage oscillator lifts the weight W1, gravitational energy is again lead-out or brought-in.  The swinging pendulum or unbalanced wheel produces a “jumping” effect – the force exerted on the pendulum side varied with the change in centrifugal force.  When this centrifugal force is highest (tangential velocity highest), the clockwise moment will be higher and the Weight W1 is lifted.  Gravitational Energy is brought-in.  When the centrifugal force is low, the anti-clockwise moment of the Weight W1 returns the lever system to the initial condition.  The energy required to maintain the swinging motion or unbalanced wheel rotation can be much less than that used to lift the Weight W1.
Thus gravitational energy can be lead-out or brought-in via oscillations or vibrations.  An important element is providing the pulse at the correct time. That is similar to pushing a swing at the right time.  The more scientific term is resonance.
Once the lead-out energy theory is thoroughly understood, it can be applied to magnetic, electromagnetic or flux change systems.  There is NO violation of the Law of Conservation of Energy.
The most powerful source is likely to be the electron motion or electron cloud energy.  Chemical Energy is just a subset of such energy.  When we can lead-out such energy, we do not need to pollute the environment.
Many lead-out energy devices are actually built.  Most inventors do not use the lead-out energy to explain their inventions.  They tried to fight the road block of “violating the Law of Conservation of Energy”.  They failed to get the support and credit they deserved.  The Christmas Gift will help them to remove the road block.  Amen.
refer to http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg428719/#msg428719 for details.
Presentation file used on Jan 11, 2015.
Added presentation file used on Feb 8, 2015.
« Last Edit: 2015-02-08, 00:07:53 by ltseung888 »
http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg443678/#msg443678
The Experiment to confirm lead-out energy - Tsinghua University Energy Multiplier.
Pages: 1 2 [3]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-07-26, 08:51:25
