It's an interesting motor professor.
I see the magnetic field crossed the vertical side/plane of the loop......is this what makes the motor possible? hm....
In part yes -- there are forces which result in torques on the left (force away from you in the diagram, hence (x), like the feathers of an arrow going AWAY from you ) and on the right (force towards you in the diagram, hence (.) ). There are also forces on the wires at the bottom where the field is stronger, tending to cause rotation in the same sense -- convention calls this -z rotation (right-hand fingers in direction of the spin, thumb points downward, hence -z axis). FYI, pls see http://en.wikipedia.org/wiki/Homopolar_motor where the diagram also comes from  OK -- please pull your right-hand, apply the right-hand-rule (RHR) and check that the forces shown on the diagram are correct! Direction of the force found from I x B, that is, fingers in direction of current I, rotate rt-hand-fingers to direction of magnetic field line B, then force F is in direction of thumb. Try it! (PS -- I find the diagram is correct.) Note that instead of rotating the WIRE as shown above, we can hold the wire fixed and rotate the magnet -- see attached. Diagram gives the idea -- note battery "upside down" from photo. Obviously we can change the orientations of the magnet and the battery. We can also place the magnetic field EXTERNAL to the system; still works.
