2024-11-27, 22:46:02
Pages: 1 ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29
Author Topic: The Rosemary Ainslie Circuit  (Read 477227 times)
Magluvin:
What happened to the oscillation? That "alternating current" through the circuit during oscillation? That alternating current would have to flow through one led at a time depending on the phase. This one lights, then that one lights with each phase of operation. No?
We have two rails of LED's.  The one takes current from the battery supply.  The other takes current from CEMF.  TWO OPTIONAL PATHS.  Now.  We've got an oscillation.  Voltage moves equally - above and below zero.  Therefore, correspondingly, the current flows above and below zero in each oscillation.  Therefore - one would expect the current to move through either one or other of those rails - depending on that polarity.  NOW.  NOTA BENE.  There is NO CORRUPTION OF THAT OSCILLATING WAVEFORM - ON EITHER SIDE OF THOSE LED's.  YET.  Only ONE RAIL STAYS LIT.  And the other doesn't even turn on.
What the hey??!!!   :o
A casse-tĂȘte = a head buster!
Better your head than your balls.
Yes, the Q2 Group is configured as
Common Gate or Grounded Gate.
When the Input to that circuit from
the Signal Generator goes sufficiently
negative the Q2 MOSFETs will be biased
ON and the Signal Generator will furnish
current (series aiding) with the batteries.
This configuration is low impedance input
so the Signal Generator current will be
equal to the MOSFET Drain current.
Signal Generators typically have considerable
internal resistance (50 to 600 Ohms) which
must also be accounted for.
When the Signal Generator output signal
goes sufficiently Positive it will cause Q1
(Common Source or Grounded Source)
to turn ON.  In this case the Signal Generator
will be isolated from the circuit current
(Q2 Group is cutoff) and will work exclusively
into the High Impedance Gate Capacitance of
Q1.
Q1 current at this time will be significantly
greater than Q2 current was during its
conduction interval..
With MOSFETs, as Poynt indicated previously,
oscillations are always a possibility.
Very interesting discussion though.  Reads like
a good book with a little bit of everything -
suspense, drama, good guys, bad guys,
big crowd, too much to drink and a happy ending!
OOps, forgot the most important character!  The
Damsel in distress.  What kind of a story would it
be without her?
Hi all,
As some of you here know I am a moderator at two forums http://convivea.com/forums/index.php  and www.hhoforums.com  and know what someones responsibility is and your reputation effects your decisions on the sites "Terms of Service" (TOS) is and how members and guests view your actions including postings.
I normally when becoming a member of any web site view the TOS and sometimes even copy what ever parts that may effect what I do there, so one of these sites was "Over Unity" .com that I copied references to conduct in July of 2008.
QUOTE (#6) Specific Use -
You agree, through your use of this forum, that you will not  post any material which is false, defamatory, inaccurate, abusive, vulgar, hateful, harassing, obscene, profane, sexually oriented, threatening, invasive of a person's privacy, adult material, or otherwise in violation of any International or United States Federal law. You also agree not to post any copyrighted material unless you own the copyright or you have written consent from the owner of the copyrighted material. Spam, flooding, advertisements, chain letters, pyramid schemes, and solicitations are also forbidden on this forum.
The Terms of Service (TOS) at "Over Unity" .com was changed shortly there after in September 2008 ..... to read
You further agree not to use the website to send or post any message or material that is unlawful, harassing, defamatory, abusive, indecent, threatening, harmful, vulgar, obscene, sexually orientated, racially offensive, profane, pornographic or violates any applicable law and you hereby indemnify the Website Owner against any loss, liability, damage or expense of whatever nature which the Website Owner or any third party may suffer which is caused by or attributable to, whether directly or indirectly, your use of the website to send or post any such message or material.
As you can see the you will not post any material which is false or inaccurate is missing.
This is a very incompetent thing not to have in a forum and by it's removal has opened the door for any fraudulent device, construction details or bogus claims on anything. It also gives a "License" for members to provide information on results or documentation to be  wrong and misleading. This gives the forum administration no recourse to do anything against that member for what was posted or replied to in a thread if portrayed incorrect.
The other concern is that reading closely at the TOS at "Over Unity" .com there maybe some Data Mining going on there, with unique restrictions on posting, edits or image inserts and terms around them ..... but that's something else all together.
http://www.overunity.com/5554/terms-and-conditions/
So ..... Rosemary is well within her right to "LIE" through her teeth there, but of course that's assuming she has teeth some say she has fangs.
Fuzzy
*edit* repaired  -  www.hhoforums.com (link)
« Last Edit: 2012-03-15, 21:53:42 by FuzzyTomCat »
Quote from: FuzzyTomCat
There may be "legal" reasons for the modification.
The "false or inaccurate" hurdle may have been
unnecessary and/or impossible.  To determine if
any matter is false or inaccurate may not be within
the realm of finality.
Look at Politics in America and the Obama birth
question.
Hmmm...  Could this be "false or inaccurate?"
question.
Well ..... how can there be a explanation for the word  F**K  (uc) posted at Over Unity .com ??
Do a "search" http://www.overunity.com/search/  you might find ..... eleven pages ??
Just get rid of the whole TOS because it's irrelevant ??
Fuzzy
Let the PHAT Tuesday parade begin...
(Prophetically hyped and Tongued)  ;D
(Prophetically Hyped And Tongued)  ;D
Pathetically harrangued and tortured, too.
Quote from: Killer of Giants
(Prophetically Hyped And Tongued)  Grin
Pathetically harangued and tortured, too.
Well said mate!
Time to knock a few back and think seriously
about all the "strangeness" in the air...
Enforcement of Policy is always difficult.  Not
every situation which arises can be dealt with
to the satisfaction of all participants.
There is much reliance on the integrity and
honesty of all registrants, among other things.
Hi Guys,
I wanted to make sure members and guest here has seen the last posting of mine at OU .com ....... the image views are incredible ....   :o
Rosemary and/or the NERD RAT contributors as of the time of this posting until now has not questioned or responded to my posting or reply at OU .com    ???
__________________________________________________________________________________________________________________________
POST OVER -
http://www.overunity.com/11675/another-small-breakthrough-on-our-nerd-technology/msg315729/#msg315729   Reply #1117 on: Today at 12:45:43 AM
Hi members and guests,
Being I've asked the question on which NERD RAT device schematic dates go where three times, and never got a response from Rosemary or a NERD RAT team member on the OU forum.
So, I and all concerned NERD RAT device verifiers and replicators will use the obvious COP>INFINITY DEMONSTRATION video of 12 MARCH 2011 as a reference to the two separate and different schematics without any exceptions.
FROM_CONCEPTION_TO_12_MARCH_2001_Q1_x5_NERD_RAT_DEVICE.JPG  ( From DEVICE "Conception" to 12 MARCH 2011 Q1 x5 "NERD RAT" DEVICE SCHEMATIC )
  ( * 561 views )
12_MARCH_2001_and_On_Q1_Q2-Q4_NERD_RAT_DEVICE.png  ( COP>INFINITY DEMONSTRATION 12 MARCH 2011 and "ON" Q1 / Q2-Q4 "NERD RAT" DEVICE SCHEMATIC )    ( * 167 views )
THIS TAKES EFFECT AS OF MARCH 17, 2012 at 12:50 am GMT
Fuzzy
___________________________________________________________________________________________________________________________________________________
***** ( * ADDED VIEW TOTALS ) ****
Hi Poynt,
How are things with Rosemary's circuit.  Were you able to get negative power?
Hi Gibbs.
I have not built the circuit yet. TK over at OU has been doing a number of tests on his version of the RAT circuit, and I asked him to make the "battery" power measurement to see if it was negative. It is.
We are now waiting to see what happens when he adds some caps across the batteries (to kill any remaining oscillation across them) and takes a battery voltage measurement right off them. I expect the battery power measurement to change to a positive value.
Reference the attached sim scope shot, the power computation becomes less negative as the battery p-p voltage drops. The reason? Looking at the unclipped peak, we are multiplying the VCSR peak (neg) and the VBAT peak (pos), so the higher the VBAT peak, the higher the negative product of the two. When averaged, the result is a larger negative average power.
It is not until the VBAT trace becomes almost flat that the true power computation is realized.
I think it's true that the negative comes from high battery positive peak when current reverse.  Not sure if capacitor would help flattening it.  We'll see.  I see the high peak as resistance, higher current, higher voltage.  It is also good to see if the area under positive current and negative current trace.  This represent the amount of charge coming in and out of the battery.
The oscillation is due to circuit inductance, so those peaks may look impressive, but it is mostly apparent power, not real.
The average current is actually slightly positive, even though the trace itself can be perceived to be negative dominant.
The circuit inductance is what requires for oscillation, well, it is required for all oscillators.   If you reduce the circuit's inductance, the peak would reduced, but power can't be apparent because the math function used is for calculating real power.  If you take away all inductance...the circuit won't oscillate and it's just the same as straight DC heating.
I'm surprised sim can put out negative wattage as obtained in the real experiment.  Perhaps sim has been showing extra energy the day it programmed.  I know you see this negative wattage as something ordinary, but I will show you something interesting.
Assuming that the battery doesn't reverse polarity.  A current going out of the battery have positive power and current flow back into the battery have negative power.  The reason the math trace shown negative power because there is more power (hence energy) when current flow back into the battery even though less charges flowing back into the battery.  Intuition would say more charges flowing out of the battery means more energy, right?  We can see this with a simple analysis.
Let's use the VCSR energy dissipation I^2R.  Now separate the current waveform into positive and negative.  Integrate I^2R over that cycle.  You can see that current flowing out of the battery have less energy dissipation than current flowing back.  The analysis for CSR hold true for all resistance the circuit contains.  The conclusion is there are more energy when current reverse and hence the negative wattage.
I'm not sure what you're trying to sat Gibbs.
You believe that the circuit is in fact OU? If not, then what are you trying to say?
The negative wattage is a measurement artifact. There is nothing wrong with SPICE. Indeed the measurement method is correct, but the measurement points are not.
You should not be surprised that the sim can also show the negative wattage. The real problem is that it is garbage in, garbage out.
The power measurement obtained using the points prescribed by the RATs is no more accurate than if we used the voltage measured between your toes times the CSR voltage.
Aw come on, you have to ask me if I believe that circuit is OU?  :)
I didn't say say there is something wrong with SPICE.  How do you describe your garbage in, garbage out?  What I'm saying is When the battery discharge, it gives 100 units of energy.  10 units is lost to resistance, 90 stored in inductance.  Inductance then return that 90 units to the battery.  20 units produced to resistance, 80 made it back to the battery.  Your turn.  :)
Even the voltage comparison between your toes times CSR voltage, it would still show negative wattage man... if you zoom in enough.
It is easy to visualize power in LTspice. You just create a trace with formula U*I where U is the generator voltage and I the current. In my example not related to Ainslie's circuit, the voltage is "V(n001)-V(p001)" and the current is I(Vin), so the formula is I(Vin)*(V(n001)-V(p001)). The trace is the power.
When the trace is displayed, use crtl+click on the formula above the trace: this will open a small box giving the average power and energy during the time of observation. If they are negative, it is the generator that provides the energy.
It's a very useful tool.
Just because a trace swings up or down indicates negative or positive Watts?
Isn't 'negative' or 'positive' Watts the same mistake as RMS Watts?
The display is instantaneous power, so yes + or - power is valid, although meaningless for the most part. Once obtained, you need to take the MEAN of that trace to get the true average power. Now you have something meaningful, if the measurement points were correct in the first place.
Not sure if that answered your question?
Yes. The most important part is 'the measurement points'.
I suppose it is my different take on things creating a bit of a problem for me. Watts is not a value that does any work or has any direction because it has no velocity(?)(wrong term but it isn't a value over time or distance). Having less leaving a battery than returning just means something is overlooked.
Having a 100W light means nothing on your electric bill until you start measuring the Watts and the time running together.
So, having higher Watts returning to the battery is not a problem. Such would happen with a little inductance. The mistake is that Watts means nothing unless you include time. If the measurement methods are decent and the right math is used doesn't really matter. The battery runs down anyway.
Of course, we know this.
"Time" is only required to obtain ENERGY.
IF the circuit runs consistently vs. time with no variations in voltage, current, frequency or duty cycle (like most oscillators), then measuring the average power is all that is required to see if the battery is delivering or receiving net power and energy.
To determine if the battery is recharging, simply look at the CSR current waveform.  More positive area means battery running down, more negative area means battery charging up.
To determine energy time is needed in addition to watts.  The CSR measurement indicated that watt x time for the discharge is less than watt x time for the charging.
They are not a mistake. They follow from equations and show the direction of the energy. When the current flows inside a component from the positive terminal to the negative terminal, the component is a receiver, it consumes energy. When the current flows from the negative terminal to the positive terminal, the component is a generator, it provides energy.
The power being voltage times current, it is perfectly logic that the power is positive or negative, depending on the convention we took for the current direction. The power is negative for a generator providing energy, positive for a receiver consuming energy.
For instance in an oscillating LC circuit, L and C play alternatively at each signal period, the role of generator or receiver: the energy goes back and forth between them.
Not only instantaneous power but also mean power and energy can be either positive or negative, and this can be displayed in LTspice. Suppose you have a 10v generator G with an internal resistance R and a capacitor C in series. When you switch on the generator, it charges C up to 10v. The energy goes from G to C. By convention for the current direction, the power and the energy are negative because the generator provides the energy, its internal energy is depleted.
Now suppose that C was initially charged at 20v. When you switch on the circuit, C provides energy that is dissipated in the internal resistance of the generator. C provides energy to G. So the generator is receiving energy, it is now a receiver, power and energy are positive.
Too early for posting. A little caffeine and I'll be back.
« Last Edit: 2012-04-29, 13:58:03 by WaveWatcher »
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-27, 22:46:02
