2024-11-27, 20:50:09
Pages: 1 ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29
Author Topic: The Rosemary Ainslie Circuit  (Read 477135 times)
The CSR measurement indicated that watt x time for the discharge is less than watt x time for the charging.
It did?
Please show us where.
When the current flows inside a component from the positive terminal to the negative terminal, the component is a receiver, it consumes energy. When the current flows from the negative terminal to the positive terminal, the component is a generator, it provides energy.
The power being voltage times current, it is perfectly logic that the power is positive or negative, depending on the convention we took for the current direction. The power is negative for a generator providing energy, positive for a receiver consuming energy.
O0
It did?
It's probably easier to be done on the sim.  You can take the blue trace (CSR waveform), squared that waveform and take the average.
Actually, you have to maintain the positive region and negative region by yourself because the squared would makes it all positive.
I did some rough calculation.  Taken data at half grid time interval.
Positive curve:  1, 1.3, 1.3, 1.3, 1.3, 1.3, 1.3,1 , 1      Squared value:  1, 1.69, 1.69, 1.69, 1.69, 1.69, 1.69, 1, 1
Negative curve: 1, 1.5, 2.5, 2.3, 1.5                          Squared value:  1, 2.25, 6.25, 5.29, 2.25
Positive total: 13.4
Negative total: 17
Notice I took less data point for negative to be conservative.
Where on earth did you get that idea?
You don't square anything there mate. You simply sum and average a large number of samples within one cycle.
That is... my idea. lol
Seems like you're not following what I'm talking about.  You want to know the energy dissipate in the CRS in the discharge and charging.  Can you calculate the energy dissipate in the CSR?  The sim can calculate the CSR energy easily, but it cannot tell you how much dissipate when current is positive and and negative.  The sim just add the two together.
Actually no. We want to know which direction the average current is flowing.
Of course, with ease.
I guess you're not that familiar with simulation software? Of course the sim can tell you both positive and negative power dissipation, I plot this all the time. It is the first step in obtaining the average power dissipated.
The direction of average current flowing indicate the amount of charge.  I want to show you that the energy watt x time for the two direction of current is different and more energy is seen in the current reverse.  This is what you want me to show you.  Let's get our point across with a simple demonstration.
The graph below shows a current going through a resistor of 1 Ohm.  Let's say the time for positive and negative is 1 second.
What is the energy for the whole cycle?
What is the energy for positive cycle?
What is the energy for the negative cycle?
Now apply how you find these value to the CRS trace.
Are you referring to the scope shot I posted? If so, you are correct in that it would appear more energy is going to the battery than what is coming out.
But look at the CSR trace by itself. If you were to do an average on it (which you have not done, and I have not shown), you would see that the average net current is from the battery. In other words, the battery is net discharging.
The reason the power computation turns out negative using the battery voltage trace and CSR trace, is because the battery voltage trace is not correct.
Yes, the battery is discharging, I never argue that.
Why do you say the voltage trace is not correct?  Are you saying it's super impose AC and is not a real current?  Just a guess.
I mean you don't need to compute battery to know the negative wattage, just compare the CSR out going energy and back energy.
« Last Edit: 2012-04-29, 18:53:20 by GibbsHelmholtz »
See the attached schematic. The battery voltage trace was obtained from point "7". That is not the correct place, but that is where the RATs are measuring it from, and so I replicate this error for demonstrative purposes.
You still don't understand. If you compute the CSR wattage, it will indicate that the battery is discharging. However, if you compute the battery power using the CSR voltage and battery voltage from point 7 on the diagram, you obtain results that say the battery is charging, and this is not correct.
Is it clear now?
PS. Yes I know the CSR value of 0.25 Ohms has not been accounted for in the power computation.
Is it clear now?
When you move from point 7 to point 1, you only reduce the inductance and resistance, making the amplitude go down, but the measurement cannot turn positive, but we'll see in the real test.
Poynt, negative wattage doesn't mean battery is charging.  It is just your assumption.
It does change to positive. Why can't it?
Technically in this scenario, you are correct. But those that are not familiar enough with electronics would (and are) make that assumption. If the measurement was performed correctly however and the polarity was negative, this would indicate the battery is being charged.
Sources have a negative power polarity, and anything that dissipates power (or acquires charge given a battery or capacitor) has a positive power polarity. The reason the polarities are reversed in the measurements we are doing, is because the battery voltage measurement probes are inverted.
What I mean is if the measurement was performed correctly and the polarity still negative, the battery still drain.  Battery charging depends on the net amount of charge, energy depends on the rate of charge.
Nvm, what on my mind right now is a scenario that possibly going on in that circuit.  Suppose if we have a charged capacitor and a resistor, when connect them, energy of 1/2CV^2 is dissipated at the resistor.  If somehow we could make the cap discharge faster for the same resistance, we have more energy.   Possibly with the aid of external magnetic field we could, but still brain storming.
t=1s, I=+/- 1A, V=+/- 1V because R=1 ohm so:
The energy for positive cycle is 1 * 1 = 1W
The energy for the negative cycle is -1 * -1 = 1W
The energy for the whole cycle is 1 + 1 = 2W.
It is only the integral of the instantaneous V*I product. Simulation softwares do it easily.
If the measurement is correctly performed and the integral over time of U * I product is positive, the battery is charging during the time of integration.
I don't think the battery charge or discharge depends on U*I .
I think I know how to make a charged capacitor have less or more heat when discharge it through a fix resistance.  Imagine a cap connecting to a coil and resistance.  If we have the external magnetic field cutting through the coil while the cap discharging, we can cause more or less current flow through the resistance until the cap is empty.  It's all KVL.  However, energy will be spent on the external magnetic field to make this happens.  You can completely discharge the cap without any heating at all.  Simply makes the magnetic field cutting such that it induce a slightly less voltage than the cap, then current would be so small that I^2R is nothing during the discharge time.  The time would be longer, but the energy spent on the magnetic field is also relatively nothing.  Uh... where did all the energy go?
I've read TK result that this is the case.  I think both you and Exn. are right that charging depends on U*I and it would change to positive in this case.  Once we have a strong confirmation from TK I'll give you both the credits.
Now that I've seen TK video, I'm confident that Poynt and Exn. are right.  The extra wire would act as impedance and increase the voltage proportional to the current flow.  If we just measure across the battery, no matter what the rate of charge is, the voltage remains constant because the battery able to absorb large current without fluctuating its voltage.
We can also see this with math analysis.  If the battery voltage remains constant, then the mean power, averaging U*I would be:
AVE [ Vbat x VCRS]
since Vbat is constant, it can be factored outside and becomes:
Vbat x AVE [VCRS]
The positive or negative mean power would then just depends on the average of the CRS waveform.  Since we already discussed that CRS waveform has more positive area, it naturally be that the mean power is positive.
Having seen this, we should be able to agree that in order for battery to be recharging, the AVE[VCRS] has to be negative.  If Rosemary or any replication able to achieve a negative average CRS waveform, it is OU.  I think I remember Rosemary also achieved this.
From ou.com :
hartiberlin
Administrator
Re: Testing the TK Tar Baby
« Reply #5253 on: December 09, 2012, 06:05:12 AM »
I deleted Rosemarie´s new account here after she tried to harrass me at 5:45 in the morning via  a phonecall...
I told her last time, that she can read here , but no more have an account !
Also she runs her own forum, but why does she come back here ??
So she tried to circumvent the rules and got now booted again.
Regards, Stefan. (admin)
Stephan Hartmann banned me from ou.com for having said that the Ainslie's circuit was a scam, and now he banned her too.
It takes him almost two years after me to understand that with Ainslie, he faced a madwoman involved in a scam (or should I suppose that it was good for his site buzz and advertisements to keep her so long?).
Nevertheless I'm still banned, and also forbidden from commenting his youtube videos. Not a problem except that I miss discussions with the little percentage of interesting contributors like Verpies whom we see here sometimes, and some others, roughly less than 5% on ou.com, emerging with their valuable works and ideas above noise, conspiracy theories and other severe delusions. I think it would be good for overunityresearch to attract more of them here.
By the way I saw some schematic from me published here and republished now on ou.com by a guy whom I don't know. If Stephan the censor knew it, he would have a stroke. ;D
I will be putting together this circuit and performing a number of tests on it shortly.
Note the actual build as per the photos vs. the schematic given. The FG ref lead connection places the FG outside the CSR loop.
Should be interesting in what may develop.  O0
She is still slamming her head against that rock?
Sad  :'(
Yep, and with more gusto than ever... :D
Here is the latest layout.
Damn!
I should have invested in alligator clips  C.C
Well i havnt followed her work befor,but i was expecting more of a circuit?. Are we simply trying to blow up some mosfet's here,or flatten some batteries?.
@ Poynt
What is the offset and frequency of the wave?.
Do we have to use those very mosfet's or can we use similar?. I have a heap of 40 amp fet's ,if they will do.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2024-11-27, 20:50:09
