Well i built a coil as per his first instructions.
2 turns thicker Secondary.
my controller is running at 1.2mhz psu at 63volts 35nS pulse width, i have a 12v 5watt bulb in series with the primary and a 12volt 5 watt bulb across the secondary, both light, if i drop the freq down to 500khz the secondary bulb is brighter than the primary bulb, but this does not mean OU it only mean the voltage is being dropped across the coil not the primary bulb, i havnt yet done any power calculations.
My personal feelings are this is just induction or coupling at this point.
« Last Edit: 2010-01-17, 20:47:31 by Peterae »
