2025-03-18, 09:27:17
Pages: 1 ... 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 ... 100
Author Topic: 9/11 debate - enter at your own risk!  (Read 1077210 times)
That's an Interesting article muDped. Something interesting to read in the links as well. Thanks !
Yes I was very satisfied for my first time shooting a "real" pistol (not home made), we all had one on one "tuition" of a very basic kind, most of the other beginners used two hands in a front on stance, but my tutor convinced me to shoot one handed with a slightly angled stance so that the front sight lined up with my eye and the target kind of naturally as I raised my arm. Maximum rate of accurate fire one handed would be about 1 or 2 per second. I agreed it was better to learn to shoot with one hand first, and I might try shooting with my other hand next time for half the rounds, one never knows when an arm or hand may be injured, so I should be able to use both fairly accurately. That Target was only at 10 meters- 30 feet or so I guess, fairly close, at 25 meters 75 feet things will be quite different I think. Some guy there was shooting a black powder "hand cannon", which was as loud as a shot gun, hilarious but seemed a bit dangerous. It was raining last night so no small bore rifle shoot in the rain. This time of year the rain is quite unpredictable.
On a side note I see way more planes spraying here than I did up the mountain. Some days the sky is obviously full of expanded streams of stuff that resemble clouds but are obviously created by the planes. Most people I have pointed it out to look at me like my nose is a banana. hahaa
Everyman decries immorality
The Buck and ball double tap serves Everyman, beyond 200 yards is extreme hunting range and could be considered aggressive.
Buck and ball
Buck and ball was a common load for muzzle-loading muskets, and was frequently used in the American Revolutionary War and into the early days of the American Civil War. The load usually consisted of a .50 to .70 caliber round lead musket ball (.69 caliber for the "Brown Bess" musket) that was combined with three to six buckshot pellets.
Purpose
The intent of the buck and ball load was to combine the devastating impact of the full-size (normally .50 to. 70 caliber, depending on the specific gun) ball with the spreading pattern of a shotgun, and served to greatly improve the hit probability of the smoothbore musket used in combat, especially at closer ranges, where the buckshot would retain significant energy, and against closely packed troops where the spread of the buckshot would be advantageous.
Claud E. Fuller, in his book The Rifled Musket, shows tests of a rifled musket firing Minie balls, and a smoothbore musket firing round ball and buck rounds at various ranges against a 10' x 10' target. The firers consisted of several men in line shooting in volley. At ranges of 200 yards (180 m) and under, the buck and ball from the smoothbore musket, while less accurate than the rifled musket, actually produces a greater number of hits due to the greater number of projectiles. At 200 yards, 37 of 50 Minie balls strike the target, vs. 18 of 50 smoothbore balls and 31 of 150 buckshot, for a total of 49 hits in 50 shots. At 100 yards, 50 shots by smoothbore buck and ball against the 10 x 10 target result in 79 buckshot hits and 37 ball strikes, as opposed to 48 minie ball hits in 50 shots. Beyond this range, the buckshot will have lost too much energy to be effective due to its lower ballistic coefficient.
Double tap
A double tap is a shooting technique where two shots are fired in rapid succession at the same target with the same sight picture (different from the controlled pair, where a second sight picture is acquired for the second shot).[1][2][3] Instruction and practice of the double-tap improves overall accuracy as shooters often do not have the gun fully extended on the first shot meaning the second of a double-tap is usually the better.[4] The term hammer is sometimes used to describe a double tap in which the firearm's sights are not reacquired by the shooter between shots.
Burst fire on modern Assault type rifles takes the double tap one round further to a three round burst, very effective fire mode in some situations I imagine. Double taps are used in the I.P.S.C. shoots though.
This is the guy to beat in Australia. He's a pretty slick shooter, no doubt.
https://www.youtube.com/watch?v=BIowLTHCjPs
Burst fire conserves ammunition from undisciplined operators, but does not deliver an accurate second shot. The point of the double tap is that the first shot normally suffers from tension bias.
The second shot which follows immediately after training has the benefit of muscle memory without preset bias and the potential for target leading and re-acquisition, should the target move. This is all achieved subconsciously, the conscious mind only registers the hit, or does not and corrects for the 2nd shot. The second tap is normally the more accurate shot due to system under extension on the first shot and the benefit of active feedback between mass delivery.
The combination of the Buck and Ball cartridge and the double tap technique maximises hit potential at a range less than 200 yards, beyond 200 yards Everyman could be perceived as the aggressor.
I live in the UK and am forcibly disarmed, enforced by the diktat of the societal government that occupies this island.
 :o
https://www.youtube.com/watch?v=mXtBZPONSCc
God bless Sammy!  :P
https://www.youtube.com/watch?v=BplxfrVZosc
Ken Okeefe tells us in language that we can understand
how our World is being destroyed.
Those who are of the belief that "radical Islam" is the
greatest problem endangering the survival of humankind
may be greatly surprised.
Battlespace
https://en.wikipedia.org/wiki/Battlespace
Battlespace is a term used to signify a unified military strategy to integrate and combine armed forces for the military theatre of operations, including air, information, land, sea, and space to achieve military goals. It includes the environment, factors, and conditions that must be understood to successfully apply combat power, protect the force, or complete the mission. This includes enemy and friendly armed forces, infrastructure, weather, terrain, and the electromagnetic spectrum within the operational areas and areas of interest.[1][2]
Concept
From 'Battlefield' to 'Battlespace'
Over the last 25 years, the understanding of the military operational environment has transformed from primarily a time & space driven linear understanding (a battlefield), to a multi-dimensional system of systems understanding (a battlespace). This system of systems understanding implies that managing the battlespace has become more complex, primarily because of the increased importance of the cognitive domain, a direct result of the information age. Today, militaries are expected to understand the effects of their actions on the operational environment as a whole, and not just in the military domain of their operational environment.
Battlespace agility
Battlespace agility refers to the speed at which the warfighting organization develops and transforms knowledge into actions for desired effects in the battlespace. Essentially it argues that you must be better than the opposition at doing the right actions at the right time and place. Inbuilt into this understanding is that battlespace agility is not just about speed, but it is also about executing the most effective action (ways) in the most efficient manner (means) relative to achieving the desired impact on the system (ends). At all times battlespace agility is dependent on the quality of situational awareness and holistic understanding of the battlespace to determine the best actions, a logic that has become a driving force behind a renaissance of interest in the quality of military intelligence. It has been heavily linked to the ability of intelligence analysts and operational planners to understand their battlespace, and their targets, as networks in order to facilitate a faster, and more accurate shared situational understanding. This in turn increases targeting efficacy and helps retain the overall initiative. Battlespace agility has its roots solidly in the more generic Command & Control (C2) research field on C2 agility conducted by NATO,[3] but works specifically with an agility concept within the context of warfighting only.[4] Hence it is framed by effects based thinking, system of systems analysis, and competing Observation Orient Decide Act (OODA) loops.[5]
Battlespace awareness
Battlespace awareness (BA) is a practice of military philosophy that is used as a valuable asset by joint component and force commanders, to predict courses of action before employing troops into a prescribed area of operation (AO). It utilizes the intelligence preparation asset to assist the commander in being 'aware' of recent, current, and near term events in his battlespace.[6]
It is based around its knowledge and understanding obtained by the an intelligence, surveillance, and reconnaissance (ISR) system. It is another methodical concept used to gain information about the operational area—the environment, factors, and conditions, including the status of friendly and adversary forces, neutrals and noncombatants, weather and terrain—that enables timely, relevant, comprehensive and accurate assessments. It has become an effective concept for conventional and unconventional operations in successfully projecting, or protecting, a military force, and/or completing its mission.[7]
Battlespace digitization
Battlespace digitization is designed to improve military operational effectiveness by integrating weapons platforms, sensor networks, ubiquitous command and control (UC2), intelligence, and network-centric warfare. This military doctrine reflects that in the future, military operations will be merged into joint operations rather than take place in separate battlespaces under the domain of individual armed services.
Battlespace intelligence preparation
Intelligence preparation of the battlespace (IPB) is an analytical methodology employed to reduce uncertainties concerning the enemy, environment, and terrain for all types of operations. Intelligence preparation of the battlespace builds an extensive database for each potential area in which a unit may be required to operate.
The database is then analyzed in detail to determine the impact of the enemy, environment and terrain on operations and presents it in graphic form. Intelligence preparation of the battlespace is a continuing process.
Joint intelligence preparation
Joint intelligence preparation of the battlespace (JIPB) is the analytical process used by joint intelligence organizations to produce intelligence assessments, estimates and other intelligence products in support of the joint force commander's decision making process. It is a continuous process that includes defining the total battlespace environment; describing the battlespace's effects; evaluating the adversary; and determining and describing adversary potential courses of action.
The process is used to analyze the aerial, terrestrial, maritime/littoral, spatial, electromagnetic, cyberspace, and human dimensions of the environment and to determine an opponent's capabilities to operate in each. JPIB products are used by the joint force and component command staffs in preparing their estimates and are also applied during the analysis and selection of friendly courses of action.
Battlespace measures
Manoeuvre control measures are the basic preliminary step in effective clearance of fire support (e.g. artillery, Naval gunfire, and close air support), marked by imaginary boundary lines used by commanders to designate the geographical area for which a particular unit is tactically responsible. It is usually established on identifiable terrain to help aid in hasty referencing for better lateral advantage in the science of fire support, normally orchestrated by a higher echelon of the general staff, mainly the operations staff sections.
They are normally designated along terrain features easily recognizable on the ground. An important point on maneuver control graphics: staffs must be knowledgeable regarding the different maneuver control measures and their impact on clearance of fires. For instance, boundaries are both restrictive and permissive; corridors are restrictive, while routes, axis, and directions of attack are neither.
It should be reminded of the effect on clearance of fires if subordinate maneuver units are not given zones or sectors (i.e. no boundaries established). Since boundaries serve as both permissive and restrictive measures, the decision not to employ them has profound effects upon timely clearance of fires at the lowest possible level.
The higher echelon may coordinate all clearance of fires short of the Coordinated Fire Line (CFL), a very time-intensive process. It allows the unit to maneuver successfully and to swiftly and efficiently engage targets. It requires coordination and clearance only within that organization.
They affect fire support in two ways:[8]
    Restrictive—Restrictive control that is established in conjunction with a host nation to preclude damage or destruction to a national asset, population center, or religious structure. Its key role are for protection of an element of tactical importance, such as a fuel storage area.
        Restrictive fire area (RFA) is an area with specific restrictions and in which fires that exceed those restrictions will not be delivered without coordination with the establishing headquarters, or higher echelon; occasionally, it may be established to operate independently.
        No-fire area (NFA) is a designated area which no fire support may be delivered for fires or effects. When the establishing headquarters allows fires on a mission-by-mission basis. When a friendly force is engaged by an enemy located within the NFA and the commander returns fire to defend his forces. The amount of return fire should not exceed that sufficient to protect the force and continue the mission.
    Permissive—Permissive control that gives the maneuver commander the liberty to announce and engage fire support at his will, unless it otherwise is restricted by a higher echelon. Most cases, a commander will deny the use of Fire Support Coordinating Measures (FSCM).
        There are free-fire areas (FFA) which fire support can commence without additional coordination with the establishing headquarters. Normally, it is established on identifiable terrain by division or higher headquarters.
Battlespace shaping
Further information: Area of responsibility
Battlespace shaping is a concept involved in the practice of maneuver warfare that are used for shaping a situation on the battlefield, gaining the military advantage for the commander. It forecasts the elimination of the enemy's capability by fighting in a coherent manner before deploying determine-sized forces.[9]
EINSTEIN – FRAUD PLAGIARIST (DOCUMENTED): The Einstein Fraud – Thief, Liar, Borderline Retardation, (Judaic) Media Created Celebrity Hero!
http://truedemocracyparty.net/2013/03/einstein-fraud-plagiarist-documented-the-einstein-fraud-thief-liar-borderline-retardation-judaic-media-created-celebrity-hero/
THE JEWISH MEDIA CENSORED TRUTH ABOUT EINSTEIN
Either all the American teachers were wrong and the Media is telling the truth, or the Media is lying, and the American teachers were telling the truth. All the information is here for you to decide for yourself.
Or you can be like Homer Simpson…and think the TV is God and believe whatever it tells you.
– T.D.P. ADMIN
You can fool all of the people, some of the time.
You can fool some of the people, all of the time.
But you can’t fool all of the people, all of the time.
He was three years old before he started speaking, and it took him several more years before he was fluent.
He did not read until he was seven, and his poor performance in elementary school caused many people to suspect he was mentally retarded.
When called upon, the boy would take forever before answering, often silently mouthing the words to himself before slowly uttering the words aloud. Most believe that it would be highly unlikely that Albert Einstein would ever succeed at anything.
When he tried to get into the Swiss Federal Institute of Technology, he failed the entrance exam and was required to take it again. His doctoral dissertation was rejected by the university as “irrelevant and fanciful.” After graduation, Einstein landed a position as a clerk in a patent office. He liked the job because it allowed him to enough free time to research some of his scientific theories.
Again, it seemed he might not achieve much more than this position since he was known for being incredibly absent-minded. For example, he would often forget to put on his socks and even misplaced a $1500 check after he used it as a bookmark.
It was not until after the first of Einstein’s theories was published, the Special Theory of Relativity, that he was truly recognized by the scientific community. However…what if it was all…Plagiarized Information.
What if the only thing he was good at, was stealing other peoples ideas. In some cases, even years after they were published?
What if his ‘Theory of Relativity’ really belonged to his best friend, who sent him a copy of it before he had it published?
Why if someone had published ‘The Theory of Relativity’ weeks before Einstein, were they ignored by the Media, and gave all credit to Einstein, even when proved it belonged to someone else?
ALBERT EINSTEIN is held up as “a rare genius,” who drastically changed the field of theoretical physics. However, using the technique known as ‘The Often-Repeated Lie= Truth,’ he has been made an idol to young people, and his very name has become synonymous with genius. THE TRUTH, HOWEVER, IS VERY DIFFERENT. Einstein was an inept & moronic person, who could not even tie his own shoelaces; he contributed NOTHING ORIGINAL to the field of quantum mechanics, nor any other science. On the contrary — he stole the ideas of others, and the Jxxxx-controlled media made him a ‘hero.’
When we actually examine the life of Albert Einstein, we find that his only ‘brilliance’ was in his ability to PLAGIARIZE and STEAL OTHER PEOPLE’S IDEAS, PASSING THEM OFF AS HIS OWN. Einstein’s education, or lack thereof, is an important part of this story. The Encyclopedia Britannica says of Einstein’s early education that he “showed little scholastic ability.” It also says that at the age of 15, “with poor grades in history, geography, and languages, he left school with no diploma.” Einstein himself wrote in a school paper of his “lack of imagination and practical ability.” In 1895, Einstein failed a simple entrance exam to an engineering school in Zurich.
This exam consisted mainly of mathematical problems, and Einstein showed himself to be mathematically inept in this exam. He then entered a lesser school hoping to use it as a stepping stone to the engineering school he could not get into, but after graduating in 1900, he still could not get a position at the engineering school!
Unable to go to the school as he had wanted, he got a job (with the help of a friend) at the patent office in Bern. He was to be a technical expert third class, which meant that he was too incompetent for a higher qualified position. Even after publishing his so-called ground-breaking papers of 1905 and after working in the patent office for six years, he was only elevated to a second class standing. Remember, the work he was doing at the patent office, for which he was only rated third class, was not quantum mechanics or theoretical physics, but was reviewing technical documents for patents of every day things; yet he was barely qualified.
He would work at the patent office until 1909, all the while continuously trying to get a position at a university, but without success. All of these facts are true, but now begins the myth.
Supposedly, while working a full time job, without the aid of university colleagues, a staff of graduate students, a laboratory, or any of the things normally associated with an academic setting, Einstein in his spare time wrote four ground-breaking essays in the field of theoretical physics and quantum mechanics that were published in 1905.
Many people have recognized the impossibility of such a feat, including Einstein himself, and therefore Einstein has led people to believe that many of these ideas came to him in his sleep, out of the blue, because indeed that is the only logical explanation of how an admittedly inept moron could have written such documents at the age of 26 without any real education.
HOWEVER, THE TRUTH IS: HE STOLE THE IDEAS AND PLAGIARIZED THE PAPERS.
Therefore, we will look at each of these ideas and discover the source of each. It should be remembered that these ideas are presented by Einstein’s worshipers as totally new and completely different, each of which would change the landscape of science. These four papers dealt with the following four ideas, respectively:
1) The foundation of the photon theory of light;
2) The equivalence of energy and mass;
3) The explanation of Brownian motion in liquids;
4) The special theory of relativity.
Let us first look at the last of these theories, the theory of relativity. This is perhaps the most famous idea falsely attributed to Einstein. Specifically, this 1905 paper dealt with what Einstein called the Special Theory of Relativity (the General Theory would come in 1915).
This theory contradicted the traditional Newtonian mechanics and was based upon two premises:
1) in the absence of acceleration, the laws of nature are the same for all observers; and
2) since the speed of light is independent of the motion of its source, then the time interval between two events is longer for an observer in whose frame of reference the events occur at different places than for an observer in whose frame of reference the events occur in the same place. This is basically the idea that time passes more slowly as one’s velocity approaches the speed of light, relative to slower velocities where time would pass faster. This theory has been validated by modern experiments and is the basis for modern physics. But these two premises are far from being originally Einstein’s. FIRST OF ALL, THE IDEA THAT THE SPEED OF LIGHT WAS A CONSTANT AND WAS INDEPENDENT OF THE MOTION OF ITS SOURCE WAS NOT EINSTEIN’S AT ALL, BUT WAS PROPOSED BY THE SCOTTISH SCIENTIST JAMES MAXWELL in 1878.
Maxwell studied the phenomenon of light extensively and first proposed that it was electromagnetic in nature.
James Maxwell wrote an article to this effect for the 1878 edition of the Encyclopedia Britannica. His ideas prompted much debate, and by 1887, as a result of his work and the ensuing debate, the scientific community, particularly Lorentz, Michelson, and Morley reached the conclusion that the velocity of light was independent of the velocity of the observer.
Thus, this piece of the Special Theory of Relativity was known 27 years before Einstein wrote his paper. This debate over the nature of light also led Michelson and Morley to conduct an important experiment, the results of which could not be explained by Newtonian mechanics. They observed a phenomenon caused by relativity but they did not understand relativity. They had attempted to detect the motion of the earth through ether, which was a medium thought to be necessary for the propagation of light.
In response to this problem, in 1880, the irish physicist george fitz gerald, who had also first proposed a mechanism for producing radio waves, wrote a paper which stated that the results of the michelson-morley experiment could be explained if, “…the length of material bodies changes, according as they are moving through the either or across it by an amount depending on the square of the ratio of their velocities to that of light.”
THIS IS THE THEORY OF RELATIVITY, 13 YEARS BEFORE EINSTEIN’S PAPER!
FURTHER… IN 1892, HENDRIK LORENTZ, of the Netherlands, proposed the same solution and began to greatly expand the idea. All throughout the 1890’s, both Lorentz and FitzGerald worked on these ideas and wrote articles strangely similar to Einstein’s Special Theory detailing what is now known as the Lorentz-Fitz Gerald Contraction.
In 1898, the Irishman Joseph Larmor wrote down equations explaining the Lorentz-Fitzgerald contraction and its relativistic consequences, 7 years before Einstein’s paper. By 1904, “Lorentz transformations,” the series of equations explaining relativity, were published by Lorentz. They> describe the increase of mass, the shortening of length, and the time dilation of a body moving at speeds close to the velocity of light. In short, by 1904, everything in “Einstein’s paper” regarding the Special Theory of Relativity had already been published. The Frenchman Poincaré had, in 1898, written a paper unifying many of these ideas. He stated seven years before Einstein’s paper: “…we have no direct intuition about the equality of two time intervals. The simultaneity of two events or the order of their succession, as well as the equality of two time intervals, must be defined in such a way that the statements of the natural laws be as simple as possible.” Anyone who has read Einstein’s 1905 paper will immediately recognize the similarity and the lack of originality on the part of Einstein.
Thus, we see that the only thing original about the paper was the term ‘Special Theory of Relativity.’ EVERYTHING ELSE WAS PLAGIARIZED. Over the next few years, Poincaré became one of the most important lecturers and writers regarding relativity, but he never, in any of his papers or speeches, mentioned Albert Einstein. Thus, while Poincaré was busy bringing the rest of the academic world up to speed regarding relativity, Einstein was still working in the patent> office in Bern and no one in the academic community thought it necessary to give much credence or mention to Einstein’s work. Most of these early physicists knew that he was a fraud.
This brings us to the explanation of Brownian motion, the subject of another of Einstein’s 1905 papers. Brownian motion describes the irregular motion of a body arising from the thermal energy of the molecules of the material in which the body is immersed. The movement had first been observed by the Scottish botanist Robert Brown in 1827. The explanation of this phenomenon has to do with the Kinetic Theory of Matter, and it was the American Josiah Gibbs and the Austrian Ludwig Boltzmann who first explained this occurrence, not Albert Einstein. In fact, the mathematical equation describing the motion contains the famous Boltzmann constant, k. Between these two men, they had explained by the 1890s everything in Einstein’s 1905 paper regarding Brownian motion.
The subject of the equivalence of mass and energy was contained in a third paper published by Einstein in 1905. This concept is expressed by the famous equation E=mc2. Einstein’s biographers categorize this as “his most famous and most spectacular conclusion.” Even though this idea is an obvious conclusion of Einstein’s earlier relativity paper, it was not included in that paper but was published as an afterthought later in the year. Still, the idea of energy-mass equivalence was not original with Einstein.
That there was an equivalence between mass and energy had been shown in the laboratory in the 1890s by both J.J. Thomsom of Cambridge and by W. Kaufmann in Göttingen. In 1900, Poincaré had shown that there was a mass relationship for all forms of energy, not just electromagnetic energy. Yet, the most probable source of Einstein’s plagiarism was Friedrich Hasenöhrl, one of the most brilliant, yet unappreciated physicists of the era. Hasenöhrl was the teacher of many of the German scientists who would later become famous for a variety of topics. He had worked on the idea of the equivalence of mass and energy for many years and had published a paper on the topic in 1904 in the very same journal which Einstein would publish his plagiarized version in 1905. For his brilliant work in this area, Hasenörhl had received in 1904 a prize from the prestigious Vienna Academy of Sciences.
Furthermore, the mathematical relationship of mass and energy was a simple deduction from the already well-known equations of Scottish physicist James Maxwell. Scientists long understood that the mathematical relationship expressed by the equation E=mc2 was the logical result of Maxwell’s work, they just did not believe it.
THUS, THE EXPERIMENTS OF THOMSON, KAUFMANN, AND FINALLY, AND MOST IMPORTANTLY, HASENÖRHL, CONFIRMED MAXWELL’S WORK. IT IS LUDICROUS TO BELIEVE THAT EINSTEIN DEVELOPED THIS POSTULATE, particularly in light of the fact that Einstein did not have the laboratory necessary to conduct the appropriate experiments. In this same plagiarized article of Einstein’s, he suggested to the scientific community, “Perhaps it will prove possible to test this theory using bodies whose energy content is variable to a high degree (e.g., salts of radium).” This remark demonstrates how little Einstein understood about science, for this was truly an outlandish remark. By saying this, Einstein showed that he really did not understand basic scientific principles and that he was writing about a topic that he did not understand. In fact, in response to this article, J. Precht remarked that such an experiment “lies beyond the realm of possible experience.” The last subject dealt with in Einstein’s 1905 papers was the foundation of the photon theory of light. Einstein wrote about the photoelectric effect. The photoelectric effect is the release of electrons from certain metals or semiconductors by the action of light. This area of research is particularly important to the Einstein myth because it was for this topic that he UNJUSTLY received his 1922 Nobel Prize.
But AGAIN IT IS NOT EINSTEIN, BUT WILHELM WIEN AND MAX PLANCK WHO DESERVE THE CREDIT. The main point of Einstein’s paper, and the point for which he is given credit, is that light is emitted and absorbed in finite packets called quanta. This was the explanation for the photoelectric effect. The photoelectric effect had been explained by Heinrich Hertz in 1888. Hertz and others, including Philipp Lenard, worked on understanding this phenomenon.
Lenard was the first to show that the energy of the electrons released in the photoelectric effect was not governed by the intensity of the light but by the frequency of the light. This was an important breakthrough. Wien and Planck were colleagues and they were the fathers of modern day quantum theory. By 1900, Max Planck, based upon his and Wien’s work, had shown that radiated energy was absorbed and emitted in finite units called quanta. The only difference in his work of 1900 and Einstein’s work of 1905 was that Einstein limited himself to talking about one particular type of energy light energy. But the principles and equations governing the process in general had been deduced by Planck in 1900. Einstein himself admitted that the obvious conclusion of Planck’s work was that light also existed in discrete packets of energy. Thus, nothing in this paper of Einstein’s was original.
After the 1905 papers of Einstein were published, the scientific community took little notice and Einstein continued his job at the patent office until 1909 when it was arranged by World Jewry for him to take a position at a school . Still, it was not until a 1919 A Jewish newspaper headline that he gained any notoriety. With Einstein’s academic appointment in 1909, he was placed in a position where he could begin to use other people’s work as his own more openly.
He engaged many of his students to look for ways to prove the theories he had supposedly developed, or ways to apply those theories, and then he could present the research as his own or at least take partial credit. In this vein, in 1912, he began to try and express his gravitational research in terms of a new, recently developed calculus, which was conducive to understanding relativity. This was the beginning of his General Theory of Relativity, which he would publish in 1915.
BUT THE MATHEMATICAL WORK WAS NOT DONE BY EINSTEIN – HE WAS INCAPABLE OF IT. Instead, it was performed by the mathematician Marcel Grossmann, who in turn used the mathematical principles developed by Berhard Riemann, who was the first to develop a sound non-Euclidean geometry, which is the basis of all mathematics used to describe relativity.
The General Theory of Relativity applied the principles of relativity to the universe; that is, to the gravitational pull of planets and their orbits, and the general principle that light rays bend as they pass by a massive object. Einstein published an initial paper in 1913 based upon the work which Grossmann did, adapting the math of Riemann to Relativity. But this paper was filled with errors and the conclusions were incorrect.
It appears that Grossmann was not smart enough to figure it out for Einstein. So Einstein was forced to look elsewhere to plagiarize his General Theory. Einstein published his correct General Theory of Relativity in 1915, and said prior to its publication that he, “completely succeeded in convincing Hilbert and Klein.” He is referring to David Hilbert, perhaps the most brilliantmathematician of the 20th century, and Felix Klein, another mathematician who had been instrumental in the development of the area of calculus that Grossmann had used to develop the General Theory of Relativity for Einstein.
Einstein’s statement regarding the two men would lead the reader to believe that Einstein had changed Hilbert’s and Klein’s opinions regarding General Relativity, and that he had influenced them in their thinking.
However, the exact opposite is true. EINSTEIN STOLE THE MAJORITY OF HIS GENERAL RELATIVITY WORK FROM THESE TWO MEN, THE REST BEING TAKEN FROM GROSSMANN. HILBERT SUBMITTED FOR PUBLICATION, A WEEK BEFORE EINSTEIN COMPLETED HIS WORK, A PAPER WHICH CONTAINED THE CORRECT FIELD EQUATIONS, OF GENERAL RELATIVITY.
What this means is that Hilbert wrote basically the exact same paper, with the same conclusions, before Einstein did. Einstein would have had an opportunity to know of Hilbert’s work all along, because there were friends of his working for Hilbert. Yet, even this was not necessary, for Einstein had seen Hilbert’s paper in advance of publishing his own. Both of these papers were, before being printed, delivered in the form of a lecture.
Einstein presented his paper on November 25, 1915 in Berlin and Hilbert had presented his paper on November 20 in Göttingen. On November 18, Hilbert received a letter from Einstein thanking him for sending him a draft of the treatise Hilbert was to deliver on the 20th. So, in fact, Hilbert had sent a copy of his work at least two weeks in advance to Einstein before either of the two men delivered their lectures, but Einstein did not send Hilbert an advance copy of his.
Therefore, THIS SERVES AS INCONTROVERTIBLE PROOF THAT EINSTEIN QUICKLY PLAGIARIZED THE WORK AND THEN PRESENTED IT, HOPING TO BEAT HILBERT TO THE PUNCH. Also, at the same time, Einstein publicly began to belittle Hilbert, even though in the previous summer he had praised him in an effort to get Hilbert to share his work with him. Hilbert made the mistake of sending Einstein this draft copy, but still he delivered his work first. Not only did Hilbert publish his work first, but it was of much higher quality than Einstein’s. It is known today that there are many problems with assumptions made in Einstein’s General Theory paper. We know today that Hilbert was much closer to the truth. Hilbert’s paper is the forerunner of the unified field theory of gravitation and electromagnetism and of the work of Erwin Schrödinger, whose work is the basis of all modern day quantum mechanics. That the group of men discussed so far were the actual originators of the ideas claimed by Einstein was known by the scientific community all along. In 1940, a group of German physicists meeting in Austria declared that “before Einstein, Aryan scientists like Lorentz, Hasenöhrl, Poincaré, etc., had created the foundations of the theory of relativity.” However, the Jewish media did not promote the work of these men. The Jewish media did not promote the work of David Hilbert, but instead they promoted the work of the Jew Albert Einstein.
As we mentioned earlier, this General Theory, as postulated by Hilbert first and in plagiarized form by Einstein second, stated that light rays should bend when they pass by a massive object. In 1919, during the eclipse of the Sun, light from distant stars passing close to the Sun was observed to bend according to the theory. This evidence supported the General Theory of Relativity, and the Jxxxx-controlled media immediately seized upon the opportunity to prop up Einstein as a hero, at the expense of the true genius, David Hilbert. On November 7th, 1919, the London Times ran an article, the headline of which proclaimed, “Revolution in science – New theory of the Universe – Newtonian ideas overthrown.” This was the beginning of the force-feeding of the Einstein myth to the masses. In the following years, Einstein’s earlier 1905 papers were propagandized and Einstein was heralded as the originator of all the ideas he had stolen. Because of this push by the Jewish media, in 1922, EINSTEIN RECEIVED THE NOBEL PRIZE FOR THE WORK HE HAD STOLEN IN 1905 REGARDING THE PHOTOELECTRIC EFFECT.
The establishment of the Einstein farce between 1919 and 1922 was an important coup for world Zionism and Jewry. As soon as Einstein had been established as an idol to the popular masses of England and America, his image was promoted as the rare genius that he is erroneously believed to be today.
As such, he immediately began his work as a tool for World Zionism. The masses bought into the idea that if someone was so brilliant as to change our fundamental understanding of the universe, then certainly we ought to listen to his opinions regarding political and social issues.
This is exactly what World Jewry wanted to establish in its ongoing effort of social engineering. They certainly did not want someone like David Hilbert to be recognized as rare genius. After all, this physicist had come from a strong German, Christian background. His grandfather’s two middle names were ‘Fürchtegott Leberecht’ or ‘Fear God, Live Right.’ In August of 1934, the day before a vote was to be taken regarding installing Adolf Hitler as President of the Reich, Hilbert signed a proclamation in support of Adolf Hitler, along with other leading German scientists, that was published in the German newspapers. So the Jews certainly did not want David Hilbert receiving the credit he deserved. The Jews did not want Max Planck receiving the credit he deserved either. This German’s grandfather and great-grandfather had been important German theologians, and during World War II he would stay in Germany throughout the war, supporting his fatherland the best he could. The Jews certainly did not want the up-and-coming Erwin Schrödinger to be heralded as a genius to the masses. This Austrian physicist would go on to teach at Adolf Hitler University in Austria, and he wrote a public letter expressing his support for the Third Reich. This Austrian’s work on the unified field theory was a forerunner of modern physics, even though it had been criticized by Einstein, who apparently could not understand it.
The Jews did not want to have Werner Heisenberg promoted as a rare genius, even though he would go on to solidify quantum theory and contribute to it greatly, as well as develop his famous uncertainty principle, in addition to describing the modern atom and nucleus and the binding energies that are essential to modern chemistry.
NO, THE JEWS DID NOT WANT HEISENBERG PROMOTED AS A GENIUS BECAUSE HE WOULD GO ON TO HEAD THE GERMAN ATOMIC BOMB PROJECT AND SERVE PRISON TIME AFTER THE WAR FOR HIS INVOLVEMENT WITH THE THIRD REICH. No, the Jews did not want to give credit to any of a number of Germans, Austrians, Irishmen, Frenchmen, Scotsmen, Englishmen, and even Americans who had contributed to the body of knowledge and evidence from which Einstein plagiarized and stole his work. Instead, they needed to erect Einstein as their golden calf, even though he repeatedly and often embarrassed himself with his nonfactual or nearsighted comments regarding the work he had supposedly done. For example, in 1934, the Pittsburgh Post-Gazette ran a front page article in which Einstein gave an “emphatic denial” regarding the idea of practical applications for the “energy of the atom.” The article says, “But the ‘energy of the atom’ is something else again. If you believe that man will someday be able to harness this boundless energyto drive a great steamship across the ocean on a pint of water, for instancethen, according to Einstein, you are wrong”
Again, Einstein clearly did not understand the branch of physics he had supposedly founded, though elsewhere in the world at the time theoretical research was underway that would lead to the atomic bomb and nuclear energy. But after Einstein was promoted as a god in 1919, he made no real attempts to plagiarize any other work. Rather, he began his real purpose evangelizing for the cause of Zionism and World Jewry. Though he did publish other articles after this time, all of them were co-authored by at least one other person, and in each instance, Einstein had little if anything to do with the research that led to the articles; he was merely recruited by the co-authors in order to lend credence to their work. Thus freed of the pretense of academia, Einstein began his assault for World Zionism.
The only two reasons Albert Einstein has been portrayed as the poster child for Physics, Genius, and High Intelligence is because he was Jewish and most of the mass media (TV stations, news companies, newspapers, radio stations, magazines, book publishing companies, etc.) have been owned by Jews. The gentile Niels Bohr formulated quantum mechanics, but no one would recognize that name except for Physics majors. So, the only reason Einstein has developed such a big name for himself is extreme nepotism:
Was Albert Einstein a hoax?
Articles have been appearing all over the Internet asserting that Albert Einstein was a hoax. I have always been troubled by the thought that any one man, regardless of how brilliant or exceptional, could be head and shoulders above all of the other men of his time. Since I have long doubted that Albert Einstein could possibly be the greatest genius that he is made out to be, I find the theory interesting. I have also been wondering why Einstein became so famous, whereas other great scientists remained virtually unknown.
The basic idea is this: Einstein was a poor student, of average ability. He even failed seventh grade math. There was nothing exceptional about his ability or accomplishments, until he got a job as a low level clerk in the patent office in Bern, Switzerland.
It is commonly reported that Einstein had an IQ of 160, but even though Tesla was supposedly never tested he is estimated to have had an IQ of over 200. I did a quick online test not long ago and scored 160 myself, though I don't put much stock into that.
Einstein I have been led to believe had a wife who was well educated and it is said she helped him to do whatever he did, be it plagiarize or other.
I'm not sure I agree with the bending or warping of space time thing, it just seems so "made up" and pangs of (not of reality).
I read a question asked online - Who was the smarter man Einstein or Tesla ? and everyone that answered, answered Tesla. The people that messed with Tesla did mankind a great disservice.
My IQ test result (I doubt it is accurate but I did the test and that is the result)
http://healthcare1s.com/test-iq/share.php?rsu=Andrew+Michael+has+an+IQ+of+160%2C+You+are+very+intelligent%2C+few+people+have+an+IQ+like+you.&ad=122.150.57.93
This is the Wiki's opinion on intelligence. "Intelligence has been defined in many different ways" and an IQ test proves you can score that particular score on that particular test at the time you take the test.
If you practice the IQ test over and over and improve your score over time do you get more intelligent ?
Intelligence
https://en.wikipedia.org/wiki/Intelligence
Intelligence has been defined in many different ways including one's capacity for logic, abstract thought, understanding, self-awareness, communication, learning, emotional knowledge, memory, planning, creativity and problem solving. It can be more generally described as the ability to perceive information, and retain it as knowledge to be applied towards adaptive behaviors within an environment.
Intelligence is most widely studied in humans, but has also been observed in non-human animals and in plants. Artificial intelligence is intelligence in machines. (i.e., software)
Within the discipline of psychology, various approaches to human intelligence have been adopted. The psychometric approach is especially familiar to the general public, as well as being the most researched and by far the most widely used in practical settings.[1]
Invasion of Europe: The ship is going down
https://www.rt.com/op-edge/329961-invasion-europe-migrants-brussels/
 It is sobering to realize that the supposed captains on the ship your forebears built over millennia are willfully detonating the bulkheads and drilling large holes in the hull whilst claiming there is nothing anyone could possibly have done.
The Kübler-Ross model of trauma describes the emotional pathway for any European with an interest in protecting the continent his forebears created from the perfidy of national leaders whose actions will breed him and his children out of existence.
First there was denial: surely Angela Merkel couldn’t be so stupid as to sink the European ship?
Next came anger as news of the organized attacks by so-called asylum-seekers on European white women seeped through the checkpoints embedded in the mainstream media machine.
Then came the stage known as bargaining as people thought they would settle for some restrictions on numbers so long as the tidal wave was stopped.
And now we are at enforced acceptance: the tidal wave will not stop – so get used to it – with Jeremy Corbyn, for example, calling for the UK to take similar numbers as Germany.
If you feel like you didn’t vote for any of this, that’s because you didn’t. Your opinion isn’t worth the paper it’s written on. It’s people like George Soros who are making these decisions. Your job is to shut up, pay taxes, and learn to get on board with this new round of social engineering and ethnic cleansing.
But now that it is obvious to anyone with a functioning brain that – hand-wringing apart – the fix is in, it is interesting to observe how career politicians are talking now that the dust is settling on the new reality.
Because talk is all that they will do. We are at the tipping point. And once we get over that, the ship is going down, make no mistake.
Political positioning
The French Prime Minister Manuel Valls, for example, has managed – albeit belatedly – to get an intellectual handle on what’s going on: the refugee crisis is destabilizing Europe.
Now, he does not mean what you and I mean by Europe: our countries, nations, languages and histories. He’s a Bilderberger so he has at least a mid-level understanding of the actual plan and doesn’t care about any of the things the people who vote for him care about. He means the Union of European Soviet Socialist Republics; the Brussels oligarchy in other words.
The Guardian writes: ‘He said a message to refugees that said “Come, you will be welcome” provoked major shifts in population.’
His grasp of the obvious now it is too late to do anything about it is impressive.
The Dutch prime minister, Mark Rutte, said Europe was close to breaking point: “We need to get a grip on this issue in the next six to eight weeks.” But, he went on: “No one wants to kill Schengen, but if it is only a fair-weather system then it cannot survive.”
Geert Wilders is described by the liberal press as a ‘far-right’ Dutch politician. This means he has stayed roughly where our grandparents were while everyone else was processed by Cultural Marxism. Wilders has called for the invading, marauding males to be locked up in asylum centers and for the safety of Dutch women and girls to be put first. What a novel idea.
This isn’t ‘far-right’. It is just right. But, we already know, it will never happen.
RT interviewed Hansjoerg Mueller of the Alternative for Germany party. Mueller said: ‘Germany now is somewhere at the edge of anarchy and sliding towards civil war, or to become a "banana republic without any government."
He went on: ‘Bavaria is the first region because we are affected the most – we are living on the border to Austria where the influx of refugees stems from. But the second regions of Germany where this happens are Saxony and Thuringia. First of all, they have also borders to the Czech Republic, that’s the first reason. And the second reason is that in former Eastern Germany people are still aware of what it is living in a dictatorship. They are feeling quite well that our so-called democracy is sliding more and more towards a totalitarian state.’’
Interesting and objectively correct words. But then Mueller does not hold any real power.
Donald Tusk, on the other hand – as chief apparatchik in the European Soviet machine – does have power. He now warns that we have only two months to get things under control. This means, of course, when after two months the invasion is only worse, we will be expected to accept the situation as fait accompli.
Tusk also has a holy reverence for the nonsense known as the Schengen Agreement and warned that if Europe fails to make the strategy work “we will face grave consequences such as the collapse of Schengen,” the 26-nation passport-free travel zone.
How complicated is it?
There is nothing holy about the Schengen Agreement – the UK is not party to it, for example. But European leaders talk about it as though it were somehow problematic to revoke it.
It’s not.
The Schengen is an idea. The invasion of Europe and the destruction of the ancient cultures within it, however, is very real.
If these were not ‘refugees’ but infantrymen (even ones without guns) arriving from – let’s say – North Korea, this problem would not have got to first base.
This is an invasion. But because it is dressed up in the garb Europeans fall for every time – the language of compassion – we are now in a state where European women cannot walk unmolested in their own streets or use public pools without being subjected to degradation.
Given the political will, this problem can be fixed in a five-minute conversation. It’s a group Skype call at best. The fact that this doesn’t happen belies the reality: the fix is in, and politicians like Valls and apparatchiks like Tusk are trying to distance themselves from the inevitable fallout. This is why they are saying things they think people will want to hear: not because they are going to step up and do what is necessary, but because they don’t want the coming chaos attached to their names.
The solution is obvious: stop ‘saving’ all the ships arriving in Europe; put officers with real powers on borders, and have anyone without a passport or other valid ID immediately ejected from the EU space. And border guards both at the peripheries of individual countries and the EU itself should be told in clear and uncertain terms what their job is: to protect what’s behind them from what’s in front of them.
If EU border guards’ pay was inversely indexed to the number of persons shown to have entered the EU illegally – and if internal police had equivalent motivations – this problem would be solved in a month.
If there is a genuine case for asylum – based on the existing legal framework – the place for that discussion is on the border of the EU, not within it.
Pretending to address the problem
Germany has followed Switzerland in confiscating the assets of ‘refugees’ over a certain value – shown to be four-figure sums on average. This will do nothing other than ensure that the next wave comes with nothing, or has it sent over in parcels later.
The real causes for invasion lie with neo-colonialism and the banking cartel which drives it – ‘philanthropists’ such as Soros – and NATO’s genocide against Libya and the murder of Gaddafi – who was holding back the population floodgates for us.
NATO has no compunction about killing people in very large numbers when it suits the bankers’ agenda. The fact that Europe’s military is pussy-footing around now that we actually need soldiers to do their only legitimate job – defend our borders – suddenly everyone is Albert Schweitzer. The case is so plain, even 16 year-old German girls with no previous interest in ‘politics’ are getting it.
Anyone who suggests taking effective action is labelled ‘far-right’ by the liberal media which panders to those whose intellects are bypassed by means of emotional trigger-words such as ‘compassion’.
But the motif of the ship is a fair one. When a ship goes down there are never enough lifeboats. Sailors are trained to beat off with violence those still in the sea once the lifeboat is full. If they do not – everyone dies. This is real compassion.
If there is a silver lining in this tale of corruption and perfidy it is this: the liberal’s catch-all justification for his crimes against his own people – that of pleading ‘compassion’ – is no longer beyond criticism. People have had enough. Wanting your family and your culture to survive does not make you evil.
This is not a game; it is deadly serious. And if the helm cannot be wrest from those bent on taking the ship down, it’s time for those with the wit and the means to make a quiet move for the exits.
Turkey’s Relations with NATO
http://www.mfa.gov.tr/nato.en.mfa
Ever since our NATO membership in 1952, the North Atlantic Alliance has played a central role in Turkey’s security and contributed to its integration with the Euro-Atlantic community. Turkey, in return, has successfully assumed its responsibilities in defending the common values of the Alliance.
Turkey attaches the utmost importance to NATO’s role in maintaining security and stability in the Euro-Atlantic area and in providing a forum for political-military consultations on topics of interest to its members. Indivisibility of Alliance security, solidarity among Allies and a fair risk and burden sharing as well as the consensus rule, are NATO’s guiding principles and should remain as such. Adherence to these principles as well as NATO’s ability to adapt to the changing security environment, have made NATO the most successful military alliance in history.
The success of current and future missions and operations will play a crucial role in shaping NATO’s future. Turkey will continue to provide appropriate support to these operations.
Turkey also supports NATO’s transformation efforts, which are crucial for NATO’s success. It is therefore making substantial contributions to the NATO Response Force. A Force Command at high readiness level is established in Istanbul. Within the new NATO command structure, the air command in Izmir will be replaced by a land command.
The “Partnership for Peace Training Center” was created in 1998 within the Turkish General Staff in an effort to contribute to the training and interoperability efforts of NATO’s partner nations. The Center provides strategic and tactical level training to military and civilian personnel from partner countries.
Turkey welcomes the strategic partnership between NATO and the EU in accordance with the agreed framework between the two organizations. This partnership should be based on mutual support, complementarity and transparency and will contribute to addressing more efficiently existing risks and threats. Turkey’s approach to NATO-EU cooperation is a natural result of its NATO membership and EU membership perspective.
Turkey also strongly supports NATO’s partnerships. Turkey also believes that a constructive relationship based on mutual understanding, transparency and cooperation between NATO and Russia is important for Euro-Atlantic peace and stability and that the NATO-Russia Council provides the necessary forum for such a relationship.
Turkey believes that the integration of all Western Balkan countries in Euro-Atlantic structures is the key to lasting peace and stability in the region. Turkey therefore supports the membership of interested countries, in particular Macedonia and Bosnia and Herzegovina in NATO, the irreversible strengthening of security in Kosovo and the normalization of relations between Serbia and Kosovo.
With the understanding that European security cannot be dissociated from Mediterranean security, Turkey shares the belief that the Mediterranean Dialogue should be strengthened in areas where NATO can bring an added value. Turkey also supports further enhancing the relations with Gulf countries through the Istanbul Cooperation Initiative.
Israeli defense minister says ISIS funded with ‘Turkish money’
https://www.rt.com/news/330204-israel-turkey-isis-oil/
Israel’s defense minister has alleged that the Islamic State terror group has long been funded with “Turkish money.”
"As you know, Daesh (Islamic State, previously ISIS/ISIL) enjoyed Turkish money for oil for a very, very long period of time. I hope that it will be ended," Moshe Yaalon told reporters in Athens on Tuesday after meeting his Greek counterpart, Panos Kammenos, Reuters reports.
Turkey has been thrown under the bus, NATO is complicit in funding ISIS, the people must now examine how ISIS has been used by their own leaders as an ideological weapon to terrorise them.
Exactly, however blind Freddy could see that coming. We ought to have been asking how ISIS has been used by our own leaders as a proxy army of death and fear long ago. Turkey has been doing what the U.S. and Co. have been condoning since the beginning. Funny that Israel made the announcement, hilarious in a sick kind of way.
The Mandarin Reveals He Is an Actor!
https://www.youtube.com/watch?v=1BYWKjY1eRA
War Is A Racket
By Major General Smedley Butler
http://www.ratical.org/ratville/CAH/warisaracket.html
CHAPTER ONE
War Is A Racket
WAR is a racket. It always has been.
It is possibly the oldest, easily the most profitable, surely the most vicious. It is the only one international in scope. It is the only one in which the profits are reckoned in dollars and the losses in lives.
A racket is best described, I believe, as something that is not what it seems to the majority of the people. Only a small "inside" group knows what it is about. It is conducted for the benefit of the very few, at the expense of the very many. Out of war a few people make huge fortunes.
In the World War a mere handful garnered the profits of the conflict. At least 21,000 new millionaires and billionaires were made in the United States during the World War. That many admitted their huge blood gains in their income tax returns. How many other war millionaires falsified their tax returns no one knows.
How many of these war millionaires shouldered a rifle? How many of them dug a trench? How many of them knew what it meant to go hungry in a rat-infested dug-out? How many of them spent sleepless, frightened nights, ducking shells and shrapnel and machine gun bullets? How many of them parried a bayonet thrust of an enemy? How many of them were wounded or killed in battle?
Out of war nations acquire additional territory, if they are victorious. They just take it. This newly acquired territory promptly is exploited by the few -- the selfsame few who wrung dollars out of blood in the war. The general public shoulders the bill.
And what is this bill?
This bill renders a horrible accounting. Newly placed gravestones. Mangled bodies. Shattered minds. Broken hearts and homes. Economic instability. Depression and all its attendant miseries. Back-breaking taxation for generations and generations.
For a great many years, as a soldier, I had a suspicion that war was a racket; not until I retired to civil life did I fully realize it. Now that I see the international war clouds gathering, as they are today, I must face it and speak out.
Again they are choosing sides. France and Russia met and agreed to stand side by side. Italy and Austria hurried to make a similar agreement. Poland and Germany cast sheep's eyes at each other, forgetting for the nonce [one unique occasion], their dispute over the Polish Corridor.
The assassination of King Alexander of Jugoslavia [Yugoslavia] complicated matters. Jugoslavia and Hungary, long bitter enemies, were almost at each other's throats. Italy was ready to jump in. But France was waiting. So was Czechoslovakia. All of them are looking ahead to war. Not the people -- not those who fight and pay and die -- only those who foment wars and remain safely at home to profit.
There are 40,000,000 men under arms in the world today, and our statesmen and diplomats have the temerity to say that war is not in the making.
Hell's bells! Are these 40,000,000 men being trained to be dancers?
Not in Italy, to be sure. Premier Mussolini knows what they are being trained for. He, at least, is frank enough to speak out. Only the other day, Il Duce in "International Conciliation," the publication of the Carnegie Endowment for International Peace, said:
    "And above all, Fascism, the more it considers and observes the future and the development of humanity quite apart from political considerations of the moment, believes neither in the possibility nor the utility of perpetual peace. . . . War alone brings up to its highest tension all human energy and puts the stamp of nobility upon the people who have the courage to meet it."
Undoubtedly Mussolini means exactly what he says. His well-trained army, his great fleet of planes, and even his navy are ready for war -- anxious for it, apparently. His recent stand at the side of Hungary in the latter's dispute with Jugoslavia showed that. And the hurried mobilization of his troops on the Austrian border after the assassination of Dollfuss showed it too. There are others in Europe too whose sabre rattling presages war, sooner or later.
Herr Hitler, with his rearming Germany and his constant demands for more and more arms, is an equal if not greater menace to peace. France only recently increased the term of military service for its youth from a year to eighteen months.
Yes, all over, nations are camping in their arms. The mad dogs of Europe are on the loose. In the Orient the maneuvering is more adroit. Back in 1904, when Russia and Japan fought, we kicked out our old friends the Russians and backed Japan. Then our very generous international bankers were financing Japan. Now the trend is to poison us against the Japanese. What does the "open door" policy to China mean to us? Our trade with China is about $90,000,000 a year. Or the Philippine Islands? We have spent about $600,000,000 in the Philippines in thirty-five years and we (our bankers and industrialists and speculators) have private investments there of less than $200,000,000.
Then, to save that China trade of about $90,000,000, or to protect these private investments of less than $200,000,000 in the Philippines, we would be all stirred up to hate Japan and go to war -- a war that might well cost us tens of billions of dollars, hundreds of thousands of lives of Americans, and many more hundreds of thousands of physically maimed and mentally unbalanced men.
Of course, for this loss, there would be a compensating profit -- fortunes would be made. Millions and billions of dollars would be piled up. By a few. Munitions makers. Bankers. Ship builders. Manufacturers. Meat packers. Speculators. They would fare well.
Yes, they are getting ready for another war. Why shouldn't they? It pays high dividends.
But what does it profit the men who are killed? What does it profit their mothers and sisters, their wives and their sweethearts? What does it profit their children?
What does it profit anyone except the very few to whom war means huge profits?
Yes, and what does it profit the nation?
Take our own case. Until 1898 we didn't own a bit of territory outside the mainland of North America. At that time our national debt was a little more than $1,000,000,000. Then we became "internationally minded." We forgot, or shunted aside, the advice of the Father of our country. We forgot George Washington's warning about "entangling alliances." We went to war. We acquired outside territory. At the end of the World War period, as a direct result of our fiddling in international affairs, our national debt had jumped to over $25,000,000,000. Our total favorable trade balance during the twenty-five-year period was about $24,000,000,000. Therefore, on a purely bookkeeping basis, we ran a little behind year for year, and that foreign trade might well have been ours without the wars.
It would have been far cheaper (not to say safer) for the average American who pays the bills to stay out of foreign entanglements. For a very few this racket, like bootlegging and other underworld rackets, brings fancy profits, but the cost of operations is always transferred to the people -- who do not profit.
CHAPTER TWO
Who Makes The Profits?
 The World War, rather our brief participation in it, has cost the United States some $52,000,000,000. Figure it out. That means $400 to every American man, woman, and child. And we haven't paid the debt yet. We are paying it, our children will pay it, and our children's children probably still will be paying the cost of that war.
The normal profits of a business concern in the United States are six, eight, ten, and sometimes twelve percent. But war-time profits -- ah! that is another matter -- twenty, sixty, one hundred, three hundred, and even eighteen hundred per cent -- the sky is the limit. All that traffic will bear. Uncle Sam has the money. Let's get it.
Of course, it isn't put that crudely in war time. It is dressed into speeches about patriotism, love of country, and "we must all put our shoulders to the wheel," but the profits jump and leap and skyrocket -- and are safely pocketed. Let's just take a few examples:
Take our friends the du Ponts, the powder people -- didn't one of them testify before a Senate committee recently that their powder won the war? Or saved the world for democracy? Or something? How did they do in the war? They were a patriotic corporation. Well, the average earnings of the du Ponts for the period 1910 to 1914 were $6,000,000 a year. It wasn't much, but the du Ponts managed to get along on it. Now let's look at their average yearly profit during the war years, 1914 to 1918. Fifty-eight million dollars a year profit we find! Nearly ten times that of normal times, and the profits of normal times were pretty good. An increase in profits of more than 950 per cent.
Take one of our little steel companies that patriotically shunted aside the making of rails and girders and bridges to manufacture war materials. Well, their 1910-1914 yearly earnings averaged $6,000,000. Then came the war. And, like loyal citizens, Bethlehem Steel promptly turned to munitions making. Did their profits jump -- or did they let Uncle Sam in for a bargain? Well, their 1914-1918 average was $49,000,000 a year!
Or, let's take United States Steel. The normal earnings during the five-year period prior to the war were $105,000,000 a year. Not bad. Then along came the war and up went the profits. The average yearly profit for the period 1914-1918 was $240,000,000. Not bad.
There you have some of the steel and powder earnings. Let's look at something else. A little copper, perhaps. That always does well in war times.
Anaconda, for instance. Average yearly earnings during the pre-war years 1910-1914 of $10,000,000. During the war years 1914-1918 profits leaped to $34,000,000 per year.
Or Utah Copper. Average of $5,000,000 per year during the 1910-1914 period. Jumped to an average of $21,000,000 yearly profits for the war period.
Let's group these five, with three smaller companies. The total yearly average profits of the pre-war period 1910-1914 were $137,480,000. Then along came the war. The average yearly profits for this group skyrocketed to $408,300,000.
A little increase in profits of approximately 200 per cent.
Does war pay? It paid them. But they aren't the only ones. There are still others. Let's take leather.
For the three-year period before the war the total profits of Central Leather Company were $3,500,000. That was approximately $1,167,000 a year. Well, in 1916 Central Leather returned a profit of $15,000,000, a small increase of 1,100 per cent. That's all. The General Chemical Company averaged a profit for the three years before the war of a little over $800,000 a year. Came the war, and the profits jumped to $12,000,000. a leap of 1,400 per cent.
International Nickel Company -- and you can't have a war without nickel -- showed an increase in profits from a mere average of $4,000,000 a year to $73,000,000 yearly. Not bad? An increase of more than 1,700 per cent.
American Sugar Refining Company averaged $2,000,000 a year for the three years before the war. In 1916 a profit of $6,000,000 was recorded.
Listen to Senate Document No. 259. The Sixty-Fifth Congress, reporting on corporate earnings and government revenues. Considering the profits of 122 meat packers, 153 cotton manufacturers, 299 garment makers, 49 steel plants, and 340 coal producers during the war. Profits under 25 per cent were exceptional. For instance the coal companies made between 100 per cent and 7,856 per cent on their capital stock during the war. The Chicago packers doubled and tripled their earnings.
And let us not forget the bankers who financed the great war. If anyone had the cream of the profits it was the bankers. Being partnerships rather than incorporated organizations, they do not have to report to stockholders. And their profits were as secret as they were immense. How the bankers made their millions and their billions I do not know, because those little secrets never become public -- even before a Senate investigatory body.
But here's how some of the other patriotic industrialists and speculators chiseled their way into war profits.
Take the shoe people. They like war. It brings business with abnormal profits. They made huge profits on sales abroad to our allies. Perhaps, like the munitions manufacturers and armament makers, they also sold to the enemy. For a dollar is a dollar whether it comes from Germany or from France. But they did well by Uncle Sam too. For instance, they sold Uncle Sam 35,000,000 pairs of hobnailed service shoes. There were 4,000,000 soldiers. Eight pairs, and more, to a soldier. My regiment during the war had only one pair to a soldier. Some of these shoes probably are still in existence. They were good shoes. But when the war was over Uncle Sam has a matter of 25,000,000 pairs left over. Bought -- and paid for. Profits recorded and pocketed.
There was still lots of leather left. So the leather people sold your Uncle Sam hundreds of thousands of McClellan saddles for the cavalry. But there wasn't any American cavalry overseas! Somebody had to get rid of this leather, however. Somebody had to make a profit in it -- so we had a lot of McClellan saddles. And we probably have those yet.
Also somebody had a lot of mosquito netting. They sold your Uncle Sam 20,000,000 mosquito nets for the use of the soldiers overseas. I suppose the boys were expected to put it over them as they tried to sleep in muddy trenches -- one hand scratching cooties on their backs and the other making passes at scurrying rats. Well, not one of these mosquito nets ever got to France!
Anyhow, these thoughtful manufacturers wanted to make sure that no soldier would be without his mosquito net, so 40,000,000 additional yards of mosquito netting were sold to Uncle Sam.
There were pretty good profits in mosquito netting in those days, even if there were no mosquitoes in France. I suppose, if the war had lasted just a little longer, the enterprising mosquito netting manufacturers would have sold your Uncle Sam a couple of consignments of mosquitoes to plant in France so that more mosquito netting would be in order.
Airplane and engine manufacturers felt they, too, should get their just profits out of this war. Why not? Everybody else was getting theirs. So $1,000,000,000 -- count them if you live long enough -- was spent by Uncle Sam in building airplane engines that never left the ground! Not one plane, or motor, out of the billion dollars worth ordered, ever got into a battle in France. Just the same the manufacturers made their little profit of 30, 100, or perhaps 300 per cent.
Undershirts for soldiers cost 14¢ [cents] to make and uncle Sam paid 30¢ to 40¢ each for them -- a nice little profit for the undershirt manufacturer. And the stocking manufacturer and the uniform manufacturers and the cap manufacturers and the steel helmet manufacturers -- all got theirs.
Why, when the war was over some 4,000,000 sets of equipment -- knapsacks and the things that go to fill them -- crammed warehouses on this side. Now they are being scrapped because the regulations have changed the contents. But the manufacturers collected their wartime profits on them -- and they will do it all over again the next time.
There were lots of brilliant ideas for profit making during the war.
One very versatile patriot sold Uncle Sam twelve dozen 48-inch wrenches. Oh, they were very nice wrenches. The only trouble was that there was only one nut ever made that was large enough for these wrenches. That is the one that holds the turbines at Niagara Falls. Well, after Uncle Sam had bought them and the manufacturer had pocketed the profit, the wrenches were put on freight cars and shunted all around the United States in an effort to find a use for them. When the Armistice was signed it was indeed a sad blow to the wrench manufacturer. He was just about to make some nuts to fit the wrenches. Then he planned to sell these, too, to your Uncle Sam.
Still another had the brilliant idea that colonels shouldn't ride in automobiles, nor should they even ride on horseback. One has probably seen a picture of Andy Jackson riding in a buckboard. Well, some 6,000 buckboards were sold to Uncle Sam for the use of colonels! Not one of them was used. But the buckboard manufacturer got his war profit.
The shipbuilders felt they should come in on some of it, too. They built a lot of ships that made a lot of profit. More than $3,000,000,000 worth. Some of the ships were all right. But $635,000,000 worth of them were made of wood and wouldn't float! The seams opened up -- and they sank. We paid for them, though. And somebody pocketed the profits.
It has been estimated by statisticians and economists and researchers that the war cost your Uncle Sam $52,000,000,000. Of this sum, $39,000,000,000 was expended in the actual war itself. This expenditure yielded $16,000,000,000 in profits. That is how the 21,000 billionaires and millionaires got that way. This $16,000,000,000 profits is not to be sneezed at. It is quite a tidy sum. And it went to a very few.
The Senate (Nye) committee probe of the munitions industry and its wartime profits, despite its sensational disclosures, hardly has scratched the surface.
Even so, it has had some effect. The State Department has been studying "for some time" methods of keeping out of war. The War Department suddenly decides it has a wonderful plan to spring. The Administration names a committee -- with the War and Navy Departments ably represented under the chairmanship of a Wall Street speculator -- to limit profits in war time. To what extent isn't suggested. Hmmm. Possibly the profits of 300 and 600 and 1,600 per cent of those who turned blood into gold in the World War would be limited to some smaller figure.
Apparently, however, the plan does not call for any limitation of losses -- that is, the losses of those who fight the war. As far as I have been able to ascertain there is nothing in the scheme to limit a soldier to the loss of but one eye, or one arm, or to limit his wounds to one or two or three. Or to limit the loss of life.
There is nothing in this scheme, apparently, that says not more than 12 per cent of a regiment shall be wounded in battle, or that not more than 7 per cent in a division shall be killed.
Of course, the committee cannot be bothered with such trifling matters.
CHAPTER THREE
Who Pays The Bills?
Who provides the profits -- these nice little profits of 20, 100, 300, 1,500 and 1,800 per cent? We all pay them -- in taxation. We paid the bankers their profits when we bought Liberty Bonds at $100.00 and sold them back at $84 or $86 to the bankers. These bankers collected $100 plus. It was a simple manipulation. The bankers control the security marts. It was easy for them to depress the price of these bonds. Then all of us -- the people -- got frightened and sold the bonds at $84 or $86. The bankers bought them. Then these same bankers stimulated a boom and government bonds went to par -- and above. Then the bankers collected their profits.
But the soldier pays the biggest part of the bill.
If you don't believe this, visit the American cemeteries on the battlefields abroad. Or visit any of the veteran's hospitals in the United States. On a tour of the country, in the midst of which I am at the time of this writing, I have visited eighteen government hospitals for veterans. In them are a total of about 50,000 destroyed men -- men who were the pick of the nation eighteen years ago. The very able chief surgeon at the government hospital; at Milwaukee, where there are 3,800 of the living dead, told me that mortality among veterans is three times as great as among those who stayed at home.
Boys with a normal viewpoint were taken out of the fields and offices and factories and classrooms and put into the ranks. There they were remolded; they were made over; they were made to "about face"; to regard murder as the order of the day. They were put shoulder to shoulder and, through mass psychology, they were entirely changed. We used them for a couple of years and trained them to think nothing at all of killing or of being killed.
Then, suddenly, we discharged them and told them to make another "about face" ! This time they had to do their own readjustment, sans [without] mass psychology, sans officers' aid and advice and sans nation-wide propaganda. We didn't need them any more. So we scattered them about without any "three-minute" or "Liberty Loan" speeches or parades. Many, too many, of these fine young boys are eventually destroyed, mentally, because they could not make that final "about face" alone.
In the government hospital in Marion, Indiana, 1,800 of these boys are in pens! Five hundred of them in a barracks with steel bars and wires all around outside the buildings and on the porches. These already have been mentally destroyed. These boys don't even look like human beings. Oh, the looks on their faces! Physically, they are in good shape; mentally, they are gone.
There are thousands and thousands of these cases, and more and more are coming in all the time. The tremendous excitement of the war, the sudden cutting off of that excitement -- the young boys couldn't stand it.
That's a part of the bill. So much for the dead -- they have paid their part of the war profits. So much for the mentally and physically wounded -- they are paying now their share of the war profits. But the others paid, too -- they paid with heartbreaks when they tore themselves away from their firesides and their families to don the uniform of Uncle Sam -- on which a profit had been made. They paid another part in the training camps where they were regimented and drilled while others took their jobs and their places in the lives of their communities. The paid for it in the trenches where they shot and were shot; where they were hungry for days at a time; where they slept in the mud and the cold and in the rain -- with the moans and shrieks of the dying for a horrible lullaby.
But don't forget -- the soldier paid part of the dollars and cents bill too.
Up to and including the Spanish-American War, we had a prize system, and soldiers and sailors fought for money. During the Civil War they were paid bonuses, in many instances, before they went into service. The government, or states, paid as high as $1,200 for an enlistment. In the Spanish-American War they gave prize money. When we captured any vessels, the soldiers all got their share -- at least, they were supposed to. Then it was found that we could reduce the cost of wars by taking all the prize money and keeping it, but conscripting [drafting] the soldier anyway. Then soldiers couldn't bargain for their labor, Everyone else could bargain, but the soldier couldn't.
Napoleon once said,
    "All men are enamored of decorations . . . they positively hunger for them."
So by developing the Napoleonic system -- the medal business -- the government learned it could get soldiers for less money, because the boys liked to be decorated. Until the Civil War there were no medals. Then the Congressional Medal of Honor was handed out. It made enlistments easier. After the Civil War no new medals were issued until the Spanish-American War.
In the World War, we used propaganda to make the boys accept conscription. They were made to feel ashamed if they didn't join the army.
So vicious was this war propaganda that even God was brought into it. With few exceptions our clergymen joined in the clamor to kill, kill, kill. To kill the Germans. God is on our side . . . it is His will that the Germans be killed.
And in Germany, the good pastors called upon the Germans to kill the allies . . . to please the same God. That was a part of the general propaganda, built up to make people war conscious and murder conscious.
Beautiful ideals were painted for our boys who were sent out to die. This was the "war to end all wars." This was the "war to make the world safe for democracy." No one mentioned to them, as they marched away, that their going and their dying would mean huge war profits. No one told these American soldiers that they might be shot down by bullets made by their own brothers here. No one told them that the ships on which they were going to cross might be torpedoed by submarines built with United States patents. They were just told it was to be a "glorious adventure."
Thus, having stuffed patriotism down their throats, it was decided to make them help pay for the war, too. So, we gave them the large salary of $30 a month.
All they had to do for this munificent sum was to leave their dear ones behind, give up their jobs, lie in swampy trenches, eat canned willy (when they could get it) and kill and kill and kill . . . and be killed.
But wait!
Half of that wage (just a little more than a riveter in a shipyard or a laborer in a munitions factory safe at home made in a day) was promptly taken from him to support his dependents, so that they would not become a charge upon his community. Then we made him pay what amounted to accident insurance -- something the employer pays for in an enlightened state -- and that cost him $6 a month. He had less than $9 a month left.
Then, the most crowning insolence of all -- he was virtually blackjacked into paying for his own ammunition, clothing, and food by being made to buy Liberty Bonds. Most soldiers got no money at all on pay days.
We made them buy Liberty Bonds at $100 and then we bought them back -- when they came back from the war and couldn't find work -- at $84 and $86. And the soldiers bought about $2,000,000,000 worth of these bonds!
Yes, the soldier pays the greater part of the bill. His family pays too. They pay it in the same heart-break that he does. As he suffers, they suffer. At nights, as he lay in the trenches and watched shrapnel burst about him, they lay home in their beds and tossed sleeplessly -- his father, his mother, his wife, his sisters, his brothers, his sons, and his daughters.
When he returned home minus an eye, or minus a leg or with his mind broken, they suffered too -- as much as and even sometimes more than he. Yes, and they, too, contributed their dollars to the profits of the munitions makers and bankers and shipbuilders and the manufacturers and the speculators made. They, too, bought Liberty Bonds and contributed to the profit of the bankers after the Armistice in the hocus-pocus of manipulated Liberty Bond prices.
And even now the families of the wounded men and of the mentally broken and those who never were able to readjust themselves are still suffering and still paying.
CHAPTER FOUR
How To Smash This Racket!
WELL, it's a racket, all right.
A few profit -- and the many pay. But there is a way to stop it. You can't end it by disarmament conferences. You can't eliminate it by peace parleys at Geneva. Well-meaning but impractical groups can't wipe it out by resolutions. It can be smashed effectively only by taking the profit out of war.
The only way to smash this racket is to conscript capital and industry and labor before the nations manhood can be conscripted. One month before the Government can conscript the young men of the nation -- it must conscript capital and industry and labor. Let the officers and the directors and the high-powered executives of our armament factories and our munitions makers and our shipbuilders and our airplane builders and the manufacturers of all the other things that provide profit in war time as well as the bankers and the speculators, be conscripted -- to get $30 a month, the same wage as the lads in the trenches get.
Let the workers in these plants get the same wages -- all the workers, all presidents, all executives, all directors, all managers, all bankers -- yes, and all generals and all admirals and all officers and all politicians and all government office holders -- everyone in the nation be restricted to a total monthly income not to exceed that paid to the soldier in the trenches!
Let all these kings and tycoons and masters of business and all those workers in industry and all our senators and governors and majors pay half of their monthly $30 wage to their families and pay war risk insurance and buy Liberty Bonds.
Why shouldn't they?
They aren't running any risk of being killed or of having their bodies mangled or their minds shattered. They aren't sleeping in muddy trenches. They aren't hungry. The soldiers are!
Give capital and industry and labor thirty days to think it over and you will find, by that time, there will be no war. That will smash the war racket -- that and nothing else.
Maybe I am a little too optimistic. Capital still has some say. So capital won't permit the taking of the profit out of war until the people -- those who do the suffering and still pay the price -- make up their minds that those they elect to office shall do their bidding, and not that of the profiteers.
Another step necessary in this fight to smash the war racket is the limited plebiscite to determine whether a war should be declared. A plebiscite not of all the voters but merely of those who would be called upon to do the fighting and dying. There wouldn't be very much sense in having a 76-year-old president of a munitions factory or the flat-footed head of an international banking firm or the cross-eyed manager of a uniform manufacturing plant -- all of whom see visions of tremendous profits in the event of war -- voting on whether the nation should go to war or not. They never would be called upon to shoulder arms -- to sleep in a trench and to be shot. Only those who would be called upon to risk their lives for their country should have the privilege of voting to determine whether the nation should go to war.
There is ample precedent for restricting the voting to those affected. Many of our states have restrictions on those permitted to vote. In most, it is necessary to be able to read and write before you may vote. In some, you must own property. It would be a simple matter each year for the men coming of military age to register in their communities as they did in the draft during the World War and be examined physically. Those who could pass and who would therefore be called upon to bear arms in the event of war would be eligible to vote in a limited plebiscite. They should be the ones to have the power to decide -- and not a Congress few of whose members are within the age limit and fewer still of whom are in physical condition to bear arms. Only those who must suffer should have the right to vote.
A third step in this business of smashing the war racket is to make certain that our military forces are truly forces for defense only.
At each session of Congress the question of further naval appropriations comes up. The swivel-chair admirals of Washington (and there are always a lot of them) are very adroit lobbyists. And they are smart. They don't shout that "We need a lot of battleships to war on this nation or that nation." Oh no. First of all, they let it be known that America is menaced by a great naval power. Almost any day, these admirals will tell you, the great fleet of this supposed enemy will strike suddenly and annihilate 125,000,000 people. Just like that. Then they begin to cry for a larger navy. For what? To fight the enemy? Oh my, no. Oh, no. For defense purposes only.
Then, incidentally, they announce maneuvers in the Pacific. For defense. Uh, huh.
The Pacific is a great big ocean. We have a tremendous coastline on the Pacific. Will the maneuvers be off the coast, two or three hundred miles? Oh, no. The maneuvers will be two thousand, yes, perhaps even thirty-five hundred miles, off the coast.
The Japanese, a proud people, of course will be pleased beyond expression to see the united States fleet so close to Nippon's shores. Even as pleased as would be the residents of California were they to dimly discern through the morning mist, the Japanese fleet playing at war games off Los Angeles.
The ships of our navy, it can be seen, should be specifically limited, by law, to within 200 miles of our coastline. Had that been the law in 1898 the Maine would never have gone to Havana Harbor. She never would have been blown up. There would have been no war with Spain with its attendant loss of life. Two hundred miles is ample, in the opinion of experts, for defense purposes. Our nation cannot start an offensive war if its ships can't go further than 200 miles from the coastline. Planes might be permitted to go as far as 500 miles from the coast for purposes of reconnaissance. And the army should never leave the territorial limits of our nation.
To summarize: Three steps must be taken to smash the war racket.
    We must take the profit out of war.
    We must permit the youth of the land who would bear arms to decide whether or not there should be war.
    We must limit our military forces to home defense purposes.
CHAPTER FIVE
To Hell With War!
I am not a fool as to believe that war is a thing of the past. I know the people do not want war, but there is no use in saying we cannot be pushed into another war.
Looking back, Woodrow Wilson was re-elected president in 1916 on a platform that he had "kept us out of war" and on the implied promise that he would "keep us out of war." Yet, five months later he asked Congress to declare war on Germany.
In that five-month interval the people had not been asked whether they had changed their minds. The 4,000,000 young men who put on uniforms and marched or sailed away were not asked whether they wanted to go forth to suffer and die.
Then what caused our government to change its mind so suddenly?
Money.
An allied commission, it may be recalled, came over shortly before the war declaration and called on the President. The President summoned a group of advisers. The head of the commission spoke. Stripped of its diplomatic language, this is what he told the President and his group:
    "There is no use kidding ourselves any longer. The cause of the allies is lost. We now owe you (American bankers, American munitions makers, American manufacturers, American speculators, American exporters) five or six billion dollars.
    If we lose (and without the help of the United States we must lose) we, England, France and Italy, cannot pay back this money . . . and Germany won't.
    So . . . "
Had secrecy been outlawed as far as war negotiations were concerned, and had the press been invited to be present at that conference, or had radio been available to broadcast the proceedings, America never would have entered the World War. But this conference, like all war discussions, was shrouded in utmost secrecy. When our boys were sent off to war they were told it was a "war to make the world safe for democracy" and a "war to end all wars."
Well, eighteen years after, the world has less of democracy than it had then. Besides, what business is it of ours whether Russia or Germany or England or France or Italy or Austria live under democracies or monarchies? Whether they are Fascists or Communists? Our problem is to preserve our own democracy.
And very little, if anything, has been accomplished to assure us that the World War was really the war to end all wars.
Yes, we have had disarmament conferences and limitations of arms conferences. They don't mean a thing. One has just failed; the results of another have been nullified. We send our professional soldiers and our sailors and our politicians and our diplomats to these conferences. And what happens?
The professional soldiers and sailors don't want to disarm. No admiral wants to be without a ship. No general wants to be without a command. Both mean men without jobs. They are not for disarmament. They cannot be for limitations of arms. And at all these conferences, lurking in the background but all-powerful, just the same, are the sinister agents of those who profit by war. They see to it that these conferences do not disarm or seriously limit armaments.
The chief aim of any power at any of these conferences has not been to achieve disarmament to prevent war but rather to get more armament for itself and less for any potential foe.
There is only one way to disarm with any semblance of practicability. That is for all nations to get together and scrap every ship, every gun, every rifle, every tank, every war plane. Even this, if it were possible, would not be enough.
The next war, according to experts, will be fought not with battleships, not by artillery, not with rifles and not with machine guns. It will be fought with deadly chemicals and gases.
Secretly each nation is studying and perfecting newer and ghastlier means of annihilating its foes wholesale. Yes, ships will continue to be built, for the shipbuilders must make their profits. And guns still will be manufactured and powder and rifles will be made, for the munitions makers must make their huge profits. And the soldiers, of course, must wear uniforms, for the manufacturer must make their war profits too.
But victory or defeat will be determined by the skill and ingenuity of our scientists.
If we put them to work making poison gas and more and more fiendish mechanical and explosive instruments of destruction, they will have no time for the constructive job of building greater prosperity for all peoples. By putting them to this useful job, we can all make more money out of peace than we can out of war -- even the munitions makers.
So...I say,
TO HELL WITH WAR!
Everyman decries immorality
This ship is sinking
http://freecriticalthinking.org/daily-pickings/1616-this-ship-is-sinking
Published on Tuesday, 15 December 2015 09:28
Not one of your pinko, leftist, anti-war folk but a U.S. Army Colonel, Lawrence Wilkerson, former national security advisor to the Reagan administration who spent years as an assistant to Secretary of State Colin Powell during both Bush administrations, paints a gloomy picture of the US empire which he says is coming to an ignominious end.
He explains how the military-industrial bureaucratic complex is now unstoppable in its drive for perpetual war. As an example, he explains the recent massive US bombing onslaught in Syria has depleted "ordinance" (ie. missiles and bombs) and that Raytheon, Boeing, Lockheed Martin et al are salivating over the renewed momentum for war refilling their order books. He confirms Critical Thinking's contention, that winning is not important; the objective is perpetual war.
Evidence emerges daily of US (and others') culpability in creating, arming and supporting ISIS; a situation which becomes increasingly hard to hide. Even mainstream media are flirting with the idea in terms of specific detail but nowhere, in political discourse, is the obvious being stated: that ISIS is a NATO/Israel asset deliberately fostered to justify perpetual war and the totalitarian state.
Fascism
https://en.wikipedia.org/wiki/Fascism
Fascism /ˈfæʃɪzəm/ is a form of radical authoritarian nationalism[1][2] that came to prominence in early 20th-century Europe. Influenced by national syndicalism, fascism originated in Italy during World War I, in opposition to liberalism, Marxism, and anarchism. Fascism is usually placed on the far-right within the traditional left–right spectrum.[3][4]
Fascists saw World War I as a revolution that brought massive changes in the nature of war, society, the state, and technology. The advent of total war and total mass mobilization of society had broken down the distinction between civilian and combatant. A "military citizenship" arose in which all citizens were involved with the military in some manner during the war.[5][6] The war had resulted in the rise of a powerful state capable of mobilizing millions of people to serve on the front lines and providing economic production and logistics to support them, as well as having unprecedented authority to intervene in the lives of citizens.[5][6] Fascists view World War I as having made liberal democracy obsolete, and regard total mobilization of society under a totalitarian one-party state as necessary to prepare a nation for armed conflict and to respond effectively to economic difficulties.[7] Such a state is led by a strong leader — such as a dictator and a martial government composed of the members of the governing fascist party — to forge national unity and maintain a stable and orderly society.[7] Fascism rejects assertions that violence is automatically negative in nature, and views political violence, war, and imperialism as means that can achieve national rejuvenation.[8][9][10][11]
Fascists advocate a mixed economy, with the principal goal of achieving autarky through protectionist and interventionist economic policies.[12] Following World War II, few parties have openly described themselves as fascist, and the term is usually used pejoratively by political opponents. The terms neo-fascist or post-fascist are sometimes applied more formally to describe parties of the far right with ideologies similar to, or rooted in, 20th century fascist movements.[13]
West’s lack of morals & disregard for law caused current political crisis – Duma speaker
https://www.rt.com/politics/330860-duma-speaker-blames-west-for/
Published time: 1 Feb, 2016 13:13
The increasing crisis in international relations is rooted in Western nations’ lack of morals and their reluctance to observe basic norms of international law, State Duma chairman Sergey Naryshkin has said.
“The tensions in the international situation have seriously increased over the past few years and this happens primarily because a group of Western nations, first of all, the United States of America, are neglecting the major principles of international law or interpret them freely,” Interfax quoted the Russian parliamentary leader as saying at a meeting with law students on Monday.
“I would be more direct – it happens due to the lack of morals,” Naryshkin added. He emphasized that the argument of “American exceptionalism” often used by many US politicians was against not only the legal principle of equality of all nations and peoples, but also contradicted basic human morality.
The Duma speaker also said that at the moment he considered Russia as the key protector of the basic foundations of international law. He noted that as one of the victor nations in World War II, Russia played a decisive role in introducing international law and that it had paid a great price for this achievement.
In May 2015, Naryshkin published an article in the Rossiiskaya Gazeta daily in which he urged European politicians to stop heeding advice from the United States and to start working on common Eurasian economic interests with Russia. If this doesn’t happen, Washington will eventually destroy the EU’s economic sovereignty by skillful manipulation of WTO mechanisms, Naryshkin wrote.
Naryshkin has also backed the idea of a future merger between the Russian Federation and the European Union, and in April 2015 he suggested immediately starting consultations. The idea of the possibility of such a merger originally came from Czech President Milos Zeman, who confessed to having a dream that one day Russia would join the EU.
War Crimes: Were the Nuremberg Tribunals Only Victors’ Justice?
http://www.globalresearch.ca/were-the-nuremberg-tribunals-only-victors-justice/5405078
By Elliott Adams
Global Research, September 29, 2014
On the surface, The Nuremberg Tribunals were a court assembled by the victors which prosecuted the losers.  It is also true Axis war criminals were tried though Allied war criminals were not. But there was a greater concern at the time about stopping wars of aggression than prosecuting individual war criminals, since no one thought the world could survive one more world war.  The intent was not retribution but to find a new way forward.  The Tribunal in its Judgment said “Crimes against international law are committed by men, not by abstract entities, and only by punishing individuals who commit such crimes can the provisions of international law be enforced.”
Nuremberg was starkly different from the typical case of victor’s justice of the time. With Nuremberg the victors turned away from the accepted vindictive punishment of the vanquished. The motivation to punish those who started a war which killed seventy two million, including sixty one million on the victor’s side, was immense.  Justice Robert Jackson, US Supreme Court Justice and the main architect of the Nuremberg Tribunals,  said in the opening statement of the Tribunals “The wrongs which we seek to condemn and punish have been so calculated, so malignant, and so devastating, that civilization cannot tolerate their being ignored, because it cannot survive their being repeated.” Stalin proposed a suitable deterrent would be executing the top 50,000 living German leaders.  Given the wanton killing on the Eastern Front experienced by the Russians, it is easy to understand how he considered this to be appropriate.  Churchill countered that executing the top 5,000 would be enough blood to assure it would not happen again.
The victorious powers instead set a new path, one of criminal trials, the Nuremberg and Tokyo Tribunals. Justice Jackson declared “That four great nations, flushed with victory and stung with injury, stay the hand of vengeance and voluntarily submit their captive enemies to the judgment of the law is one of the most significant tributes that Power has ever paid to Reason.”
Acknowledged as imperfect, Nuremberg was an effort to establish the rule of law to deal with sociopathic and despotic leaders and their followers who would start wars of aggression. “This Tribunal, while it is novel and experimental, represents the practical effort of four of the most mighty of nations, with the support of seventeen more, to utilize international law to meet the greatest menace of our times – aggressive war.” said Jackson. The experiment provided that each defendant be indicted, have the right to a defense before a court, similar to a civilian court. And there seems to have been some level of justice since some were found completely innocent, some were only found guilty of some charges and most were not executed. Whether this was just a victor’s court dressed up in fancy trappings of justice or the first faulting steps of a new way forward would depend on what happened in the years after, even what happens now. Some of what is accepted as normal today comes to us from Nuremberg like the terms war crimes, crimes against humanity.
Jackson said “We must never forget that the record on which we judge these defendants is the record on which history will judge us tomorrow. To pass these defendants a poisoned chalice is to put it to our own lips as well.” They knew they were only writing the first part of the story of Nuremberg and that others would write the ending. We can answer this question about victor’s justice by looking just at 1946. Or we can take a broader perspective and answer it in terms of today and of the future, in terms of the long term results from Nuremberg.
Whether it was justice only for the benefit of the victors is our challenge.  Will we let international law be a tool only for the powerful? Or will we use Nuremberg as a tool for “Reason over Power”? If we let the Nuremberg Principles be used only against the enemies of the powerful it will have been victor’s justice and we will be “putting the poisoned chalice to our own lips.”  If instead we, we the people, work, demand and, succeed in holding our own high criminals and government up to these same laws it will not have been a victor’s court.  Justice Jackson’s words are an important guide today, “The common sense of mankind demands that law shall not stop with the punishment of petty crimes by little people. It must also reach men who possess themselves of great power and make deliberate and concerted use of it to set in motion evils.”
Going back to the original question – Were the Nuremberg Tribunals only victor’s justice? – that depends on us – that depends on you. Will we prosecute our own high war criminals?  Will we respect and use the obligations of Nuremberg to oppose our government’s crimes against humanity and crimes against peace?
Elliott Adams was a soldier, a politician, a businessman; now he works for peace.  His interest in international law grew out of his experience in war, in places of conflict like Gaza, and being on trial for peace activism.
Russian jets + American boots = Neocon madness in Syria
https://www.rt.com/op-edge/331047-russia-us-syria-neocons/
Is it just coincidence that shortly after Russia begins a successful bombing campaign against Islamic State (IS, formerly ISIS/ISIL) positions in Syria, US think-tanks suddenly called for American boots on the ground in the Arab Republic?
The US military has some of the world’s most advanced surveillance technology, capable of identifying suspected terrorists and eliminating them with state-of-the-art unmanned aerial vehicles (UAVs). So why do US neocons insist that the only way to beat Islamic State forces in Syria is to put boots on the ground?
Certainly not because the strategy has worked so effectively in the past. One possible explanation is that putting boots on the ground in Syria is an incredibly dangerous backdoor maneuver to foil Russia's air campaign against Islamic State.
Neocons on the warpath
Robert Kagan, senior analyst at the Brookings Institution and co-founder of the now-defunct Project for the New American Century, is now calling for boots on the ground in Syria, despite warnings from a veritable army of military brass, like retired four-star General David Petraeus, that such a plan is “not sustainable.”
But the warnings of Petraeus and others will be predictably ignored. After all, US officials never miss an opportunity of proving Winston Churchill’s adage that “Americans can always be counted on to do the right thing… after they have exhausted all other possibilities.” So Kagan's unfathomably insane idea is now being endorsed by several hawkish Republicans, like New Jersey Gov. Chris Christie, Florida Governor Jeb Bush and Senator Marco Rubio.
But considering some of the highly disturbing comments uttered of late by Hillary Clinton, a Democrat with a very real chance of becoming the next US president, it is clear one does not have to be a Republican to uphold nutty neocon doctrine.
Hillary Clinton "We Came, We Saw, He Died" (Gaddafi)
https://www.youtube.com/watch?v=FmIRYvJQeHM
Any guesses what country the young men and women will come from who will fill those boots and spill their blood? Yes, of course, the United States of America, which, thanks to ‘analysts’ like Kagan, is quickly moving from being the world’s “exceptional nation” to the world’s “expendable nation.”
In a recent essay, the analyst laid out his master disaster plan for both Syria and the United States.
“America will have to take the lead, provide the troops, supply the bulk of the air power and pull together those willing and able to join the effort…” crowed Kagan, who went on to emphasize the operation would require not only US air power “but ground troops numbering up to 30,000.”
Further on, he proposes “a further 10,000 to 20,000 U.S. troops — or 40,000 to 50,000 in total — to uproot [ISIS] from the haven it has created in Syria and to help local forces uproot it in Iraq.”
Amazing how easy it is to manipulate the lives of young men and women the greater their numbers become.
In another article (‘America's Dangerous Aversion to Conflict, Sept. 5, 2014), Kagan actually expressed disappointment that a majority of the American people “seem to have come close to concluding not only that war is horrible but also that it is ineffective in our modern, globalized world.”
Kagan, husband of Victoria Nuland, Assistant Secretary of State for European and Eurasian Affairs, had no small part in exerting pressure – mostly through the lobbying efforts of PNAC - in advocating for the military invasion of Iraq (he got his wish in March 2003).
Disregarding the realities of the present, in which US allies are abandoning their foreign outposts at the edge of Empire, Kagan wants his audience to believe that NATO forces will happily fill the violent void after US troops create a mythical “safe zone” against Islamic State in Syria. Such a plan is guaranteed to be no more successful than the “safe zone” created against the Taliban in Afghanistan has been.
“Once the safe zone was established,” Kagan enthuses, “many of those [American] troops could be replaced by forces from Europe, Turkey, Saudi Arabia, and other Arab states.” Similarly, many of the troops that had uprooted ISIS could be “replaced by NATO and other international forces to hold the territory and provide a safe zone for rebuilding the areas shattered by [ISIS’s] rule.”
Kagan has chosen a very interesting group of actors who would fill the smoking void left by America’s footprint in Syria: “Europe, Turkey, Saudi Arabia, and other Arab states.” But wait, weren’t those the very same countries mentioned in a declassified US military document that showed they actually supported the rise of Islamic State?
“If the situation unravels there is the possibility of establishing a declared or undeclared Salafist Principality in eastern Syria (Hasaka and Der Zor), and this is exactly what the supporting powers to the opposition want, in order to isolate the Syrian regime…”
In other words, those governments supporting the Syrian opposition – Gulf States, Turkey and the West – were desirous to see a band of thugs like Islamic State rise up and challenge Syrian President Bashar Assad. Now, Kagan somehow thinks it is sound strategy to let the same countries that desired an Islamic Caliphate in Syria in the first place to do battle against them.
If recent history is any reliable guide, Kagan’s chosen countries – all of which are suspected of funneling money and supplies to ISIS - will most likely work to protect Islamic State forces on the ground in Syria. In fact, the very same complaint has been leveled against the US military regarding their operations in Iraq.
Ordinary Iraqis, as well as high-ranking officials have reached the conclusion that “the United States is supporting the Islamic State for a variety of pernicious reasons that have to do with asserting US control over Iraq, the wider Middle East and, perhaps, its oil,” The Washington Post reported.
Such widespread suspicions amongst Iraqis of American double-dealing were reinforced last month when the Iraqi military said US fighter jets hit its forces as they were fighting Islamic State militants near the strategic city of Fallujah, just 40 miles outside of Baghdad. The Iraqis, after calling for US aerial support as they engaged the enemy, found themselves under heavy bombardment by the US jets instead.
Iraqi soldiers said 25 soldiers were killed in the incident and up to 40 wounded.
Meanwhile, it did not escape Kagan’s attention that “the Syrian crisis has further bolstered Russia’s position,” which is really the crux of Kagan's essay.
What follows is a misrepresentation of Russia's actions packed into one telling sentence: “Although Europeans generally share Washington’s discomfort with Moscow’s support for Mr. Assad and Russia’s bombing of moderate Syrian rebels, in the wake of the Paris attacks, any plausible partner in the fight against Islamic State seems worth enlisting.”
As has already been well established by the above-mentioned declassified military document, the idea of “Syrian moderate rebels” is a myth foisted upon the public in an effort to unseat yet another regional leader, while Kagan’s proposal for working alongside Russia in the fight against Islamic State has already been soundly rejected by practically everyone in Washington – for reasons that make absolutely no military sense whatsoever.
Indeed, only those beyond the iron grip of the neocons – for example, billionaire Republican frontrunner Donald Trump – can actually express admiration for Putin’s actions in Syria without fear of having his campaign war funds halted.
Now please imagine the following Syrian scenario: Washington decides to take the neocon approach (and despite the painful lessons of Iraq, Afghanistan and Libya) and puts boots on the ground in Syria, ostensibly to fight against the very terrorist forces the Pentagon had previously designated as an effective and desirable tool to “isolate the Syrian regime.”
At the same time, Russian air strikes are continuing to pound Islamic State positions, proving - much to the apparent chagrin of Western leaders - the absolute futility of risking boots on the ground in the Arab Republic.
Unless neocons like Kagan want US troops to serve as some sort of human shields for ISIS fighters, there is no good reason to risk boots on the ground in Syria when the technology is available to get the job done.
It doesn’t take much imagination to foresee how Kagan’s warped strategy, which is winning over Republican converts in the Beltway, could quickly spiral out of control, turning what was once a regional civil war into a global conflagration.
Before the Syrian conflict really gets out of control (and before somebody with heavy debts to pay back to the military industrial complex enters the White House), Washington policy makers should realize the advantages of cooperating with Russia in the skies above Syria, instead of risking everything on the ground, exactly where the Russian bombs are falling.
Robert Bridge is the author of the book, Midnight in the American Empire, released in 2013.
Peace Talks “Paused” After Putin’s Triumph in Aleppo
February 5, 2016 by Mike Whitney
http://www.counterpunch.org/2016/02/05/peace-talks-paused-after-putins-triumph-in-aleppo/
    “This is the beginning of the end of jihadi presence in Aleppo. After 4 years of war and terror, people can finally see the end in sight.”
    — Edward Dark, Twitter, Moon of Alabama
A last ditch effort to stop a Russian-led military offensive in northern Syria ended in failure on Wednesday when the Syrian Arab Army (SAA) backed by the National Defense Forces (NDF) and heavy Russian air cover broke a 40-month siege on the villages of Nubl and al-Zahra in northwestern Aleppo province. The Obama administration had hoped that it could forestall the onslaught by cobbling together an eleventh-hour ceasefire agreement at the Geneva peace talks.  But when the news that Syrian armored units had crashed through al Nusra’s defenses and forced the jihadists to retreat, UN envoy Staffan de Mistura suspended the negotiations tacitly acknowledging that the mission had failed.
“I have indicated from the first day that I won’t talk for the sake of talking,” the envoy told reporters, saying he needed immediate help from international backers led by the United States and Russia, which are supporting opposite sides of a war that has also drawn in regional powers.” (Reuters)  De Mistura then announced a “temporary pause” in the stillborn negotiations which had only formally begun just hours earlier. Developments on the battlefield had convinced the Italian-Swedish diplomat that it was pointless to continue while government forces were effecting a solution through military means.
After months of grinding away at enemy positions across the country,  the Russian strategy has begun to bear fruit. Loyalist ground forces have made great strides on the battlefield rolling back the war-weary insurgents on virtually all fronts. A broad swathe of the Turkish border is now under SAA control while the ubiquitous Russian bombers continue to inflict heavy losses on demoralized anti-regime militants. Wednesday’s lightening attack on the strategic towns of  Nubl and Zahraa was just the icing on the cake.  The bold maneuver severed critical supply-lines to Turkey while  tightening the military noose around the country’s largest city leaving hundreds of terrorists stranded in a battered cauldron with no way out.
For the last two weeks, the Obama team has been following developments on the ground with growing concern. This is why Secretary of State John Kerry hurriedly assembled a diplomatic mission to convene emergency peace talks in Geneva despite the fact that the various participants had not even agreed to attend. A sense of urgency bordering on panic was palpable from the onset. The goal was never to achieve a negotiated settlement or an honorable peace, but (as Foreign Policy magazine noted) to implement “a broad ‘freeze’ over the whole province of Aleppo, which would then be replicated in other regions later.” This was the real objective, to stop the bleeding any way possible and prevent the inevitable encirclement of Aleppo.
The recapturing of Nubl and Zahraa leaves the jihadists with just one route for transporting weapons, food and fuel to their urban stronghold. When loyalist forces break the blockade at Bab al Hawa to the northeast, the loop will be closed, the perimeter will tighten, the cauldron will be split into smaller enclaves within the city, and the terrorists will either surrender or face certain annihilation. Wednesday’s triumph by the Russian-led coalition is a sign that that day may be approaching sooner than anyone had anticipated.
It’s worth noting, that a senior fellow at the Brookings Institution, Michael O’Hanlon– whose plan to “deconstruct Syria” by using “moderate elements”  to “produce autonomous zones”–advised Obama and Kerry “not to pursue the failed logic of the current Syria peace talks but to explore a confederal model and seek buy-in from as many key players and allies as possible.”   In other words, the main architect of the US plan to break up Syria into smaller areas, (controlled by local militias, warlords and jihadists) thought the peace talks were “doomed” from the very beginning.
According to O’Hanlon the US needs to commit “20,000 combat troops” with  “the right political model for maintaining occupation”.   The Brookings analyst says  that “Any ceasefire that Kerry could negotiate…would be built on a foundation of sand” for the mere fact that the “moderate” forces it would support would be much weaker than either the SAA or ISIS. That means there would be no way to enforce the final settlement and no army strong enough to establish the authority of the new “unity” government.
O’Hanlon’s comments suggest western elites are deeply divided over Syria. The hawks are still pushing for more intervention, greater US, EU, and NATO involvement, and American and allied “boots on the ground” to occupy the country for an undetermined amount of time. In contrast, the Obama administration wants to minimize its commitment while trying desperately to placate its critics.
That means Syria’s troubles could resurface again in the future when Obama steps down and a new president pursues a more muscular strategy.  A number of  powerful people in the ruling establishment are as determined-as-ever to partition Syria and install a US puppet in Damascus. That’s not going to change. The Russian-led coalition has a small window for concluding its operations, eliminating the terrorists, and reestablishing security across the country.  Ending the war as soon as possible, while creating a safe environment for Syrian refugees to return home, is the best way to reduce the threat of escalation and discourage future US adventurism. But Putin will have to move fast for the plan to work.
Excerpts from:  “Deconstructing Syria: A new strategy for America’s most hopeless war“, Michael O’ Hanlon, Brookings Institute.
« Last Edit: 2016-02-07, 19:02:59 by evolvingape »
Syria: NATO's Last Desperate Options in Lost Proxy War
http://journal-neo.org/2016/02/06/syria-natos-last-desperate-options-in-lost-proxy-war/
06.02.2016 Author: Tony Cartalucci
As Syrian forces and their allies complete the encirclement of Syria’s largest city, Aleppo, the United States and its regional allies have signaled a sudden increased interest in ground operations in Syria, including US airpower backing Turkish-Saudi ground forces.
While it is obvious the US and its allies are responding directly to the collapse of their proxy forces across the country, their most recent threats to further escalate the conflict in Syria are tenuously predicated on “fighting ISIS.”
The Guardian in its article, “Saudi Arabia offers to send ground troops to Syria to fight Isis,” would report:
    Saudi Arabia has offered for the first time to send ground troops to Syria to fight Islamic State, its defence ministry said on Thursday.
    “The kingdom is ready to participate in any ground operations that the coalition (against Isis) may agree to carry out in Syria,” said military spokesman Brigadier General Ahmed al-Asiri during an interview with al-Arabiya TV news.
    Saudi sources told the Guardian that thousands of special forces could be deployed, probably in coordination with Turkey.
In reality, Turkey and Saudi Arabia have played a central role in both the intentional creation of ISIS and the logistical and financial perpetuation of its activities within Syria and Iraq. This is not according only to enemies of Ankara and Riyadh, but according to their central most ally, the United States.
As early as 2012, a Department of Intelligence Agency (DIA) document (.pdf) admitted in regards to the Syrian conflict and the rise of ISIS that:
    If the situation unravels there is the possibility of establishing a declared or undeclared Salafist principality in eastern Syria (Hasaka and Der Zor), and this is exactly what the supporting powers to the opposition want, in order to isolate the Syrian regime, which is considered the strategic depth of the Shia expansion (Iraq and Iran).
Mention of this “Salafist” (Islamic) “principality” (State) in 2012 is clearly when it was decided to transform US, Saudi, and Turkish-backed Al Qaeda affiliates – then called “rebels” – officially into ISIS. To clarify just who these “supporting powers” were supporting its creation, the DIA report explains (emphasis added):
    The West, Gulf countries, and Turkey support the opposition; while Russia, China, and Iran support the regime.
It is clear then, that this sudden interest in escalation has nothing to do with ISIS and more to do with rescuing the West’s proxy terrorists before they are entirely eradicated and/or expelled from the country. Russia, who has played a pivotal role in reversing the tides against Al Qaeda and ISIS militants in Syria, has even gone as far as accusing Turkey of what appears to be an imminent military incursion into the country’s northern region.
Reuters would report in its article, “Russia and Turkey trade accusations over Syria,” that:
    Russia said on Thursday it suspected Turkey was preparing a military incursion into Syria, as a Syrian army source said Aleppo would soon be encircled by government forces with Russian air support.
ISIS, as it has always been designed to be, serves merely as a pretext for justifying any prospective operation by the US and its regional allies – an operation that will be in all reality aimed at challenging and rolling back Syrian and Russian gains on the battlefield – or at the very least, providing an unassailable sanctuary within Syrian territory for the West’s defeated proxies to retreat to.
The Buffer Zone (Again)
The idea of carving out a buffer zone from Syrian territory also goes back as far as 2012 when it became apparent that Libya-style regime change would be difficult if not impossible to achieve quickly. The idea would be to switch from the fast paced, overwhelming proxy war the US and its allies had hoped to panic Damascus out from power with, to a more paced proxy war launched from NATO-occupied “safe havens” in Syria.
With NATO aircover, terrorists could safely launch operations deeper into Syrian territory, slowly expanding both the buffer zone and NATO’s defacto no-fly zone.
Eventually, it was planned, the buffer zones would lead directly to the collapse of the government in Damascus.
Again, far from a conspiracy theory, this plan was openly discussed within policy circles in Washington.
The Brookings Institution – a corporate-funded policy think-tank whose policymakers have helped craft upper-level strategy for the Iraqi, Afghan, Libyan, and now Syrian conflicts as well as plans laid for future confrontations with Iran and beyond – has been explicit regarding the true nature of these “buffer zones.” In a recent paper titled, “Deconstructing Syria: A new strategy for America’s most hopeless war,” it states:
    …the idea would be to help moderate elements establish reliable safe zones within Syria once they were able. American, as well as Saudi and Turkish and British and Jordanian and other Arab forces would act in support, not only from the air but eventually on the ground via special forces.
The paper goes on by explaining (emphasis added) :
    The end-game for these zones would not have to be determined in advance. The interim goal might be a confederal Syria, with several highly autonomous zones and a modest (eventual) national government. The confederation would likely require support from an international peacekeeping force, if this arrangement could ever be formalized by accord. But in the short term, the ambitions would be lower—to make these zones defensible and governable, to help provide relief for populations within them, and to train and equip more recruits so that the zones could be stabilized and then gradually expanded.
In many ways, this has been attempted already to one degree or another in terrorist-occupied territory in Syria. As Syrian forces with Russian aircover moved into northern Aleppo, reports across the Western media complained that infrastructure underwritten by Western governments was being destroyed. This infrastructure, including bakeries literally run by Al Qaeda using flour supplied by the US government, was part of Brookings’ plan to “make these zones governable.”
The presence of Russian military forces in Syria has apparently prevented the West from making these zones more “defensible” through the use of direct military force aimed at Syrian troops.
How this plan will manifest itself now remains to be seen. What is most likely is a limited incursion into northern Syria into the shrinking Afrin-Jarabulus corridor before Syrian, Russian, and Kurdish forces completely fill the void. With Turkish and Saudi forces holding even a small percentage of the corridor, attempts to incrementally expand it as envisioned by Brookings may be made in the near to intermediate future.
Brookings had also envisioned coordinating Turkish operations in the north with an Israeli attack in the south – another option that is likely still being considered.
There is also the possibility of the West attempting to enter and seize a sizable piece of Syrian territory Syria’s eastern most region- linking it up with territory in Iraq that appears likely to be stripped from the central government in Baghdad through similar tactics.
Best Case Scenario is Still Defeat + Costly Long-Term Standoff
The most likely result, however, would be a Golan Heights-style stand-off that could last years, if not decades.
Syria would still be able to restore peace and order across the vast majority of its territory, liquidate the West’s proxies within their borders, and perhaps operate proxies of their own within seized territory – creating a costly conflict politically, financially, and militarily for Turkey.
For Saudi Arabia, the further stretching of its military forces would strain operational preparedness within the Kingdom, and further diminish its fighting capacity amid its war of aggression against neighboring Yemen. It is also another opportunity to expose inherent weaknesses in its military capabilities, further emboldening the growing arc of opposition challenging its influence throughout the Middle East.
Worst Case Scenario Threatens US Hegemony
The worst case scenario includes a NATO incursion into northern Syria being met by overwhelming resistance, blunting both its air and ground forces. With the majority of Turkish and Saudi military equipment originating in the US and Europe, it would in turn further weaken the illusion of Western military superiority upon the global stage. This could have significant impact on the integrity of both the European Union and the NATO alliance, as well as on prospective members seeking to join either or both in the near to intermediate future.
With the endgame approaching fast in Syria, Damascus and its allies may seek to invest heavily in making this second, worst case scenario the most likely outcome of any US-Turkish-Saudi incursion into northern Syria. By doing so, they may deter such a move from even being made in the first place, or the consequences unimaginable for the West should they try despite the obvious risks.
Since the prospect of a buffer zone being carved out of Syrian territory in the event of a failed regime change operation against Damascus has been literally years in the making – it is sincerely hoped that significant measures have been planned by Syria and its allies to counter it for just as long.
Tony Cartalucci, Bangkok-based geopolitical researcher and writer, especially for the online magazine“New Eastern Outlook”.
Saudi invasion of Syria: The bluff that could ignite World War III
Published time: 7 Feb, 2016 14:33
https://www.rt.com/op-edge/331648-saudi-invasion-syria-bluff/
The Saudi plan to send ground troops into Syria appears to be just a ruse. But this is precisely the kind of reckless saber-rattling that could ignite an all-out war, one that could embroil the United States and Russia.
Saudi rulers have reportedly amassed a 150,000-strong army to invade Syria on the alleged pretext “to fight against terrorism” and to defeat the so-called Islamic State (also known as ISIS/ISIL). Saudi officials told CNN that in addition to Saudi troops there are ground forces from Egypt, Turkey, Sudan, Morocco, Jordan, Qatar, Bahrain and the United Arab Emirates.
Syria’s Foreign Minister Walid al-Muallem gave a categorical response, saying the move would be seen as an act of aggression and that any invasion force regardless of its stated reasons for entering Syria will be sent back in “wooden coffins”.
Nevertheless, US President Barack Obama has welcomed the Saudi plan to intervene in Syria.
Obama’s Defense Secretary Ashton Carter is this week due to meet in Brussels with counterparts from the US-led so-called “anti-terror” coalition to make a decision on the whether to activate the Saudi plan. A Saudi military spokesman has already said that if the US-led coalition gives its consent then his country will proceed with the intervention.
In recent weeks, Carter and other senior US officials, including Vice President Joe Biden, have been calling for increased regional Arab military action against ISIS in Syria and Iraq. Carter and Biden have also said the US is prepared to send in its own ground troops en masse if the Geneva peace talks collapse.
Now, those talks appear to be floundering. So, does that mean that a large-scale invasion of US-led foreign armies in Syria is on the way?
Let’s step back a moment and assess what is really going on. The Saudi warning – or more accurately “threat” – of military intervention in Syria is not the first time that this has been adverted to. Back in mid-December, when Riyadh announced the formation of a 34-Islamic nation alliance to “fight terrorism”, the Saudis said that the military alliance reserved the right to invade any country where there was deemed to be a terror threat – including Syria.
Another factor is that the House of Saud is not pleased with US-led diplomatic efforts on Syria. US Secretary of State John Kerry’s bustling to organize the Geneva negotiations – supposedly to find a peace settlement to the five-year conflict – is seen by the Saudis as giving too many concessions to the Syrian government of President Bashar al-Assad and his foreign allies, Russia, Iran and Lebanon’s Hezbollah.
The Geneva talks – which came unstuck last week – can be arguably assessed as not a genuine internal Syria process to resolve the war – but rather they are a cynical political attempt by Washington and its allies to undermine the Syrian government for their long-held objective of regime change. The inclusion among the political opposition at Geneva of Al Qaeda-linked militants, Jaish al-Islam and Ahrar al-Sham, with Western backing, illustrates the ulterior purpose.
The Washington Post gave the game away when it reported at the weekend: “The Obama administration has found itself increasingly backed into a corner by Russian bombing in Syria that its diplomacy has so far appeared powerless to stop.”
In other words, the Geneva diplomacy, mounted in large part by Kerry, was really aimed at halting the blistering Russian aerial campaign. The four-month intervention ordered by Russian President Vladimir Putin has turned the tide of the entire Syrian war, allowing the Syrian Arab Army to win back strategically important terrain.
That the Russian military operations have not stopped, indeed have stepped up, has caused much consternation in Washington and its allies.
Russia and Syria can reasonably argue that the UN resolutions passed in November and December give them the prerogative to continue their campaign to defeat ISIS and all other Al Qaeda-linked terror groups. But it seems clear now that Kerry was counting on the Geneva talks as a way of stalling the Russian-Syrian assaults on the regime-change mercenaries.
Kerry told reporters over the weekend that he is making a last-gasp attempt to persuade Russia to call a ceasefire in Syria. Indicating the fraught nature of his discussions with Russian counterpart Sergei Lavrov, Kerry said: “The modalities of a ceasefire itself are also being discussed… But if it’s just talks for the sake of talks in order to continue the bombing, nobody is going to accept that, and we will know that in the course of the next days.”
Moscow last week was adamant that it would not stop its bombing operations until “all terrorists” in Syria have been defeated. Syria’s Foreign Minister al-Muallem reiterated this weekend that there would be no ceasefire while all illegally armed groups remain in Syria.
What we can surmise is that because the US-led covert military means for regime change in Syria is being thwarted and at the same time the alternative political means for regime change are also not gaining any traction – due to Russia and Syria’s astuteness on the ulterior agenda – the Washington axis is now reacting out of frustration.
Part of this frustrated reaction are the threats from Saudi Arabia, Turkey and other regional regimes – with US tacit approval – to go-ahead with a direct military intervention.
In short, it’s a bluff aimed at pressuring Syria and Russia to accommodate the ceasefire demands, which in reality are to serve as a breathing space for the foreign-backed terrorist proxies.
From a military point of view, the Saudi troop invasion cannot be taken remotely serious as an effective deployment. We only have to look at how the Saudi regime has been battered in Yemen over the past 10 months – in the Arab region’s poorest country – to appreciate that the Saudis have not the capability of carrying out a campaign in Syria.
As American professor Colin Cavell noted to this author: “Saudi intervention in Syria will have as much success as its intervention in Yemen. History has clearly shown that mercenary forces will never fight external wars with any success or elan, and no Saudi soldier in his right mind truly supports the Saudi monarchy. Everyone in Saudi Arabia knows that the House of Saud has no legitimacy, is based solely on force and manipulation, propped up by the US and the UK, and – if it did not have so much money – is a joke, run by fools.”
Thus, while a military gambit is decidedly unrealistic, the real danger is that the Saudi rulers and their American patrons have become so unhinged from reality that they could miscalculate and go into Syria. That would be like a spark in a powder keg. It will be seen as an act of war on Syria and its allies, Russia, Iran and Hezbollah. The US would inevitably be drawn fully into the spiral of a world war.
History has illustrated that wars are often the result not of a single, willful decision – but instead as the result of an ever-quickening process of folly.
Syria is just one potential cataclysm.
Finian Cunningham (born 1963) has written extensively on international affairs, with articles published in several languages. Originally from Belfast, Northern Ireland, he is a Master’s graduate in Agricultural Chemistry and worked as a scientific editor for the Royal Society of Chemistry, Cambridge, England, before pursuing a career in newspaper journalism. For over 20 years he worked as an editor and writer in major news media organizations, including The Mirror, Irish Times and Independent. Now a freelance journalist based in East Africa, his columns appear on RT, Sputnik, Strategic Culture Foundation and Press TV.
The statements, views and opinions expressed in this column are solely those of the author and do not necessarily represent those of RT.
If you have a significant military on a credit card and your only way out of criminal responsibility for a destroyed global economy and massive crimes against humanity, is total global war, would you go for it ?
The X-Files Season 10 Episode 1: My Struggle
http://www.tv.com/shows/the-xfiles/my-struggle-3309943/
In the Season 10 opener, agents Mulder and Scully return after 13 years to investigate a government conspiracy at the behest of a popular web-TV-show host, who introduces them to a woman who claims she's an alien abductee and shares startling news with them.
The first minute of the show depicts 911 as a warm-up to WW3..  :o
Pages: 1 ... 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 ... 100
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-18, 09:27:17
