OK
I found Duncans post
It was his mentioning of reactive power that was Different
Duncan
Quote:
OK even with a pair of spoons and very careful adjustment I can get amazing results, But what are we tuning to?
I have an Idea sort of “roughed out” which I'd like to float It starts with considering a radio system.
Or even a TV system I'm sure most of your have played about with CB radio for instance. At first it would seem to have nothing to do with the electric grid but of course all the same bits are in place a/ the Transmitter (which is analogous of the generator) b/The cable feeding the antenna (which is analogous of the grid itself c/The antenna Itself which is analogous of our equipment receiving the power (heater,motor whatever) and lastly the antenna launches the signal into the Aether this is analogous to how you perceive the energy heat,movement,light whatever.
If you have ever connected a TV or one of these CB things you will find that Coaxial cable is the stuff to use, you will also find that it has a “Characteristic Impedance” typically 75 ohm and some times 50 ohm but I guess by design it can be anything. Our electric grid also has a “Characteristic impedance” and so I think a little thought on the matter is in order.
This coax and 75 ohms where would you measure it with your meter? The answer is if course you cant.
The Transmitter is by design is manufactured to transfer 100% of its power at a certain frequency into an Impedance of 75 ohms. The coax in turn delivers the power to the Antenna which again by design has a Impedance designed to be 75 ohm and it in turn is physically made to launch your power onto the Aether. It is a little bit like pass the parcel but each of the four people involved has to be suited to handle the load and pass it to the next guy.
and so what happens if the transmitter changes frequency ? Well each transmitter has one of these
http://www.mds975.co.uk/Images/radios/atu09.jpgIt can be adjusted to “fool” the transmitter into seeing 75 ohms and so give you the adjustment required to put everything “bang on tune”
If things are not On tune some most unpleasant things occur,if they are for instance 100% out of tune all the power from the transmitter is reflected straight back like throwing a ball against a wall and normally blows up the transmitter.
If you get it 75% tuned most of the power goes out onto the Aether 25% is forced to stay on the coax if fact if memory serves they refer to it a “a standing wave” In practice you can actually go along the coax with a neon or small fluorescent tube and it will light and dim as you follow this wasted power and you will actually feel hot spots on the coax..
Radio Amateurs go to inordinate lengths to reduce standing waves because they cause what they refer to as “Spurious emissions” that is they transmit bursts of power that can appear anywhere.
I'm sure at some stage you have heard police or Taxi drivers or CB operators crashing through onto your phone or TV on a frequency far away from where they should be . That is because of this “evil twin” of the sine wave.
Now it so happens that “The grid” is exactly the same sort of system. Vastly different powers and currents and frequencies involved but essentially the same.
Electrical engineers such as myself are taught exactly the same subject as radio engineers but in an entirely different fashion, with different terms and different units and Its extremely difficult to marry the two. And so we end up with a situation where allied trades are discussing the same subject but not able to understand each other.
There is for instance a subtle 90deg phase shift introduced in the “radio transmission” teaching of things to sort of pat things into shape a bit Its not really required in electrical engineering so its just “omitted” The maths route is really a “bear” of a line to go down BUT … Eric Dollard is one of the few that is obviously well versed in both fields and has noticed the anomalies and been after them like a terrier after a rat his writing is recommended (gives me head ache) so I can only take small bites.
It does become very clear that big lumps are missing or altered in such a way that the cap is forced to fit the head.
So much for a extremely hashed version of a radio transmission what of our grid? It has a “Transmitter” a generator in fact lots of them joined together they will have a maximum power transfer impedance (just like the CB radio) although Its going to be very low, Its also going to have lots of this evil twin the standing wave sitting solidly on the grid except they call it re-active power.
Much like the spurious radio signals it arrives any were with full power unannounced.
It blows up transformers, It loves eating semi-conductors, Its probably responsible for spontaneous combustion. It generates heat on the grid, the supply people have to put in much bigger cables to cater for reactive power,standing wave, watt-less component (call it what you will)
And to me It rather looks like some of this worthless expensive watt-less component is being “tuned “ and used to heat water,. With total respect to Mr C just to get a little closer P = VI is what the standard house meter is reading.
Power =VI cosφ
is what a typical factory meter would be reading in order to encourage Power factor correction. Power factor correction doesn't really cure the problem anyway it simply throws it back on the grid. And ups the Ante
these are all known and accepted … BUT and its a big BUT what if As I am starting to suspect we are tuning to the reactive watt less component that the power companies hate and turning it into heat. And so doing them a great kindness. Do you think we could heat our homes and send them a bill for removing the watt-less component?
Yeh I'm sure they'd be highly delighted. It would be very interesting to see one of these heaters that is working really well disconnected from the grid and connected instead to a battery and a true sine wave inverter.
A/ It would remove the shock hazard (to a certain extent)
B/ It prove/dis prove the tuning to a specific frequency
C/ It would give direct current volts amps reading
D/If it does what I suspect we can all buy and use the same inverter
What I suspect it will do …. Not having access to the spurious emissions, reactive power,wattless component call it what you will (a rose by any other name) It will draw most of the power which it is tuned to receive
from the Aether In the same fashion as all these machines
https://lh6.googleusercontent.com/-t...2520floyyd.pngNew Free Energy by George Mitchell - YouTube
ThaneCHeins's Channel - YouTube
F.M.CHALKALIS ENERGY MULTIPLIER - YouTube
This absolutely free un patentable god given energy flooding vertically into these machines and only visible as it mixes with the ambient light frequencies is what I suspect is heating the water although we of course can't see the interaction.
It simply remains to confirm in tests I know from calculation that even with my crude set up I am at least “very efficient” To make a tuner such as this
http://www.rocketradio.co.uk/ekmps/s...mhz-1010-p.jpgis to a Transmitter antenna for our heater and the grid connection is an ambition, but perhaps an inverter we could all buy regardless of country and connect to a standard construct is also not a bad way to go, and the power utilities can be left to sort out their own life choking, planet strangling, "evil power" which this power of which we have been deprived for many years is in direct opposition to “in every respect.”.
I notice when I draw attention to the above links on other relevant threads they tend to DRY UP for some reason I hope that isn’t the case here!
spurious emissions Light tubes lite up under powerlines without plugs? EMF Cra - YouTube
__________________
Whatever you can do,or dream you can,begin it.Bold
