2025-03-31, 22:14:42
Pages: 1 [2]
Author Topic: The Lenz delay propulsion effect is authentic !  (Read 37786 times)
Thane Likes this Man !
http://www.youtube.com/watch?v=QziS_o6gSnQ&feature=uploademail
If your a builder I think you will Too?
Unfortunately none of these guys do truly scientific tests e.g
1) Test the drag effect with just a bolt (core), no coil
2) Test the drag effect with the coil with no core (bolt)
3) Test the completed assembly, coil with core.
4) Test the power draw with no, coil, no core.
Just a bolt in a rotating, alternating field will produce a drag. It makes sense that a small time delay in the coil plus bolt assembly will lessen the drag.
Problem is, you cannot get below or even equal to the power draw with no coil and no core. That's what I see from the video's. The big white elephant in the room goes unnoticed.
If they were able to get below the power draw of (4) versus (3), I would be interested.
Well Thane says it "generates under a load"
http://www.youtube.com/user/ThaneCHeins?feature=mhee#p/u/4/u3gVfltiO-E
And he's gonna post that peski data!!
Rational analysis, Ion. I came to the same conclusion.
The essential experiment (no coil, no core) has not been done. It is obvious it should be done, so I guess rather that the author led it and avoids to show us the negative results.
Pages: 1 [2]
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-03-31, 22:14:42
