Well i was board,so i had to go and look  Anyway,it is a simple circuit,and i have all the gear needed to build and test it--so why not. I took Lindermanns circuit,and made a change or two  --see diagram below. I see ION made mention of diodes that do not need to be there,so i ask--which ones?,as they all seem to be needed to me,so as the circuit can do what it is suppose to do--as far as i can tell. P.S--I did remove the diode on the negative rail ,as that one is not needed. The change i made is to shift the position of D1,so as the inductive kickback cannot be absorbed by the battery. This is so i can see if the cap voltage dose indeed go higher than that of the supply voltage. I will be driving the transistor with my FG--easiest way to go for adjustments. Some questions,and ideas as to how to make it even more efficient. 1-would it be better to use a mosfet as per Lindermanns schematic? 2-should we remove diodes 2 and 3,and try to make it a tank circuit,so as it operates at resonance ? 3-I have added a ferrite core to the LR to increase the inductance value--would this make it better or worse? Any ideas would be great. Brad
