we have to harvest the kickbacks to another capacitor or back to the source with a pulse transformer and diode setup Who needs a diode why waste energy in the diode. We know when we turn off the drive fet, so if we were to wait an adjustable amount of time and switch a cap across the coil using a fet for a determined amount of time then we should be able to dump the energy into the cap without a diode. The question is how to connect a cap to the coil using a fet when the fet needs to be referenced to the pic ground. If we had 2 fets and 2 caps, each cap opposite polarity then we could then capture positive and negative cycles if needed, but again we would need to drive this from a pic port line. as WW said which i loved LOL rectification by logic  Infact this has given me an idea for a project, to build the worlds first pic bridge rectifier without diodes  Bearing in mind we know what the voltage of the waveform is by sampling using an A/D converter
« Last Edit: 2011-08-13, 22:11:53 by Peterae »
