2025-04-16, 23:47:19
Author Topic: Flux Compression Generator  (Read 5341 times)
Please share this info with as many people as possible even if you don't understand it. Someone out there will.
"Whatever our resources of primary energy may be in the future, we must, to be rational, obtain it without consumption of any material" Nikola Tesla
  Everything is relative  And never take anything too serious or too lightly.... While to go forward you really are going backwards..... Nothing is impossible, it is only wheather or or not it is probable in my time....$um1
            Here is some of my research I have to share. The plasma ignition system is also the power supply to these devices. It is a magnetic flux compression device.
THE FUNDEMENTALS NEEDED
Marko Rodin has discovered the source of the non-decaying spin of the electron. Although scientists know that all electrons in the universe spin, they have never discovered the source of this spin. Rodin has. He has discovered the underpinning geometry of the universe, the fabric of time itself. He has done this by reducing all higher mathematics – calculus, geometry, scalar math – to discrete-number mathematics.
http://vortexmath.webs.com/
                                  Edward LEEDSKALNIN
                                       Magnetic Current
                                                 http://www.rexresearch.com/leedskal/leedskal.htm
                                             THE  ELECTRON  PHASE  SHIFT
                                   http://glafreniere.com/sa_phaseshift.htm
                                               FLUX COMPRESSION GENERATOR
                             http://reactor1967.fortunecity.com/freenergy.html
High Energy Free Energy Generator - Fcg's being used for free energy. The USA military use this to power its high energy weapons. (Status classified by the USA)
                                                  http://reactor1967.fortunecity.com/ps.jpg
MAGNETIC PULSE COMPRESSION (MPC)
Magnetic pulse compression utilizes reactors in conjunction with capacitors to shape input pulses into narrow output pulses of much higher current . MPC, therefore, allows the designer to use less expensive input switches with lower current ratings. MPC can also extend the lifetime of the input switch. Advanced MPC devices - capable of generating power levels of multi-terawatts in tens of nanoseconds - have been realized utilizing Metglas® cores.
                                                          http://www.metglas.com/products/page5_1_3.htm
This product may require licensing for export outside the United States:
Please visit the U.S. Dept of Commerce website to understand the necessary requirements. ( http://www.bis.doc.gov/licensing/index.htm#factsheets )
Metglas®, Inc. requests that the applications and approval accompany any request for samples, quotations, or purchase orders.
Theme © PopularFX | Based on PFX Ideas! | Scripts from iScript4u 2025-04-16, 23:47:19
